Schema.org snippet for thumbs up-down reviews
Hi guys,
I'm deep into the Schema.org meta-tags implementation for the reviews on my website and I'd love to know how do you think I should implement it when I have Positive-Negative reviews as opposed to star ratings. I couldn't find a site that had this with schema tags for reference. Fiverr used to have thumbs up/down, but recently changed to star rating.
On our services marketplace we allow users to review the providers they worked with and ask them for a positive-negative review - thumbs up/down with an additional open text area.
I thought about adding a schema.org meta-tags like this:
Lets assume one of our providers got two reviews, one is positive and the second is negative. So, first I thought about adding an aggregateReview meta-tag on top, just like this:
And also add a meta-tag for any review, like this:
Two days ago by
Kareem Abdul-Jabbar
Joe is a great guy, I'd recommend him to my friends.Does that make sense?
Has anyone had the chance to implement a schema.org meta tags for this kind of situation or familiar with a website who does it that way?
Thanks so much for your help!
Shaqd
I'm pretty sure it was on the product page you messaged about. Not that there is anything wrong with marking up several things on a page, but I'm just saying perhaps one of those other areas (e.g. pharmacy) is where the incomplete markup is instead of the product markup.
Thanks Everett for your help.
The HTML code is ok, you're right. It's something with how we configured the Schema.org tags.
Btw, where did you see the several different schemas?
ShaqD
Hello ShaqD,
I had a look at the code and it looks good to me, but I'm not a developer by trade. Perhaps a developer could be of more assistance.
One thing I did notice was that you have several different schemas on that page, such as one for "website" and one for "pharmacy". Is it possible that one of those is responsible for the error, or were they already on the page the last time you tested the site live without errors using the structured data testing tool?
Well, I decided to go with the approach we discussed earlier. After I pushed the changes to our live environment and tested it on Google Structured Data Testing Tool, I found a really weird (and very generic) error: "Error: Incomplete microdata with schema.org."
Any idea what could be the issue here?
Results:
Item
type: http://schema.org/review
property:
reviewrating: Item 1
datepublished: 2014-07-25
author: Massim L.
reviewbody: This is the great job made by X. You know what? I will have remix some of my previous songs too... he's so good!!!Error: Incomplete microdata with schema.org.
Item 1
type: http://schema.org/rating
property:
ratingvalue: 1
worstrating: 0
bestrating: 1Thanks.
ShaqD
LOL, well you know the Moz folks. If they bent the rules just a bit they'd have a thousand haters calling them out on it publicly by the end of the day. So they tend toward sticking with legitimate best practices and unfortunately there is no such thing at the moment that I can find for "thumbs up or down" but I think a scale of 0-1 is definitely appropriate and will bring this up to the powers that be.
Everett, I think you're right. Since I didn't find a place to get inspiration from I will try it out in the way I mentioned above with a scale of 0-1 for every review.
Btw, I'm not sure you guys noticed, but this forum includes thumbs up/down rating system.Unfortunately, they didn't implement the schema.org tags
Thanks a million.
ShaqD
I would put the scale at 0-1. The choice is binary: on or off, good or bad, thumbs up or thumbs down. If you used 1-2 even a bad review would increase the score so the worst Item could end up having the highest rating on the site if enough people voted.
I haven't implemented thumbs up or thumbs down, but I have bent the use to match the way I present data on a site. The site I did this on does have star ratings in the SERPs, which use the aggregate rating of two or more star ratings/reviews. This is pretty standard, but my problem was that I was comparing two or more totally different products, and I'm sure the aggregate rating is meant to apply only to multiple reviews of the same thing. However, that was the only way to get the stars (unless I missed something, and I hope I did) so that's what I did.
All of that is to say, don't be afraid to try it out and see what happens. You're not going to get penalized for poorly implemented schema. Unless you are grossly and obviously trying to spam Google the worst that is going to happen is you don't get the snippet in the SERPs. The problem is even if everything is perfect, that doesn't guarantee Google will display them.
Thanks Ray-pp for the quick and helpful response.
It might be a good idea to add bestRating/worstRating tags to each Review (I'm thinking whether it should be a 0/1 or 1/2 like you suggested). The thing is I need also to add an aggregateReview meta tag in addition to the reviews.
What do you think should be the values for the aggregateReview meta tags reviewCount and reviewValue than?
Hi Shaqd,
I have not personally implemented a thumbs up/down rating system, but have implemented a 5 star rating system.
Since your rating only have two values, either 1 or 2 (1 being thumbs down, 2 being thumbs up), you'll need to specify the Bestrating attribute so Google understands you only have two options.
This is because, by default, Google assumes a 5 star rating system (1-5) if the attribute is not specified.
On this page: http://schema.org/Rating you'll see how to add the bestrating attribute (bestRating)
It would be great if someone could give an example of how that looks in the SERPs too.
Can I add FAQS schema on my homepage?
Hello, can we have the FAQ code on the homepage (staff time)? we have written some questions and answers in the drop-down list on the homepage, and also add the schema code script to one tag of the page, but it does not work!
Intermediate & Advanced SEO | | fbowable0 -
JSON-LD schema markup for a category landing page
I'm working on some schema for a client and have a question regarding the use of schema for a high-level category page. This page is merely the main lander for Categories. For example: https://www.examples.com/pages/categories And all it does is list links to the three main categories (Men's, Women's, Kid's) - it's a clothing store. This is the code I have right now. In short, simply using type @Itemlist and an array that uses @ListItem. Structured Data Testing Tool returns no errors with it, but my main question is this: Is this the _correct _way to do a page like this, or are there better options? Thanks.
Intermediate & Advanced SEO | | Alces0 -
Schema types for webinars, infographics, datasheets, product videos and eBooks
Hi, I’m looking to add Schema markup to my company pages’s webinar page (recording past webinars) and data sheets, infographics, product videos, eBooks/white papers. For eBooks, I am primarily referring to a landing page with a gate to download a PDF document. I’m trying to determine the best markup type: For Webinars, I’ve seen suggestions to use “Event” type but that seems appropriate for future events, not something like a recorded webinar, which is not time-sensitive, unlike a live event. However, I see a StackOverflow forum to use http://schema.org/recordedIn for recorded webinars. For eBooks and White Papers, I see a few potential schema types: https://schema.org/DigitalDocument https://schema.org/CreativeWork http://schema.org/EBook (or https://schema.org/Book and then book format type of Ebook)
Intermediate & Advanced SEO | | WhiteHat10 -
Website Snippet Update in Search Console?
I have a company that I started working with that has an outdated and inaccurate snippet coming up. See the link below. They changed their name from DK on Pittsburgh Sports to just DK Pittsburgh Sports several years ago, but the snippet is still putting the old info, including outdated and incorrect description. I'm not seeing that title or description anywhere on the site or a schema plugin. How can we get it updated? I have updated titles, etc. for the home page, and done a Fetch to get re-indexed. Does Snippet have a different type of refresh that I can submit or edit? Thanks in advance https://g.co/kgs/qZAnAC
Intermediate & Advanced SEO | | jeremyskillings0 -
Positions dropping in SERPs after Title and Snippet change
Hi! I switched to a better title and meta description today for our page. Instead of ranking us better and displaying the new title - google let us fall from Position 10 to Position 16 (still dip laying the old title and meta description). Why is that? (I only changed it for the homepage) Cheers Marc
Intermediate & Advanced SEO | | RWW0 -
Schema markup for video playlists?
We're adding schema markup for all of our videos, but some videos exist only in a playlist (all integrated into one URL, and loaded after a javascript call). Per Google: "Make sure that your video and schema.org markup are visible without executing any JavaScript or Flash." https://support.google.com/webmasters/answer/2413309?hl=en So we know the current implementation won't work for schema markup... What's the best practice for adding schema markup for video playlists? Should we host all of these videos on individual URLs (but then they appear twice) or is there some other workaround?
Intermediate & Advanced SEO | | nicole.healthline0 -
Schema.org on Youtube iframe embed?
So I've tried scouring the internet on the proper way to markup youtube videos. I know there's the VideoObject propery but that seems to be more made for the old school embed code that looks like this: <embed width="100%" id="video-player-flash" height="100%" type="application/x-shockwave-flash" src="http://s.ytimg.com/yt/swfbin/watch_as3-vflpp9opi.swf" allowscriptaccess="always" allowfullscreen="true" bgcolor="#000000" flashvars="el=embedded&fexp=904001%2C914057%2C918000%2C910206%2C907217%2C907335%2C921602%2C919306%2C922600%2C919316%2C920704%2C912804%2C913542%2C919324%2C912706&is_html5_mobile_device=false&tabsb=1&hl=en_US&eurl=http%3A%2F%2Fwww.dial800.com%2Fblog%2Fvideos%2Fdial800-product-overview-video&iurl=http%3A%2F%2Fi4.ytimg.com%2Fvi%2Fgk1aD9UCKYA%2Fhqdefault.jpg&tspto=12000&probably_logged_in=1&tsp_buffer=10&video_id=gk1aD9UCKYA&tsp_dvrloop=50&sendtmp=1&enablejsapi=1&sk=WZy3rFIXzzhTB_BpmE1p1tTsbxMib1vIC&rel=1&playlist_module=http%3A%2F%2Fs.ytimg.com%2Fyt%2Fswfbin%2Fplaylist_module-vfl3lol2H.swf&jsapicallback=ytPlayerOnYouTubePlayerReady&playerapiid=player1&framer=http%3A%2F%2Fwww.dial800.com%2Fblog%2Fvideos%2Fdial800-product-overview-video"> Do I need to use that code or is it possible to mark it up using just the clean iframe src that youtube provides now?
Intermediate & Advanced SEO | | SirSud0 -
Schema.org and Testimonials
Does anyone know which fields and code are necessary to embed a testimonial into a page using schema.org?
Intermediate & Advanced SEO | | rarbel0
