Using a lot of "Read More" Hidden text
My site has a LOT of "read more" and when a user click they will see a lot of text. "read more" is dark blue bold and clear to the user. It is the perfect for the user experience, since right below I have pictures and videos which is what most users want.
Question: I expect few users will click "Read more" (however, some users will appreciate chance to read and learn more) and I wonder if search engines may think I am hiding text and this is a risky approach or simply discount the text as having zero value from an SEO perspective?
Or, equally important: If the text was NOT hidden with a "Read more" would the text actually carry more SEO value than if it is hidden under a "read more" even though users will NOT read the text anyway? If yes, reason may be: when the text is not hidden, search engines cannot see that users are not reading it and the text carry more weight from an SEO perspective than pages where text is hidden under a "Read more" where users rarely click "read more".
Hi khi5
I analyzed your page. You are doing just fine. you are using CSS display none. You are not doing any cloaking.
You are doing the right thing.
1. not fooling google
2.not fooling user
3.giving the user a better user experience.
Don't worry you are not applying any "black hat" technique. You will not get penalized.
thx. Anirban. I am not a programmer, so would you be able to tell me if this approach seems right: http://www.honoluluhi5.com/oahu/honolulu-condos/ - I don't know if css or display none.
I can't think of a better layout for that page and hiding text the way I have done it is ideal for users. If I show more text, surely bounce rate would go up!
It used by many huge sites is to pre-load code, navigation, or content in the background so that it can be dynamically displayed as needed. The most common technique for accomplishing this is through the use of the CSS display: none attribute.
Unfortunately, you can also use display: none to simply hide text. This is where the perceived problem comes in. People worry that the use of display: none to hide content(and show when user asks for it) or for code that is really meant for screen readers can lead them into trouble. The legitimate use of this technique is so prevalent that I would rarely expect search engines to penalize a site for using the display: none attribute. It’s just very difficult to implement an algorithm that could truly ferret out whether the particular use of display: none is meant to deceive the search engines or not.
I usually use this tactics to make the page more user friendly and it is useful for the user too. User don't get bombarded by a large content piece and I am not fooling the user/google. I am giving the option to the user to read more if he wants to.
"display: none"
What it does :- the functionality is same - when user clicks "read more" it opens and when user click "less" it closes.
How it defeats the "cloaking" idea:- When google crawls your page where the full content is there (text based browser, not java enabled) and when user sees the page there is a "read more" link and by clicking it it shows the full content. So you are not showing two different things to google & user. it solves the problem.there shouldn't be a a cloaking problem. Its tested.
Hope this helps...
Also refer :- http://cloudz.click/community/q/would-using-display-none-to-hide-a-section-of-text-effect-seo-negatively
Wow -- thanks for the links! I learn something new every day.
I'll defer to others on your specific question since I haven't ever worked with sites that specifically do what you do. I hope someone will give you a good answer!
http://searchengineland.com/googles-matt-cutts-on-hidden-text-using-expandable-sections-youll-be-in-good-shape-167753 - this is a more Matt Cutts video and more relevant, which again mentions it is OK to use those read more.
Again, my bigger concern is if it is OK, or I am probably safer off showing all text if possible….
thx, Sam. Here is a video from Matt Cutts: https://www.youtube.com/watch?v=UpK1VGJN4XY - it appears Google is OK with hidden text that makes sense for user.
For my site I have a lot of read more types like here:
http://www.honoluluhi5.com/oahu-condos/
http://www.honoluluhi5.com/oahu/honolulu-city-real-estate/As you can see from those 2 links, I have created with only the user in mind and nothing else. In order to play it safe, maybe I should just show all the text somehow, even though it compromises user experience.
The answer to your question lies in another question: Do search engines see one thing and users see another? If the answer is "yes," then you are using "cloaking" -- which is a very bad black-hat SEO technique. It can get you penalized and possibly banned.
Users don't see the text if they don't click "read more" but search engines will see the text either way? That's cloaking. I'd stop doing this right away.
Are "Powered By..." type footer backlinks good or bad for SEO?
Hi guys, We're running a software company which is also selling WP themes amongst other things. We've heard recently that footer backlinks like "Powered by BigBangThemes" might do more harm than good. Some clients usually forget to change them - so we want to make sure we stop including them in case this is true. Thanks!
Intermediate & Advanced SEO | | andy.bigbangthemes0 -
Are HTML Sitemaps Still Effective With "Noindex, Follow"?
A site we're working on has hundreds of thousands of inventory pages that are generally "orphaned" pages. To reach them, you need to do a lot of faceting on the search results page. They appear in our XML sitemaps as well, but I'd still consider these orphan pages. To assist with crawling and indexation, we'd like to create HTML sitemaps to link to these pages. Due to the nature (and categorization) of these products, this would mean we'll be creating thousands of individual HTML sitemap pages, which we're hesitant to put into the index. Would the sitemaps still be effective if we add a noindex, follow meta tag? Does this indicate lower quality content in some way, or will it make no difference in how search engines will handle the links therein?
Intermediate & Advanced SEO | | mothner0 -
"sex" in non-adult domain name
I have a client with a domain that has "sex" in the domain name. For example, electronicsexpo.com. The domain ranks for a few keywords related to the services offered. It is an old domain that has been online for over 10 years. It ranks well for local keywords. No real SEO effort has been made on this domain, so it is rather a clean slate. I am going to be doing SEO on this site. Will the fact that the word "sex" exists in the name have any sort of negative consequence. There is ABSOLUTELY NOTHING adult related or pornographic on this site. I would think that search engines are sophisticated enough to differentiate, but would potential customers with things like parental filters be blocked from viewing content? Is this hurtful in anyway? If so, would I be better off changing domain names? TIA
Intermediate & Advanced SEO | | inhouseseo0 -
Why is "Noindex" better than a "Canonical" for Pagination?
"Noindex" is a suggested pagination technique here: http://searchengineland.com/the-latest-greatest-on-seo-pagination-114284, and everyone seems to agree that you shouldn't canonicalize all pages in a series to the first page, but I'd love if someone can explain why "noindex" is better than a canonical?
Intermediate & Advanced SEO | | nicole.healthline0 -
After reading of Google's so called "over-optimization" penalty, is there a penalty for changing title tags too frequently?
In other words, does title tag change frequency hurt SEO ? After changing my title tags, I have noticed a steep decline in impressions, but an increase in CTR and rankings. I'd like to once again change the title tags to try and regain impressions. Is there any penalty for changing title tags too often? From SEO forums online, there seems to be a bit of confusion on this subject...
Intermediate & Advanced SEO | | Felix_LLC0 -
Pipe ("|") in my website's title is being replaced with ":" in Google results
Hi , One of the websites I'm promoting and working on is www.pau-brasil.co.il.
Intermediate & Advanced SEO | | Kadel
It's wordpress-based website and as you can see the html's Title is "PauBrasil | some hebrew slogan".
(Screenshot: http://i.imgur.com/2f80EEY.gif)
When I'm searching for "PauBrasil" (Which is the brand's name) , one of the results google shows is "PauBrasil: Some Hebrew Slogan" (Screenshot: http://i.imgur.com/eJxNHrO.gif ) Why does the pipe is being replaced with ":" ?
And not just that , as you can see there's a "blank space" missing between the the ":" to the slogan.
(note: the websites has been indexed by google crawler at least 4 times so I find it hard to believe it can be the reason) I've keep on looking and found out that there's another page in that website with the exact same title
but when I'm looking for it in google , it shows the title as it really is , with pipe. ("|").
(Screenshot: http://i.imgur.com/dtsbZV2.gif) Have you ever encountered something like that?
Can it be that the duplicated title cause that weird "replacement"? Thanks in advance,
Kadel0 -
Is it ok to use both 301 redirect and rel="canonical' at the same time?
Hi everyone, I'm sorry if this has been asked before. I just wasn't able to find a response in previous questions. To fix the problems in our website regarding duplication I have the possibility to set up 301's and, at the same time, modify our CMS so that it automatically sets a rel="canonical" tag for every page that is generated. Would it be a problem to have both methods set up? Is it a problem to have a on a page that is redirecting to another one? Is it advisable to have a rel="canonical" tag on every single page? Thanks for reading!
Intermediate & Advanced SEO | | SDLOnlineChannel0 -
How long is it safe to use a 302 redirect?
Hi All, Lets assume there is site A and site B, both sites are live on the internet today as standalone businesses, but they sell very similar products. Site B has built up some link equity and will eventually become the domain for site A due to an organisational re-brand. For the time being however site A will remain, but site B needs to disappear temporarily, but not lose the link equity which has been built up against it. My current thinking is to 302 redirect site B to site A such that users and search bots accessing site B will be redirected to site A whilst leaving the link equity that exists against site B fully intact and allowing us to continue to grow it should we wish to. The question is, does anybody have a view on how long it is safe to use a 302 temporary redirect for? i.e., is 8-10 months to long. Thanks, Ben
Intermediate & Advanced SEO | | BenRush0
