Question on noscript tags and indexing
If I have a
<noscript>tag on every page of my website with the same sentence over and over saying something to the effect of "Sorry our site uses Javascript, please enable javascript for the full site experience.", Webmaster Tools will tell me that one of the most common words on my site is "Javascript".</p> <p>Is this something to be concerned about from an SEO perspective? My site is obviously not about Javascript and I don't want to dilute my page's topic or authority by repeating words that are not relevant to the topic of my site.</p> <p>Thanks!</p></noscript>
Weird. We were having a problem where lots of our skill pages were getting our
<noscript>text used as page descriptions on Google SERPS. We added these comments, and Googlebot reverted to using our meta description as the page descriptions in SERPs. It could have been a freak coincidence that Google stopped using our <noscript> text right after we implemented the tags, or possibly Google was (possibly accidentally) supporting them for web search awhile back when we originally did this, and now has stopped supporting it. Anyways, our SERPS remain clean of our <noscript> text today (<a href="https://www.google.com/search?q=site:www.ixl.com/math/grade-5" target="_blank">example</a>).</p> <p>John Mueller recently commented on that Quora thread saying it won't do anything for web search, so IMO that puts this to rest.</p></noscript>
Yes actually you are correct. After I read this answer I tested it on my personal site by adding the tags around some nonsense words. Not only did Google index the pages with the nonsense words making it into their cache of the pages, but my site ranks for those nonsense words. So while it would be awesome if Googlebot honored those tags, they only work for the Google search appliance!
John,
The googleoff and googleon tags are meant for Google's enterprise site search product, Google Search Appliance. They "shouldn't" have any effect on the public index. Do you have an example where you can prove they work in Google search?
Can you try wrapping only the message about Javascript with the googleoff/googleon comments, and see what happens? It you don't have to put it around everything in the
<noscript>. I would agree that it sounds like the structure of your site is not ideal, but I'd try that first and see if it solves the problem.</p></noscript>
John,
You just literally blew my mind with that googleon/googleoff documentation! I've been working as an SEO since 2001 and have literally never heard of this! I have so many questions I need to research. I can think of a lot of ways to use this but I'm sure the best practices around its use are more nuanced than just the technical documentation.
Anyway, in terms of my immediate problem, not sure if that will fix it. I should have mentioned that in addition to the message about Javascript, the noscript tag also contains site content, including navigation links, that are not on the page otherwise for non-javascript clients. In other words, this entire website is a singe blank page with no content on it if you do not have javascript without the noscript tags. The long term solution is to completely redo the website, obviously, but I need a short term solution to get some SEO traction. I guess I could always put the javascript message as an image.
I had a similar problem, Google was picking up
<noscript>text and using it as the description for our pages in some SERPs. We didn't want to remove them, so we tried using "googleoff" and "googleon" tags, which are just HTML comments that Googlebot can read. You can read their documentation <a href="https://developers.google.com/search-appliance/documentation/68/admin_crawl/Preparing#pagepart" target="_blank">here</a>. We wrapped the text in the <noscript> with these comments, and it worked like a charm, so it does look like Google respects these tags.</p> <p>If I were you, I'd go ahead and add the syntax if it's easy for you to do (i.e. only have to add it a few places in the code, not in thousands). It's probably not great for your SEO that Google thinks your site is about Javascript. Or you can do what Frederico says and remove it. Only you know your user base, but he's probably right. Almost everyone for the most part everyone has Javascript enabled these days.</p> <p>I originally read about this in the Quora thread <a href="http://www.quora.com/Quora/Why-hasnt-Google-banned-Quora-for-hiding-answers-from-search-engine-visitors" target="_blank">here</a>. Quora Uses it to control what text Googlebot can index on their pages. If you want to see an example of it on my site, you can view one of our skills <a href="http://www.ixl.com/math/pre-k/identify-circles-squares-and-triangles" target="_blank">here</a>.</p></noscript>
Most modern browsers run javascript, and most users have Javascript enabled and running as sites today use it more and more. I would definitely remove that noscript tag and all within. It is actually not adding any value while it can cause google to recognize your site as something related to javascript.
Sudden Indexation of "Index of /wp-content/uploads/"
Hi all, I have suddenly noticed a massive jump in indexed pages. After performing a "site:" search, it was revealed that the sudden jump was due to the indexation of many pages beginning with the serp title "Index of /wp-content/uploads/" for many uploaded pieces of content & plugins. This has appeared approximately one month after switching to https. I have also noticed a decline in Bing rankings. Does anyone know what is causing/how to fix this? To be clear, these pages are **not **normal /wp-content/uploads/ but rather "index of" pages, being included in Google. Thank you.
Technical SEO | | Tom3_150 -
Indexing Issue of Dynamic Pages
Hi All, I have a query for which i am struggling to find out the answer. I unable to retrieve URL using "site:" query on Google SERP. However, when i enter the direct URL or with "info:" query then a snippet appears. I am not able to understand why google is not showing URL with "site:" query. Whether the page is indexed or not? Or it's soon going to be deindexed. Secondly, I would like to mention that this is a dynamic URL. The index file which we are using to generate this URL is not available to Google Bot. For instance, There are two different URL's. http://www.abc.com/browse/ --- It's a parent page.
Technical SEO | | SameerBhatia
http://www.abc.com/browse/?q=123 --- This is the URL, generated at run time using browse index file. Google unable to crawl index file of browse page as it is unable to run independently until some value will get passed in the parameter and is not indexed by Google. Earlier the dynamic URL's were indexed and was showing up in Google for "site:" query but now it is not showing up. Can anyone help me what is happening here? Please advise. Thanks0 -
Image Indexing Issue by Google
Hello All,My URL is: www.thesalebox.comI have Submitted my image Sitemap in google webmaster tool on 10th Oct 2013,Still google could not indexing any of my web images,Please refer my sitemap - www.thesalebox.com/AppliancesHomeEntertainment.xml and www.thesalebox.com/Hardware.xmland my webmaster status and image indexing status are below,
Technical SEO | | CommercePunditCan you please help me, why my images are not indexing in google yet? is there any issue? please give me suggestions?Thanks!
0 -
Div tags vs. Tables
Is there any reason NOT to code in tables (other than it being outdated) for SEO reasons?
Technical SEO | | EileenCleary0 -
Isnt it better to have headlines in H1 and H2 tags instead of p tags?
I am working with a simple site http://http://lightsigns.com/Uniko_Manufacturing_Limited.html They seek more SEO traffic. However, the two big headlines that read "Wholesale Supply to the Sign and Display Industries" which is on line 241 and 242 of the source code, its in a p tag, i.e. <p <span class="webkit-html-tag">style</p <span>="padding-top: 0pt; " class="paragraph_style_1">Wholesale Supply to the and <p <span class="webkit-html-tag">style</p <span>="padding-bottom: 0pt; " class="paragraph_style_1">Sign and Display Industries Likewise, the product titles are in p tags, also. For example, on the Slide-in Light Box product page, http://lightsigns.com/Slide_In_light_box.html , I have done keyword research and no one is using the words slide in light box.Plus, it is also a p tag, ie. line 43 reads style="padding-bottom: 0pt; padding-top: 0pt; " class="paragraph_style">Slide-in Light Box If I suggest that they make an H2 tag with SEO-optimized keywords such as Display Light Box - Slide-In LIght Box, would this indeed help SEO? In summary, is it correct to say that H1 and H2 tags are stronger signals to the search bots of what the page is about?
Technical SEO | | BridgetGibbons1 -
Pages removed from Google index?
Hi All, I had around 2,300 pages in the google index until a week ago. The index removed a load and left me with 152 submitted, 152 indexed? I have just re-submitted my sitemap and will wait to see what happens. Any idea why it has done this? I have seen a drop in my rankings since. Thanks
Technical SEO | | TomLondon0 -
Google is indexing my directories
I'm sure this has been asked before, but I was looking at all of Google's results for my site and I found dozens of results for directories such as: Index of /scouting/blog/wp-includes/js/swfupload/plugins Obviously I don't want those indexed. How do I prevent Google from indexing those? Also, it only seems to be doing it with Wordpress, not any of the directories on my main site. (We have a wordpress blog, which is only a portion of the site)
Technical SEO | | UnderRugSwept0 -
How many strong tags is too many
Hi everyone, just a quick question, what are your views on the use of strong tags in content? how many is too many? What is you have strong tags around every keywords for a sentance etc?
Technical SEO | | pauledwards1
