Guest Blogging Question? How many links in an article?
I am being offered by a blog to have more than 5 links in an article that points directly to our money sites. The blog is in the same niche. This is the first time i am being offered more than 2-3 links in an article. Should i do it?
How many links should be in an article so not to be penalized by Google? Does it look unnatural to have more links in an article that points to the same site but different pages?
I was originally taught by my SEO sensei that you can include 1 link for approx. every 100 words. Still, I wouldn't do more than 1 or 2. You definitely don't want to include more than one link to the same page. Here's a video of Google's (former?) Matt Cutts on that.
Be very careful when guest blogging for links. Here is what Cutts had to say about Guest Blogging:
I wouldn’t recommend relying on guest posting, guest blogging sites, or guest blogging SEO as a linkbuilding strategy.
http://searchengineland.com/matt-cutts-stick-a-fork-in-it-guest-blogging-is-done-182147
If you are guest blogging for links, I would suggest reading Cyrus Shepard's The Rules of Link Building here on the Moz Blog. He states that you should never ask for the anchor text, and I agree. Worry more about the quality of the content and less about the link.
Hey Wayne,
Again there is no rule for it but the censorship and keeping the article quality alive is in your hand. I have seen articles that contain 5 links in total and still contain the quality on the other hand there are articles where 2 links does not make sense.
You said 5 link all going to one money making site, this sounds fishy to me!
Hope this helps!
You are doing guest blogging for the links? Then just 1 will do it to get you penalized. Forget about guest blogging for links, instead, create great content and promote it trying to get a natural link.
If you are doing guest blogging, don't do it for the links. If in one article you write it happens you have an excellent article to link to in one of your properties then link to it. But do NOT write so you can insert a link.
Depends on the extent , but I never use more than two links per article. As much a link with the anchor of the keyword and the other "brand link". Greetings !
I use maximum 2-3 links if the post is about 500 words, but i think it is depending on the amount of the text
There is so many articles online talking about this topic. A blog should contain under 6 links which under 4 is the most desired. is not the quantity is the quality of the links. A resource i found is below:
Value of Links? What is each link worth?
Morning Everyone, I just had this thought and wondered what everyone's opinions were in terms of link value in monetary terms. We'll assume for the purposes of this that the links come from contextually relevant sites and that the sites in question have got the Moz DA from being high quality and have a good quality incoming link profile. Its a bit of a theoretical question, but i guess imagine if the only way you could get links was to pay for them, what would they be worth to you. This is link value for SEO purposes, they will have in addition value from traffic from good sites, that no doubt varies wildly depending on topic. I assume everyone also agrees on: The first link from a domain is the most valuable High DA sites are worth more than low ones. So could anyone who has an opinion on the link value suggest a monetary value for links. Its really just using a monetary amount to see how best to target my time. Here is my example of what might be expected, but I am hoping people with more knowledge will perhaps correct it. DA Rating First Link 2nd-5th Link 5th-10th Link 10Plus Links 5 $5 $2 $1 $0 15 $7 $3 $2 $1 25 $25 $10 $5 $2 35 $45 $20 $7 $3 45 $65 $30 $11 $4 55 $95 $45 $19 $5 65 $200 $100 $45 $6 75 $350 $120 $65 $9 85 $700 $240 $95 $15 95 $1100 $450 $200 $30
Link Building | | wellandpower1 -
If I disavow bad links on "disavow link webmaster" will they still show up on my moz reports?
We recently found out we have a lot of bad links linking back to our website from spam sites, I disavowed them through the google disavow link webmaster. On my moz report it still shows the links, is that normal?
Link Building | | Ryan.Cruz0 -
How can I find the best sites to guest post on while linking back to my article?
Whats the best way to find sites to guest blog on. There are just so many and I don't want to make bad choices so my current rankings don't get hurt
Link Building | | aronwp0 -
Do footer links pass less link juice?
One of my best inbound links for PA and DA happens to be a footer link, curious if it's less valuable or has any value at all.
Link Building | | Theskimonster0 -
Footer Links And Link Juice
I'm starting to learn about link juice and notice in GWMT > Traffic > Internal Links, that the list is in this order by the links counted on each page. Some are in the footer and some are in the header, with some being more important than others commercially i.e. /register /privacy /terms /search /sitemap /disclaimer /blog /register So I am wondering if I should add a 'no-follow' attribute to the footer links i.e. privacy, terms, disclaimer and leave the others as they are? Does this help retain link juice on each page where the links appear? Or am I missing the point all together? This is my website: http://goo.gl/CN0e5
Link Building | | Ubique0 -
Should I link from my blog back to my product pages?
Hello... I just installed a blog on my Magento site. My question is whether or not i should be linking within posts on the blog back to the product or category pages that i am talking about...from an SEO perspective. If in my post i am talking about flashlights being important when preparing for a storm, should i link the word flashlights to the flashlight category on my site? I know I can do this, the question is should i, from google's perspective. A) should i link the word (flashlights) to that category on my page B) should i put a line at the bottom of every post that says something like "if you are interested in purchasing flashlights, visit this link" and hyperlink that whole sentence... THANKS!
Link Building | | Prime850 -
Blog. vs /Blog
I need to be able to explain to a client the difference from an SEO perspective between Blog. vs /Blog. www.website.com/Blog vs Blog.website.com The client wants to know which one will help there website with SEO. I belive both will but /Blog will more. I'm looking for a tangible answer only centered around this subject. Thanks,
Link Building | | cfield_splashmedia.com0 -
Text Link vs image link?
Which passes most link juice a text link or an image with the correct 'alt' attribute? Do the pass the same amount or is one more valuable than the other?
Link Building | | SamCUK0
