Custom hreflang tags in WP & using with Yoast
Hi
My clients dev has added custom fields for adding hreflang tags to head of pages such as:
"Rel Type", "The URL", and "Language Code"
Am i right in thinking that until a different language/country version of the site is created these can remain empty or should they still be populated once added say with some sort of global reference or best left blank since will leave the head content global by default ?
Also how important is it to add charset to the language code ? since seems optional ?
Also this set up is on WP multi-site with Yoast and devs asked me the below:
_One thing to note is that Yoast generates its own "canonical" tags - so if _
_you are going to use hreflang tags and canonical tags then you don't need to _
_add a canonical using the custom fields I have set up - Yoast has that _
sorted._But if you are going down the route of NOT having any canonical tags - and _
_using a x-defult for the hreflang tags, I will need to try and suppress the _
_Yoast canonical tag so you can do this. Much depends on your approach and _
what you think is best.So how do i know if using canonicals or x-default, i take it best simplest to leverage Yoast and hence not add canonicals to custom fields ? Isnt x-default just for indicating language selectors/redirector not specific to 1 region? So long as havnt got those then good to proceed with Yoasts generated canonicals ?
Cheers
dan
I have a Blog In Which I am Using Google Translate, Which Can Convert the Blog into Multilanguages. Is it Suggested to use Herflang Tags in My Blog. Thanks In Advance ( Blog I Have Mention is signature)
Ashish Sharma
Thanks again really is a big help
Ive read that correct charsets are important, i take it that plugin handles that correctly ?
Do you know if plugin should work fine in WP Multisite environment with network childs domain mapped with their cctlds ?
Re: "using x-default and removing the canonical is nonsense" The dev just meant if going down route of NOT using canonicals AND using x-default in the hreflang then would need to suppress Yoast in those instances.
Re: "In my example, I used two very similar (if not the same langs), however there are things that change, but those are minimal (take as an example a car "hood", in England a "bonnet"). As those are such minimal changes, I don't think a specific version for GB is needed if you are already serving a US version (that's up to you)." Would you say the same if phrases containing these regional variations (hood vs bonnet) were on your target kw list ? Since i find that whilst Google is getting better at semantic relationships between words i think that they do need to be specifically targeted/appear in content & meta data in order to rank for them, or at least increase chances of ranking for them.
Also re your final paragraph 'car repair centers' would be a logical target kw for such a page so i would have thought it would be beneficial to create 2 versions of this page, 1 for US targeting US spelling & 1 for UK targeting UK spelling (centers vs centres), rather than 1x English to serve both UK & US audiences
Also I would have thought it would be useless showing a list of US car repair centers to UK visitors ?
Sorry for more questions, think that should be it now & thanks again
All Best
Dan
Dan,
If you have an English page that is also available on Turkish (same content but rewritten/translated) then an hreflang tag is recommended, not mandatory, but recommended. Although as you said you are already writing in Turkish and geotargeting in GWT, there are other engines too, that regardless their market share, shouldn't be overlooked.
HOWEVER, if you have a page in English not matching a Turkish page, then you don't need the hreflang in that page. The tag is only used when the same content is available on other language/location to tell engines which version they should serve.
What you mention about using x-default and removing the canonical is nonsense. Those are 2 different things and one would not interfere with the other. The plugin I recommended does not mess with Yoast, leaving the canonicals as they should be and adding the hrefland tags as specifies. Check this example on my site English and Spanish using both Yoast and the hreflang Manager plugin:
- English: http://viberagency.com/blog/6-reasons-shouldnt-put-intern-charge-companys-social-media/
- Spanish: http://es.viberagency.com/blog/6-razones-por-las-que-debes-dejar-un-pasante-cargo-de-los-medios-sociales-de-tu-empresa/
Check the source code, both have their canonicals and hreflang tags just fine. We chose to use the English version as the default, as you can see in the x-default.
The hreflang tags should be used only when the content is the same (but targeted to a different audience). Of course of the translation from one language to the other some lines must be rewritten to make sense.
In my example, I used two very similar (if not the same langs), however there are things that change, but those are minimal (take as an example a car "hood", in England a "bonnet"). As those are such minimal changes, I don't think a specific version for GB is needed if you are already serving a US version (that's up to you). In that case (1 english version to all english speakers), you only specify the language, instead of the Language and Region:
<link rel="<a class="attribute-value">alternate</a>" href="http://www.example.com" hreflang="<a class="attribute-value">en</a>"/>
Now, just to make sure we have an example that DOES apply a different GEO in en-US and en-GB, could be a page that explains what are car repair centers, plus below it shows a list of repair centers. In these scenario, the content is the same, but the list of repair centers change, you would like to display those in GB to your GB audience (still, from my point of view, useless, but was just an example).
Hope that clears it up
Hi Apog
Thanks so much for all that great info !
First of all, the main default site is for general/global targeting so have instructed dev to put on network.domain.com/en (but mapped to tld domain.com) to signify english but not be country specific - global kw research has determined USA spelling to be used predominently with just one or two UK spelt target kw).
The next stage is a Turkish geotargeted site that will be in Turkish language on our WP MS network network.domain.com/tr but mapped with a tld such as www.domain.tr which will be geotargeted in GWT. Given these other geo signals such as gwt, native language in body copy etc is hreflang even needed for such a scenario or due to hreflang is overkill/not needed ?
Re your example (US/GB): You are saying use x-default but my dev says (copied in my question) that if we want to use x-default then would have to suppress Yoast re the canonical, so any ideas how to resolve that ? Does the plugin you linked to handle hreflang without requiring Yoast to be suppressed re having x-default or not applicable since only refers to scenario where not having canonicals.
Also you say your example set up is if the contents not exactly the same, do you mean if they have substantially different content ? And your second point (below the example set up) says if they have the same content - so here do you mean if the only difference is US/vsGB versions of english language/spelling but otherwise identical ? And if our target kw include the USvsGB spelling variations then i take it the en-gb version isnt expendable after all ?
Thanks for all your help and sorry for more questions but i really need to get to the bottom of this asap
Many Thanks
Dan
thanks Kristina !
Hey Dan,
If I understood correctly, you should use both. Canonical tags are used tell search engines that the content is located on the canonical content, while hreflang points which version should be served to each visitor depending on the user's location/language.
If you Yoast, then they already handle the canonical tags and there's nothing you need to do. For the hreflang, if you have at the moment only 1 version served to all visitors, then those shouldn't be used. However, if you have 2 versions quite similar, like en-US and en-GB then you will need to choose the one that's default, let's say the US version and have the following on each version:
en-US:
- Canonical pointing to it.
- Hreflang x-default pointing to it
- Hreflang en-US pointing to it
- Hreflang en-GB pointing to en-GB version
en-GB:
- Hreflang x-default pointing to en-US
- Hreflang en-US pointing to en-US
- Hreflang en-GB pointing to it
This applies if the en-US and en-GB versions are NOT exactly the same. If the language changes (that's why you create a specific version to each country) you need a canonical in each version pointing to itself.
If the en-US and en-GB have the same contents, then the canonical should point to the en-US version (but there's no need to have the en-GB version really, which makes it useless / expendable).
As you mention that at the moment you do not have any extra langs/regions, then you could leave the tags empty or better remove them.
There's a plugin for wordpress that handles hreflang tags (paid) hreflang Manager
Hope that helps!
No need to worry about hreflang (and therefore x-default) unless you're working with international versions of your sites! If Google doesn't see anything referencing international, it will figure out the language and country from the ccTLD and the language you're using on your site. Hreflang tells Google where the international versions of a page are, it isn't necessary to designate a language and location.
Best,
Kristina
Should we set up redirects for all deleted TAGS?
We recently found our site had 65,000 tags (yes 65K). In an effort to consolidate these we've started deleting them. MOZ is now reporting a heap of 404 errors for tag pages. These tag pages should not have links to them so not sure how come they're being crawled. Any suggestions from experience in this area would be useful.
Technical SEO | | wearehappymedia0 -
Multiple H1 Tags on Page
Can having multiple H1 tags on a webpage be detrimental to its rankings?
Technical SEO | | AubbiefromAubenRealty0 -
What punctuation can you use in meta tags? Are there any Google does not like?
So I know you can use dashes and | in meta tags, but can anyone tell me what other punctuation you can use? Also, it'd be great to know what punctuation you can't use. Thanks!
Technical SEO | | Trevorneo1 -
Canonical Tag when using Ajax and PhantomJS
Hello, We have a site that is built using an AJAX application. We include the meta fragment tag in order to get a rendered page from PhantomJS. The URL that is rendered to google from PhantomJS then is www.oursite.com/?escaped_fragment= In the SERP google of course doesnt include the hashtag in the URL. So my question, with this setup, do i still need a canonical tag and if i do, would the canonical tag be the escaped fragment URL or the regular URL? Much Appreciated!
Technical SEO | | RevanaDigitalSEO0 -
Multiple H1 tags in Squarespace
Hi. I'm using Squarespace, and I've noticed they assign the page title and site title h1 tag status. So if I add an on-page h1 tag, that's three in total. I've seen what Matt Cutts said about multiple h1 tags being acceptable (although that video was back in 2009 and a lot has changed since then). But I'm still a little concerned that this is perhaps not the best way of structuring for SEO. Could anyone offer me any advice? Thanks.
Technical SEO | | The_Word_Department0 -
Isnt it better to have headlines in H1 and H2 tags instead of p tags?
I am working with a simple site http://http://lightsigns.com/Uniko_Manufacturing_Limited.html They seek more SEO traffic. However, the two big headlines that read "Wholesale Supply to the Sign and Display Industries" which is on line 241 and 242 of the source code, its in a p tag, i.e. <p <span class="webkit-html-tag">style</p <span>="padding-top: 0pt; " class="paragraph_style_1">Wholesale Supply to the and <p <span class="webkit-html-tag">style</p <span>="padding-bottom: 0pt; " class="paragraph_style_1">Sign and Display Industries Likewise, the product titles are in p tags, also. For example, on the Slide-in Light Box product page, http://lightsigns.com/Slide_In_light_box.html , I have done keyword research and no one is using the words slide in light box.Plus, it is also a p tag, ie. line 43 reads style="padding-bottom: 0pt; padding-top: 0pt; " class="paragraph_style">Slide-in Light Box If I suggest that they make an H2 tag with SEO-optimized keywords such as Display Light Box - Slide-In LIght Box, would this indeed help SEO? In summary, is it correct to say that H1 and H2 tags are stronger signals to the search bots of what the page is about?
Technical SEO | | BridgetGibbons1 -
MBG Tracker...how to use it?
So I am a new blogger that has been submitting guest blog posts to a number of different blogs. It was recommended that I use the MBG Tracker so I can track the back links. The problem is that I am totally lost on how to use this tool. As I said before I am new to this whole thing and I am not really sure what constitutes a "base link" and a "back link." In the author bylines we are linking to different pages within a larger website. If anyone can help me I would really appreciate it!
Technical SEO | | Stroll0
