Best way to noindex long dynamic urls?
I just got a Mozcrawl back and see lots of errors for overly dynamic urls. The site is a villa rental site that gives users the ability to search by bedroom, amenities, price, etc, so I'm wondering what the best way to keep these types of dynamically generated pages with urls like /property-search-page/?location=any&status=any&type=any&bedrooms=9&bathrooms=any&min-price=any&max-price=any from indexing.
Any assistance will be greatly appreciated : )
If you have a page that lists all the villas outside the search results, then you don't lose anything by blocking that folder on the robots.txt
But still, somebody, the guy that wrote the custom theme knows how to do the changes needed.
If you want I can help you with it, for free
Just PM me (I'll need FTP access).
Having some trouble... Because the site is Wordpress, which dynamically generates pages, there is no /property-search-page/ nor is there a property-search-page.php in the editor files, so the only option I have is to put disallow: /property-search-page/ in the robots.txt file, correct?
You guys rock! I'll try these out tomorrow. Thanks a million.
If you have a /all-villas/ page then you should go ahead and noindex the search results as Google Guidelines suggests. You can either do it in the /property-search-page/ or using the robots.txt file.
In the robots.txt, add:
The robots method guarantees that no page inside that folder is indexed or even crawled (including /property-search-page/?whatever).
Or on the page /property-search-page/ you can add the meta noindex as such:
Then check if that meta tag is shown in all search results (just check a couple of them).
Hope that works!
Yes, it will. Also looks like custom code, it depends on how the header is coded. But it should work. Test it, if you can. This should solve your problems relatively easily. If nothing works, you can always do a robots.txt deny for /property-search-page/?* pages, but that's not a recommended solution. Try the canonical way to see if it works first.
We already have Yoast installed, but the errors are still showing up in the Moz report.
To clarify, let's assume we have another page that lists all the villas (/all-villas/). If I go to the property-search-page php file and canonical=rel it to /all-villas/, will it canonical=rel all /property-search-page/?whatever pages to the /all-villas/ page?
Well, that will make a little easier from one side and harder from the other.
You can try installing SEO by Yoast, that will put all the canonical tags for you, however, I think it won't link the search result pages to the canonical page that lists them all.
That might require a little coding.
If there's another page, outside /property-search-page/ folder that lists all villas, then you can disallow that folder in the robots.txt file, and that should fix it. If there isn't, well, then you will need to edit the /property-search-page/ page to use a static canonical tag that points to the page that lists all the villas removing any kind of filtering.
Hope that helps!
Thanks for the response. The site is Wordpress - is there an easy way to write some sort of rule that would canonical any of these types of pages to a category page? How would you go about doing that?
I agree with Federico one hundred percent. Figure out what your primary SEO friendly URLs are for these kinds of pages and canonical them back to that page.
I wouldn't put a noindex meta on them, instead I would consider using a canonical tag pointing to the page that lists all the villas.
Anyway, what programming language are you using?
Best way to link to multiple location pages
I am a Magician and have multiple location pages for each county I cover. I currently have them linked off the menu under locations/ <county>and also in the footer</county> However I have heard that a link from the page is much stronger, so I am experimenting with removing the Menu & Footer link and just linking to these pages from within the content. It's not really a navigation item and most people come in through search to the right page. Am I diluting the link by having it in the Menu/Page and Footer? I read a long time ago that Google only considers the first link to a page and ignores the rest - is that the case? Thanks Roger https://www.rogerlapin.co.uk/
Technical SEO | | Rogerperk0 -
Robots.txt Syntax for Dynamic URLs
I want to Disallow certain dynamic pages in robots.txt and am unsure of the proper syntax. The pages I want to disallow all include the string ?Page= Which is the proper syntax?
Technical SEO | | btreloar
Disallow: ?Page=
Disallow: ?Page=*
Disallow: ?Page=
Or something else?0 -
Best way to handle pages with iframes that I don't want indexed? Noindex in the header?
I am doing a bit of SEO work for a friend, and the situation is the following: The site is a place to discuss articles on the web. When clicking on a link that has been posted, it sends the user to a URL on the main site that is URL.com/article/view. This page has a large iframe that contains the article itself, and a small bar at the top containing the article with various links to get back to the original site. I'd like to make sure that the comment pages (URL.com/article) are indexed instead of all of the URL.com/article/view pages, which won't really do much for SEO. However, all of these pages are indexed. What would be the best approach to make sure the iframe pages aren't indexed? My intuition is to just have a "noindex" in the header of those pages, and just make sure that the conversation pages themselves are properly linked throughout the site, so that they get indexed properly. Does this seem right? Thanks for the help...
Technical SEO | | jim_shook0 -
Best URL format for pagination
We're currently changing the URL format of our website search, we have been discussing a lot and cannot decide the past way to pass the pagination parameter for SEO. We narrowed down to the options. www.website.com/apples/p2 - www.website.com/apples?page=2 - www.website.com/apples/page/2 What would give us best ranking returns? What do you think?
Technical SEO | | HelpSaude0 -
URLs in Greek, Greeklish or English? What is the best way to get great ranking?
Hello all, I am Greek and I have a quite strange question for you. Greek characters are generally recognized as special characters and need to have UTF-8 encoding. The question is about the URLs of Greek websites. According the advice of Google webmasters blog we should never put the raw greek characters into the URL of a link. We always should use the encoded version if we decide to have Greek characters and encode them or just use latin characters in the URL. Having Greek characters un-encoded could likely cause technical difficulties with some services, e.g. search engines or other url-processing web pages. To give you an example let's look at A) http://el.wikipedia.org/wiki/%CE%95%CE%BB%CE%B2%CE%B5%CF%84%CE%AF%CE%B1which is the URL with the encoded Greek characters and it shows up in the browser asB) http://el.wikipedia.org/wiki/Ελβετία The problem with A is that everytime we need to copy the URL and paste it somewhere (in an email, in a social bookmark site, social media site etc) the URL appears like the A, plenty of strange characters and %. This link sometimes may cause broken link issues especially when we try to submit it in social networks and social bookmarks. On the other hand, googlebot reads that url but I am wondering if there is an advantage for the websites who keep the encoded URLs or not (in compairison to the sites who use Greeklish in the URLs)! So the question is: For the SEO issues, is it better to use Greek characters (encoded like this one http://el.wikipedia.org/wiki/%CE%95%CE%BB%CE%B2%CE%B5%CF%84%CE%AF%CE%B1) in the URLs or would it be better to use just Greeklish (for example http://el.wikipedia.org/wiki/Elvetia ? Thank you very much for your help! Regards, Lenia
Technical SEO | | tevag0 -
What is the best way to find stranded pages?
I have a client that has a site that has had a number of people in charge of it. All of these people have very different opinions about what should be on the site itself. When I look at their website on the server I see pages that do not have any obvious navigation to them. What is the best way to find out the internal linking structure of a site and see if these pages truly are stranded?
Technical SEO | | anjonr0 -
Old URL redirect to New URL
Alright I did something dumb a year a go and I'm still paying for it. I changed my hyphenated URL to the non-hyphenated version when I redesigned my website. I say it was dumb because I lost most of my link juice even though I did 301 redirects (via the htaccess file) for almost all of the pages I could find in Google's index. Here's my problem. My new site took a huge hit in traffic (down 60%) when I made the change and even though I've done thousands of redirects my old site is still showing up in the SERPS and send much if not most of my traffic. I don't want to take the old site down in fear it will kill all of my traffic. What should I do? Is there a better method I should explore then 301 redirects? Could the other site be affecting my current rank since it's still there? (FYI...both sites are built on the WP platform). Any help or ideas are greatly appreciated. Thank you! Joe
Technical SEO | | kaje0 -
I can buy a domain from a competitor. Whats the best way to make good use of these links for my existing website
Technical SEO | | Archers0
