Do H2 tags carry more weight than h4 tags?
Of course H tags are key signals for relevance in search. Does an h2 tag send a significantly "louder" signal than an h4 tag?
Hi There
It's questionable how much weight H tags carry at all. If they carry any, it's probably really small, or relative to how easy the keyword and industry is. H1's may help a bit more than all others - but when you start getting into H2's vs H4's it's splitting really thin hairs.
This is the best resource on H tags and SEO I know of: http://www.seobythesea.com/2012/01/heading-elements-and-the-folly-of-seo-expert-ranking-lists/
Consider it this way:
H tags, in a perfect world, would always descend sequentially as content became more specific. So, the H1 and H2 would be more general than an H3 or H4. Also, those H3s and H4s should be inside of the H2s and H1s. This set up allows for more general "head" keywords in the larger H tags, and more specific information that supports the larger H tags to go in the lower H tags. This means you're target area should be in the largest H tag possible, with all subsequent H tags in the list supporting your main headline with proper content. I hope that makes sense.
So, yes. H2 > H4.
Optimal use of keywords in header tag
what does optimal use of keywords in header tag actually mean given you indicate this as hurting seo factor?
Technical SEO | | Serg1550 -
Can a H1 Tag Have Multiple Spans Within It?
H1 tags on my client's website follow the template [Service] + [Location]. These two have their own span, meaning there are two spans in an H1 tag. class="what">Truck Repair near class="where">California, CA How do crawl bots see this? Is that okay for SEO?
Technical SEO | | kevinpark1910 -
Do you need a canonical tag for search and filter pages?
Hi Moz Community, We've been implementing new canonical tags for our category pages but I have a question about pages that are found via search and our filtering options. Would we still need a canonical tag for pages that show up in search + a filter option if it only lists one page of items? Example below. www.uncommongoods.com/search.html/find/?q=dog&exclusive=1 Thanks!
Technical SEO | | znotes0 -
Bing webmaster tools incorrectly showing missing title and description tags
Hey all, Was wondering if anyone else has come across this issue. Bing is showing title and description tags missing in the head of my wordpress blog. I can't seem to find any documentation on this. Thanks, Roman
Technical SEO | | Dynata_panel_marketing0 -
What punctuation can you use in meta tags? Are there any Google does not like?
So I know you can use dashes and | in meta tags, but can anyone tell me what other punctuation you can use? Also, it'd be great to know what punctuation you can't use. Thanks!
Technical SEO | | Trevorneo1 -
Does the rel="bookmark" tag have any SEO impication?
I'm assuming the rel="bookmark" tag doesn't have any SEO implications but I just wanted to make sure it wasn't viewed like a nofollow by search engines.
Technical SEO | | eli.boda0 -
Content loc and player log tags for XML video site maps
I need a little help understanding how to create two of the required tags for a XML video site map for Google. 1. video:content_loc2.<video:player_loc< p=""></video:player_loc<></video:content_loc> Google explains their Video XML Site map requirements here:
Technical SEO | | dsexton10
www.google.com/support/webmasters/bin/answer.py?answer=80472
Using the example on this Google Web Master Help page (where they explain all six of the required tags) , here are examples of the two tags I need help with: video:content_locwww.example.com/video123.flv</video:content_loc> <video:player_loc allow_embed="yes" autoplay="ap=1">www.example.com/videoplayer.swf?video=12...video:player_loc></video:player_loc> The video I am trying to optimize is located on a page on my site:
www.mountainbikingmaine.com/races/bradbury_hawk.html
This page has an embedded Vimeo video. So I don't have the video file on my domain. It is on Vimeo. Here is source code from my page that I think provides the information I need to create the two tags that Google requires. <iframe src="<a rel=" nofollow"="" href="http://player.vimeo.com/video/24580638?title=0&byline=0&portrait=0"" target="_blank">player.vimeo.com/video/24580638?title=0&...amp;portrait=0"</a> width="400" height="533" frameborder="0"></iframe> [vimeo.com/24580638">Bradbury](<a rel=) Mountain Maine Hawk Migration Count from [vimeo.com/user3219915">dan](<a rel=) sexton Using this source from my site, can you suggest what to put in the two tags? Thanks! Dan0 -
Use of Meta Tag - MSSmartTagsPreventParsing
We've inherited some sites from another developer that had the following tag: All references I can find to it are from 2004. What is the purpose and is it worth including in pages/sites we build?
Technical SEO | | wcksmith0
