2 phone numbers in our SERP snippet are incorrect. How do I fix it?
At the special rich snippet at the top of the SERP, we have 5 phone numbers, but 2 of them are for something specific and need to be removed. Do you know how to do this?
I've looked up the 2 phone numbers and they appear to only be on PDF documents.
Any ideas?
If you find that the other mentions of the phone numbers are on directory sites like DMOZ (which can take along time to get edits) you can add this code to the head section of the homepage:
Hi Mike,
If the numbers exist anywhere, Google can decide to pull them. You should search Google for the existence of these phone numbers anywhere on the web (just to be sure they're not only in the PDFs) and then remove those numbers if having them pulled by Google in this manner is having a negative enough impact. Eventually, you should see them drop off.
Are the pdf documents controlled by you? Can you edit them?
its hard to say what might be causing it without looking at the site. My best guess would be to see if its being pulled form any old G+ Local pages or schema.org markup on the site.
Incorrect Image is Displaying on Google My Business Knowledge Graph - Need Urgent Solution??
Incorrect Image is Displaying on Google My Business for our company. We have updated new image on google business But still, Google is fetching and showing old image on the google my business knowledge panel. What will be the right fix for this? Our site URL : www.yolobus.in
Local Listings | | AnkitS.19900 -
How do you fix a Google My Business Location Issue if the road doesn't yet exist on Google Maps?
My core question is just: How do you fix a Google My Business Location Issue if the road doesn't yet exist on Google Maps? Do I have any other options other than to just wait on Google to catch up with reality? Here's the background: I work for a hospital. We just opened a clinic on a street that is real and has a U.S. Postal Address, but Google Maps doesn't recognize it, and redirects people to a house . This is our postal address: 8343 S 168th Ave Omaha NE 68136-1677 If a patient enters the following into google maps, 8343 S 168th Ave, the location the map autofills the wrong zip code, and sends them to a home that is on S 168th Ave. (where in theory a home would exist if it had that home number). The road does exist in that portion of town. If a patient enters 8343 S 168th Ave, Omaha NE 68136, google maps takes you to the correct location, but it automatically changes Ave to St. The verified Google My Business listing also lists it as Street, even though on the back end I've put in the word Avenue, and it shows up in the right place. If however someone just searches by name "Chalco Clinic" the right Google My Business comes up. This is the Google My Business page I'm referring to: https://www.google.com/maps/place/Nebraska+Medicine+-+Chalco/@41.1754796,-96.1787153,15z/data=!4m5!3m4!1s0x0:0xf77aefb4e27f865!8m2!3d41.1754796!4d-96.1787153 And even though it says it's on a Street, on the back end of the claimed listing I've used "Avenue". In case it matters, this is the landing page for the location: https://www.nebraskamed.com/chalco
Local Listings | | Patrick_at_Nebraska_Medicine0 -
How will changing the phone number on my website affect SEO?
We are considering changing the phone number to our website to one of those 1-800-eat-cows. How will changing a phone number we've had 10 years affect our SEO. Do we need to change all citations, Google maps, etc etc? What if we don't? Thanks!
Local Listings | | RoxBrock0 -
Different Phone Numbers in GMB/onsite
Hello All! I have an issue. I have a local business with multiple addresses, In order to start doing some conversion optimization I need to know where are the leads coming from, my assumption is that part of the leads come from phone calls directly from the google my business listing that appears in the local pack and some come from the website itself. Here's where the problem lays, I cannot understand how many calls come from each platform, Google My Business analytics provides a very high number that doesn't fit with my reports (i have a CRM that can track calls), the numbers are inflated in hundreds of %. The solution i thought of was implementing a different phone number in my website to track the leads, the problem is the NAP, which will be different. Another solution I thought of was implementing an additional phone number in Google My Business, and adding that additional phone number to the local landing page, displaying the new phone number as the main number on the page and leaving the old number in the schema markup. Does this solution seems fit? do you have another suggestion?
Local Listings | | OrendaLtd0 -
How to deal with wrong location in Google SERP
Hi, If I understand correctly, Google provides search results based on the location of the user. That's fine, because most of my clients are local. But if I look at my own search results, Google thinks I'm in a totally different town. Most likely based on my IP address. Of course I can solve that for myself, but the same goes for my potential clients. Is there a way to deal with this, from an seo perspective? For instance find out where most of the the IP providers are located and target that location?
Local Listings | | Houdoe1 -
Why is the incorrect city name being appended to search results when that search is done from a completely different city? Screenshot Included
Hi Guys, This is weird. When searching "generator rentals" from within Vancouver/Lower Mainland and on a mobile device, our organic listing is ranked #1. That is the good news. The bad news is that for some reason the title returend is: Generator Rentals & Temporary Power Distribution - Edmonton". The "-Edmonton" is dynamically added, but I have no idea why. Edmonton is in a completely different province than Vancouver... over 720 miles apart. The only thing I can think of is that there is some sort conflict with our Google places account. You see, we do have an Edmonton branch. I have setup two branches... one for the Coquitlam/Vancouver branch and one for the Edmonton. And as far as I can tell, both are setup correctly. A screenshot from my iPhone has been linked (http://imgur.com/9YvyLDB). Any ideas would be appreciated. Thank you, Jarrett 9YvyLDB
Local Listings | | TrinityPower0 -
NPA. Adding two new locations. What phone numbers to use?
Hi everyone, Our client wants to add two new locations. Not sure what phone number to use.
Local Listings | | Ryan_V
We have main phone 800 number, with no adders associated, and local phone numbers for locations which we do SEO for. New two locations are not for SEO purposes. Client just want them to be listed on website and on major directories for now. Understanding NPA importance:
Should we use main 800 for both locations?
Should we get new phone numbers for each one? Thanks0 -
2 Businesses + Same Address = Not a Problem?
Imagine someone who has 2 separate businesses with the same (home) address. Both are verified Google My Business G+ pages, each with its own separate website. Essentially the old business that is being de-emphasized is a guitar lesson teacher's studio. This G+ page is set as a storefront where people come to. The new business is similar, it is music lessons (private in-home instruction). This G+ page is set to have a service area - this goes along with their new business model. We all know that consistent NAP is essential BUT do you think these are competing against each other because they share an address even though the businesses are separate?
Local Listings | | Rich_Coffman0
