Will changing my business location affect my ranking for localised searches in my original area?
I run a mobile outdoor personal training service in London, UK (i.e. no bricks and mortar gym). Or, rather, my business is in London (all my clients and the freelance trainers that work for me) but I'm personally due to move out to the county of Suffolk.
As I work from a home office and my company's registered address is my home, that means I have to inform Companies House and various government agencies that the company has moved.
Does this mean:
a) I also must tell Google the company has moved, and;
b) if I do will Google start to see my website as being for a Suffolk-based company?
I really don't want this to happen: my clientele are mostly in London., I still want to market to Londoners. And if I want to expand the areas covered by my company, Suffolk is not high on my list.
You'll excuse me if this is a simple question!
Thanks for any help you could give
Hi Fiona,
Unfortunately, it does not really matter if you set up multiple service areas, you'll still only have a chance of ranking in the city or near the area the business is actually located. (Depending on competition.)
And also, since you'll just be moving there, you may not rank well at 1st compared to established businesses that have been there for a long time. The algo is like a giant puzzle and there are lots of things at play that go into the ranking order.
Moving can be challenging for your Google ranking, so I'd suggest reading the Moz Local Search Ranking Factors if you have not yet and be ready to start working to increase some of those ranking signals after you move. Using the Moz Local tool to try to either correct or build new citations to the new location would be important too.
That does help, Linda, thank you. Although I'm in a quandary. If I register multiple service areas under my business listing, will my competition still rank higher than me if their business address is in London ? I assume that when Google are informed of my move to another town, my organic ranking for London-related keywords ("personal training in westminster") would be affected?
Thanks, Jeff, I have unchecked 'I serve customers at my address' and have added the locations I serve customers.
There are a few issues I wanted to point out.
1st off the address in your Google dashboard needs to be the real address you work from. So if you move you MUST change it in dash. If you don't all kinds of problems could come up including duplicates and including your listing being deleted.
Any time you move, it breaks NAP so you will likely lose ranking.
If you move to a new city you will likely only rank in that city, not the previous city. (Depends on competition and proximity.)
In either case you need to set service area and be sure address is hidden. But that service area does not affect ranking in any way at all. Ranking area is still determined by the location that's in dash, even though address is hidden.
Hope that helps and best of luck!
A reputable business will have a trading address on their site, therefore the actual trading address and listings will differ. In this case every aspect of NAP will differ.
customerparadignm.com makes a good point, however I've seen consistency & having a set office location work better.
https://cloudz.click/local/ does a great job of cleaning up consistency errors and is less expensive than Yext Business Listings.
Tips:
1. Submit a Change Of Address to G
2. Consistency, consistency, consistency.
3. Verify all major business listings for your new location.
4. Make sure your new location is on your website.
5. Schema markup never hurt.
Good Luck Fiona!
Hi fionadoggett,
The thing is that you do not need to tell Google you are moving. Remember that you are working online, so you can hold your business location just for Google. Anyway i have seen many times in google places two different locations of the same business (but in the same city) so, may be is possible to hold both of them.
Good luck
Yes, unfortunately if you change the address that you have listed on your Website, along with the address you have for a Google+ page, then you might start to have issues with local search results migrating to Sufolk instead of London.
My recommendation: Change your Google+ listing to a Service-area business
For local business search, you'll want to set up the business so it not based on the physical location / address (i.e. your new home in Sufolk), but serves a greater area (i.e. London). In order to do this, you will need to set up your Google+ account as a Service-area business on Google.
This is perfect for a trainer, local plumber, tree trimmer or construction crew that works at customer's locations (either homes or businesses) vs. your home address.
My recommendation would be to go here:
https://support.google.com/business/answer/3038163?hl=en... and set up your service areas based on the zip codes or cities that the business serves.
You also have the option to check or uncheck, "I serve customers at my business address."
You might need to go through another round of verification to make this change, however.
I hope this helps!
Thanks,
- Jeff
Unsolved Has anyone noticed the Google quote request response rate never changes?
We respond to almost 100% of our quote requests, yet every quote email that comes in from Google shows a 27% response rate and it never changes. Has anyone else seen this or have any insight into it?
Local Listings | | r1200gsa0 -
Google Business Listing with no physical office location
Hey, everyone! As a business owner who works from home and doesn't have a physical office location. Is setting up a Google business listing without location going to hurt my local search ranking? Should I get a virtual office so I have a physical location? Thank you!! 😃
Local Listings | | ichorstudios0 -
How do you fix a Google My Business Location Issue if the road doesn't yet exist on Google Maps?
My core question is just: How do you fix a Google My Business Location Issue if the road doesn't yet exist on Google Maps? Do I have any other options other than to just wait on Google to catch up with reality? Here's the background: I work for a hospital. We just opened a clinic on a street that is real and has a U.S. Postal Address, but Google Maps doesn't recognize it, and redirects people to a house . This is our postal address: 8343 S 168th Ave Omaha NE 68136-1677 If a patient enters the following into google maps, 8343 S 168th Ave, the location the map autofills the wrong zip code, and sends them to a home that is on S 168th Ave. (where in theory a home would exist if it had that home number). The road does exist in that portion of town. If a patient enters 8343 S 168th Ave, Omaha NE 68136, google maps takes you to the correct location, but it automatically changes Ave to St. The verified Google My Business listing also lists it as Street, even though on the back end I've put in the word Avenue, and it shows up in the right place. If however someone just searches by name "Chalco Clinic" the right Google My Business comes up. This is the Google My Business page I'm referring to: https://www.google.com/maps/place/Nebraska+Medicine+-+Chalco/@41.1754796,-96.1787153,15z/data=!4m5!3m4!1s0x0:0xf77aefb4e27f865!8m2!3d41.1754796!4d-96.1787153 And even though it says it's on a Street, on the back end of the claimed listing I've used "Avenue". In case it matters, this is the landing page for the location: https://www.nebraskamed.com/chalco
Local Listings | | Patrick_at_Nebraska_Medicine0 -
SEO - Should individual doctors at facility claim a Google My Business profile?
My client is a physician facility with several doctors practicing at the facility. When doing a Google search for some of their practices such as "family practice" one of the doctor's profiles will display in the Google Local pack - however it is not linked to the facility website where their profile exists. As of right now, we are using YEXT and other tools to claim Google Business Profiles for each practice, not the individual doctors. If there are unclaimed accounts for individual doctors, they are alerting Google that it’s a duplicate and should be taken down. Is this the right process to follow for SEO best practices or should we be claiming both the business and individual doctor profiles? The reason they are not claiming individual doctor profiles is to cut down on duplicate reviews as part of the Reputation Management Program. Advice much appreciated!
Local Listings | | chrisvogel0 -
What would Cause listing to fall off local search map spot?
Any reason a listing that was showing in Google between the 3 and 5 spot on local map search would suddenly disappear all together from the map position for a specific keyword?
Local Listings | | scott3150 -
Should my website link to my google business listing given that I already link from google business to my website ?
I have a website with individual Location Landing Pages for each of my Depots. I also have individual Google Local Business Listings for each of my depots. Should I have a link from my Website Location Landing Pages to the associated Google local Business listings or not ?... Given that I already have a link on my Google Business listing to the relevant Location Page on my website. I wasn't sure whether linking both ways would be more beneficial thus enforcing things better or whether it's not needed to link both ways . thanks Pete
Local Listings | | PeteC120 -
Does anyone use Moz Local + Yext? How valuable is this for local businesses?
For brands that have a budget to pay $600 / year for valuable backlink directories, would you recommend Moz Local + Yext? I would like to hear some feedback on marketers that use Yext. Thanks,
Local Listings | | ColeLusby
Cole0 -
Bing Places for Business - Worth It?
Hey Fellow Mozzers, I am trying to determine if Bing Places for Business is worth the time and effort it takes to create listings. My business has 900 locations, and would take some time to create the bulk upload file to load into the Bing Places for Business dashboard. My question is, since Bing already does a good job of creating business listings using data from 3rd party sources such as Yelp and Citysearch, where I already have a strong presence for each of my locations, is there any value in overriding the automatically created business page for each of my location with information that I upload?
Local Listings | | dsinger2
