Best way to nofollow affiliate links?
I don't "nofollow" affiliate links but I have quite a few. Doing them one by one would just be an impossible job. Would it be best to get a plugin that nofollows EVERYTHING? What would google prefer? I need to DOFOLLOW some links because those sites deserve it.
If it's Amazon you are concerned with you could probably just leave them as-is. However, you could also run a scan of your site using a tool like Screaming Frog or OSE and look for outbound links going to Amazon.com and other known affiliate sites. This will at least make tracking them down to manually update them easier.
You could probably have this done at the database level too, though that is something for which you'll probably want to hire a DBA.
The following article has the best idea I could find for your situation, though it still isn't perfect because you could be applying a nofollow meta tag (as opposed to a nofollow link attribute) to pages that have both affiliate links AND editorial links that you want followed. At any rate, I hope this helps: http://www.bradlinder.net/2011/05/how-to-add-nofollow-attribute-to-all.html
I want to dofollow links to great blog posts or websites - NOT affiliate links. I cannot find a plugin that nofollows affiliate links. Any suggestions? Amazon does not redirect and I have a lot of Amazon affiliate links.
I would not nofollow "everything" on your site, as in every outbound link, affiliate or not. However, if you can find a plugin that will nofollow every "affiliate" link, you could go back and manually remove the nofollow link on those you wish to editorially endorse - though "technically" you shouldn't have a financial arrangement with them.
Much of the time affiliate links go through some sort of redirect that blocks pagerank anyway, such as a 302, or a redirect to a blocked folder, etc... This is typical with most of the larger affiliate networks.
Best practices for publishing sponsored content
Hello, Our website hosts sponsored content from different brands. Should we be listing the sponsor either on the frontend and/or through markup? - Would either way have any sort of an impact? The content itself is already clearly marked as 'sponsored content' but we were more interested in listing the specific sponsor. Also, we’re assuming the outbound links would need to be marked rel="sponsored" but are there any other best practices we should be implementing? Any insight would be appreciated.
On-Page Optimization | | Ben-R
Thank you in advance.
Best,0 -
URL keyword separator best practice
Hello. Wanted to reach out see what the consensus is re-keyword separators So just taken on a new client and all their urls are structured like /buybbqpacks rather than buy-bbq-packs - my understanding is that it comes down to readability, which influences click through, rather than search impact on the keyword. So we usually advise on a hyphen, but the guy's going to have to change ALLOT of pages & setup redirects to change it all wasn't sure if it was worth it? Thanks! Stu
On-Page Optimization | | bloomletsgrow0 -
Should an internal link open in a new tab or in the same window?
Should an internal link open in a new tab or in the same window? Seems like this is an issue that has never had a definitive answer one way or the other. But I couldn't find any recent articles from reliable sources taking a stance and answering this question. Does anyone know if user engagement metrics (time on site, bounce rate, pages per visit) are impacted if a user clicks a link that opens in a new tab? Thanks!
On-Page Optimization | | NicheSocial0 -
Linking to External Site In Nav Bar
Hi, we are a celebrity site but also own a separate sports site with its own URL. We have a link to that site in our Nav bar. Are we being penalized by having that link? thanks
On-Page Optimization | | Uinterview0 -
Navigation Links Causing Too Many Links Help?
Hello, I have read some SEOMOZ search results for this, but am still concerned that Google may see 4,500 Too Many Link warnings as a problem. This is caused primarily due to our header navigation, which is not intended to be keyword stuffing, but to provide all avenues for our breadth of content. site: crazymikesapps.com. Most answers seem to advise if there is no keyword stuffing at hand don't worry about it. Any help appreciated. thank you Mike
On-Page Optimization | | crazymikesapps0 -
Internal Linking - in content vs navigation menu
Would like to get some thoughts on whether navigation menus or in-content links are best for internal linking, from an SEO standpoint. A few thoughts to get started with: For sites with a lot of content, you can have a navigation menu linking to your higher-level pages, then in-content links to deeper pages on your site. For smaller sites, this is not an option, as the navigation menu will probably link to all your important pages. You could add in-content links, but Google only counts the first link on the page, so the in-content links would be ignored if you'd already linked yp the page in your top nav menu. I can think of several possible reasons navigation menu links could be less desirable than in content links from a Google perspective. (They are sitewide boilerplate content without context.) If you setup your navigation structure based on what is best for the user, small sites don't have much wiggle room to optimize internal link structure, as all their money pages will be linked to from the top nav menu. Do you think Google prefers in content links to navigation menu links? If so, how do you get around the fact that for many sites, all their money pages are being linked to from their main navigation menu?
On-Page Optimization | | AdamThompson0 -
Blog on Subdomain vs. Subdirectory - Best Practices
Hi, I have recently been told that it no longer impacts authority or rankings if a blog is set up on a subdomain (blog.domain.com) rather than a subdirectory (/blog). However, I am reluctant to do so because I remember learning how blog subdomains did not adhere to SEO best practices. Would anyone be able to shed some light on the latest SEO best practices regarding this topic? Many thanks, Erin
On-Page Optimization | | HiddenPeak0 -
Too many links on page -- how to fix
We are getting reports that there are too many links on most of the pages in one of the sites we manage. Not just a few too many... 275 (versus <100 that is the target). The entire site is built with a very heavy global navigation, which contains a lot of links -- so while the users don't see all of that, Google does. Short of re-architecting the site, can you suggest ways to provide site navigation that don't violate this rule?
On-Page Optimization | | novellseo2
