Block in robots.txt instead of using canonical?
When I use a canonical tag for pages that are variations of the same page, it basically means that I don't want Google to index this page. But at the same time, spiders will go ahead and crawl the page. Isn't this a waste of my crawl budget? Wouldn't it be better to just disallow the page in robots.txt and let Google focus on crawling the pages that I do want indexed?
In other words, why should I ever use rel=canonical as opposed to simply disallowing in robots.txt?
With this info, I would go with Robots.txt because, as you say, it outweighs any potential loss given the use of the pages and the absence of links.
Thanks Robert.
The pages that I'm talking about disallowing do not have rank or links. They are sub-pages of a profile page. If anything, the main page will be linked to, not the sub-pages.
Maybe I should have explained that I'm talking about a large site - around 400K pages. More than 1,000 new pages are created per week. That's why I am concerned about managing crawl budget. The pages that I'm referring to are not linked to anywhere on the site. Sure, Google can potentially get to them if someone decides to link to them on their own site, but this is unlikely and certainly won't happen on a large scale. So I'm not really concerned about about losing pagerank on the main profile page if I disallow them. To be clear: we have many thousands of pages with content that we want to rank. The pages I'm talking about are not important in those terms.
So it's really a question of balance... if these pages (there are MANY of them) are included in the crawl (and in our sitemap), potentially it's a real waste of crawl budget. Doesn't this outweigh the minuscule, far-fetched potential loss?
I understand that Google designed rel=canonical for this scenario, but that does not mean that it's necessarily the best way to go considering the other options.
Thanks Takeshi.
Maybe I should have explained that I'm talking about a large site - around 400K pages. More than 1,000 new pages are created per week. That's why I am concerned about managing crawl budget. The pages that I'm referring to are not linked to anywhere on the site. Sure, Google can potentially get to them if someone decides to link to them on their own site, but this is unlikely (since it's a sub-page of the main profile page, which is where people would naturally link to) and certainly won't happen on a large scale. So I'm not really concerned about about link-juice evaporation. According to AJ Kohn here, it's not enough to see in Webmaster Tools that Google has indexed all pages on our site. There is also the issue of how often pages are being crawled, which is what we are trying to optimize for.
Would love to hear your thoughts...
I would go with the canonicals. If there are any links going to these duplicate pages, that will prevent any "link juice evaporation" from links which Google can see but can't crawl due to robots.txt. Best to let Google just crawl the page and see the canonical so that it understands that it is a duplicate page.
Having canonicals on all your pages is good practice anyway, as it can prevent inadvertent duplicate content from things like query parameters.
Crawl budget can be of some concern if you're talking about a massive number of pages, but start by first taking a look at Google Webmaster Tools and seeing how many of your pages are being crawled vs the total number of pages on your site. As long as this ration isn't small, you should be good. You can also get more crawl budget by building up your domain authority by building links.
I don't disagree at all and I think AJ Kohn is a rock star. In SEO, I have learned over time that there are rarely absolutes like always do this or never do that. I based my answer on how you posited the question.
If you read AJ's post you will note that the rel=canonical issue comes up with others commenting and not in the body of his post. Yes, if the page is superfluous like a cart page or a contact page, use the robots.txt to block the crawl. But, if you have a page with rank, links, etc. that help your canonical page, how are you helping yourself by forgoing rel=canon?
I think his bigger point was that you want to be aware and to understand that the # of times you are crawled is at least partially governed by PR which is governed by all those other things we discussed. If you understand that and keep the crawl focused on better pages you help yourself.
Does that clarify a bit?
Best -
Hi, even if you use robots.txt file to block these pages, Google can still pick the references of these pages from third-party websites and can crawl from there. Such pages will not have the description snippet in the search results and instead will show text that reads:
A description of this result is not available because of this site's robots.txt.
So, to fully stop Google from crawling these pages, you can go in for the page-level meta robots tag along with the robots.txt method. The page-level robots meta tag complements robots.txt method.By the way, robots.txt file can definitely save you some crawl budget. I don't think you should be thinking much about crawl budget though, as long as your website is super-easy to crawl with simple text-based internal links and stuff like, super-fast servers etc.,
Those my my two cents my friend.
Best regards,
Devanur Rafi
Thanks for the response, Robert.
I have read lots of SEO advice on maximizing your "crawl budget" - making sure your internal link system is built well to send the bots to the right pages. According to my research, since bots only spend a certain amount of time on your site when they are crawling, it is important to do whatever you can to ensure that they don't "waste time" on pages that are not important for SEO. Just as one example, see this post from AJ Kohn.
Do you disagree with this whole approach?
Yair
I think that the canonical is the better option. I am unsure as to your use of the term "crawl budget," in that there is no fixed number of times a page or a site will be crawled versus a second similar site for example. I have a huge reference site that is crawled every couple of days and I have small sites of ten pages that are crawled weekly or less. It is dependent on the traffic and behaviors of that traffic (which would include number of inbound links, etc.) and on things like you re-submitting sitemap, etc.
The canonical tag was created to provide the clarification to the search engine as to what you considered to be the relevant page. Go ahead and use it.Best
Robert
Canonical and Alternate Advice
At the moment for most of our sites, we have both a desktop and mobile version of our sites. They both show the same content and use the same URL structure as each other. The server determines whether if you're visiting from either device and displays the relevant version of the site. We are in a predicament of how to properly use the canonical and alternate rel tags. Currently we have a canonical on mobile and alternate on desktop, both of which have the same URL because both mobile and desktop use the same as explained in the first paragraph. Would the way of us doing it at the moment be correct?
Intermediate & Advanced SEO | | JH_OffLimits3 -
Homepage appearing instead of subpage
Hi, I have my homepage which has links saying "bike tours and bike tours in France" because in the past I was only doing bike tours in France. I now do tours all over Europe and I have a page about "bike tours in Franc" only. The issue I have is that my page about "bike tours in France" never appears in the search ranking it is always my homepage that does for tjhe keyword "bike tours in France". My guess is that it is due to the links that my homepage has ? How could I make sure my France page appears instead of my homepage ? Thank you,
Intermediate & Advanced SEO | | seoanalytics0 -
Canonical Chain
This is quite advanced so maybe Rand can give me an answer? I often have seen questions surrounding a 301 chain where only 85% of the link juice is passed on to the first target and 85% of that to the next one, up to three targets. But how about a canonical chain? What do I mean by this:? I have a client who sells lighting so I will use a real example (sans domain) I don't want 'new-product' pages appearing in SERPS. They dilute link equity for the categories they replicate and often contain identical products to the main categories and subcategories. I don't want to no index them all together I'd rather tell Google they are the same as the higher category/sub category. (discussion whether a noindex/follow tag would be better?) If I canonicalize new-products/ceiling-lights-c1/kitchen-lighting-c17/kitchen-ceiling-lights-c217 to /ceiling-lights-c1/kitchen-lighting-c17/kitchen-ceiling-lights-c217 I then subsequently discover that everything in kitchen-ceiling-lights-c217 is already in /kitchen-lighting-c17 and I decide to canonicalize those two - so I place a /kitchen-lighting-c17 canonical on /kitchen-ceiling-lights-c217. Then what happens to the new-products canonical? Is it the same rule - does it pass 85% of link equity back to the non new-product URL and 85% of that back to the category? does it just not work? or should I do noindexi/follow Now before you jump in: Let's assume these are done over a period of time because the obvious answer is: Canonicalize both back to /ceiling-lights-c1/kitchen-lighting-c17 I know that and that is not what I am asking. What if they are done in a sequence what is the real result? I don't want to patronise anyone but please read this carefully before giving an answer. Regards Nigel Carousel Projects.
Intermediate & Advanced SEO | | Nigel_Carr0 -
Large robots.txt file
We're looking at potentially creating a robots.txt with 1450 lines in it. This will remove 100k+ pages from the crawl that are all old pages (I know, the ideal would be to delete/noindex but not viable unfortunately) Now the issue i'm thinking is that a large robots.txt will either stop the robots.txt from being followed or will slow our crawl rate down. Does anybody have any experience with a robots.txt of that size?
Intermediate & Advanced SEO | | ThomasHarvey0 -
Should I disallow all URL query strings/parameters in Robots.txt?
Webmaster Tools correctly identifies the query strings/parameters used in my URLs, but still reports duplicate title tags and meta descriptions for the original URL and the versions with parameters. For example, Webmaster Tools would report duplicates for the following URLs, despite it correctly identifying the "cat_id" and "kw" parameters: /Mulligan-Practitioner-CD-ROM
Intermediate & Advanced SEO | | jmorehouse
/Mulligan-Practitioner-CD-ROM?cat_id=87
/Mulligan-Practitioner-CD-ROM?kw=CROM Additionally, theses pages have self-referential canonical tags, so I would think I'd be covered, but I recently read that another Mozzer saw a great improvement after disallowing all query/parameter URLs, despite Webmaster Tools not reporting any errors. As I see it, I have two options: Manually tell Google that these parameters have no effect on page content via the URL Parameters section in Webmaster Tools (in case Google is unable to automatically detect this, and I am being penalized as a result). Add "Disallow: *?" to hide all query/parameter URLs from Google. My concern here is that most backlinks include the parameters, and in some cases these parameter URLs outrank the original. Any thoughts?0 -
"noindex, follow" or "robots.txt" for thin content pages
Does anyone have any testing evidence what is better to use for pages with thin content, yet important pages to keep on a website? I am referring to content shared across multiple websites (such as e-commerce, real estate etc). Imagine a website with 300 high quality pages indexed and 5,000 thin product type pages, which are pages that would not generate relevant search traffic. Question goes: Does the interlinking value achieved by "noindex, follow" outweigh the negative of Google having to crawl all those "noindex" pages? With robots.txt one has Google's crawling focus on just the important pages that are indexed and that may give ranking a boost. Any experiments with insight to this would be great. I do get the story about "make the pages unique", "get customer reviews and comments" etc....but the above question is the important question here.
Intermediate & Advanced SEO | | khi50 -
Lowercase VS. Uppercase Canonical tags?
Hi MOZ, I was hoping that someone could help shed some light on an issue I'm having with URL structure and the canonical tag. The company I work for is a distributor of electrical products and our E-commerce site is structured so that our URL's (specifically, our product detail page URL's) include a portion (the part #) that is all uppercase (e.g: buy/OEL-Worldwide-Industries/AFW-PG-10-10). The issue is that we have just recently included a canonical tag in all of our product detail pages and the programmer that worked on this project has every canonical tag in lowercase instead of uppercase. Now, in GWT, I'm seeing over 20,000-25,000 "duplicate title tags" or "duplicate descriptions". Is this an issue? Could this issue be resolved by simply changing the canonical tag to reflect the uppercase URL's? I'm not too well versed in canonical tags and would love a little insight. Thanks!
Intermediate & Advanced SEO | | GalcoIndustrial0 -
Set up a rel canonical
I have a question. I was wondering, if it was possible to set up a rel canonical. When I can't access the non canonical pages? For example, my site as at www.site.com , but the non cannocail is at site.com is their any way to set thet up without actually edting it at site.com ? Thanks for your help
Intermediate & Advanced SEO | | PeterRota0
