Does using data-href="" work more effectively than href="" rel="nofollow"?
I've been looking at some bigger enterprise sites and noticed some of them used HTML like this:
<a <="" span="">data-href="http://www.otherodmain.com/" class="nofollow" rel="nofollow" target="_blank"></a>
<a <="" span="">Instead of a regular href=""
Does using data-href and some javascript help with shaping internal links, rather than just using a strict nofollow?</a>
I think this is actually a really good question. The main reason most SEOs these days don't "sculpt" or "shape" with nofollow links anymore has to do with the fact that they will still take away from the total amount of pagerank available to be passed on to other links on the page. So the question I'm reading above seems to be:
Do<a data-href...="" links="" still="" take="" a="" portion="" of="" pagerank="" away="" from="" the="" total="" pr="" available="" to="" be="" passed="" on="" other="" same="" page?<="" p=""></a>
<a data-href...="" links="" still="" take="" a="" portion="" of="" pagerank="" away="" from="" the="" total="" pr="" available="" to="" be="" passed="" on="" other="" same="" page?<="" p="">My answer is "I don't know" but I'd like to see a test if anyone can think of a way to try it out.</a>
<a data-href...="" links="" still="" take="" a="" portion="" of="" pagerank="" away="" from="" the="" total="" pr="" available="" to="" be="" passed="" on="" other="" same="" page?<="" p="">However, even if the test came back saying "No, these are treated differently and do not currently affect the total amount of PR available to other links on the page" I still would not use it for the purpose of pagerank sculpting. The reason is that how Google treats these links today can change tomorrow, making "tactics" like this a bad idea IMHO. It just leaves a mess for either you or some other poor SEO to cleanup later.
If I don't want pagerank to pass through a link on a page I simply don't put the link on the page. In extreme circumstances where there is no other way around it I might consider obfuscating the link with some javascript, for instance. However, even if you block the .js file that handles this "link" in the robots.txt file Google still executes it (as you can see when viewing the cached version on Google for pages that do this).</a>
Hi Jonathan,
I highly doubt it, you normally use the data-href to trigger some events with JavaScript and as these links still have the rel="nofollow" it probably will have the same value (0, as it's nofollow) to search engines.
Should we use Cloudflare
Hi all, we want to speed up our website (hosted in Wordpress, traffic around 450,000 page views monthly), we use lots of images. And we're wondering about setting up on Cloudflare, however after searching a bit in Google I have seen some people say the change in IP, or possible sharing of Its with bad neighbourhoods, can really hit search rankings. So, I was wondering what the latest thinking is on this subject, would the increased speed and local server locations be a boost for SEO, moreso than a potential loss of rankings for changing IP? Thanks!
Technical SEO | | tiromedia1 -
Quick Fix to "Duplicate page without canonical tag"?
When we pull up Google Search Console, in the Index Coverage section, under the category of Excluded, there is a sub-category called ‘Duplicate page without canonical tag’. The majority of the 665 pages in that section are from a test environment. If we were to include in the robots.txt file, a wildcard to cover every URL that started with the particular root URL ("www.domain.com/host/"), could we eliminate the majority of these errors? That solution is not one of the 5 or 6 recommended solutions that the Google Search Console Help section text suggests. It seems like a simple effective solution. Are we missing something?
Technical SEO | | CREW-MARKETING1 -
Where did the "Location" go, on Google SERP?
In order to emulate different locations, I've always done a Google query, then used the "Location" button under "Search Tools" at the top of the SERP to define my preferred location. It seems to have disappeared in the past few days? Anyone know where it went, or if it's gone forever? Thanks!
Technical SEO | | measurableROI0 -
Schema markup for products is missing "price": Is this bad?
Hey guys, So a current client of mine has an e-commerce shop with a few hundred products. They purposely choose to keep the prices off of their website, which is causing errors in Google Webmaster Tools. Basically the error shows: Error: Structured Data > Product (markup: schema.org) Error type: missing price 208 items with error Is this a huge deal? Or are we allowed to have non-numerical prices for schema ie. "call for quote"
Technical SEO | | tbinga1 -
How can I Style Long "List Posts" in Wordpress?
Hi All, I have been working on a list-post which spans over 100 items. Each item on the list has a quick blurb to explain it, an image and a few resource links. I am trying to find an attractive way to present this long list post in Wordpress. I have seen several sites with long list posts however; they place their items one on top of the other which yields a VERY long page and the end user has to do a lot of scrolling. Others turn their lists into slideshows, but I have no data on how slides perform against 10-mile-long-lists which load in 1 page. I would like to do something similar to what List25.com does as they present about 5-10 items per page and they seem to have pagination. The pagination part I understand however; is there a shortcode plugin to format lists in an attractive way just like list25?
Technical SEO | | IvanC0 -
New "Static" Site with 302s
Hey all, Came across a bit of an interesting challenge recently, one that I was hoping some of you might have had experience with! We're currently in the process of a website rebuild, for which I'm really excited. The new site is using Markdown to create an entirely static site. Load-times are fantastic, and the code is clean. Life is good, apart from the 302s. One of the weird quirks I've realized is that with oldschool, non-server-generated page content is that every page of the site is an Index.html file in a directory. The resulting in a www.website.com/page-title will 302 to www.website.com/page-title/. My solution off the bat has been to just be super diligent and try to stay on top of the link profile and send lots of helpful emails to the staff reminding them about how to build links, but I know that even the best laid plans often fail. Has anyone had a similar challenge with a static site and found a way to overcome it?
Technical SEO | | danny.wood1 -
Should we use "and" or "&"?
Our client has an ampersand in their brand name. The logo has "&", their url is spelled out. I'm trying to get them to standardize the use of the name for directories/listings. Should we use "and" or "&"?
Technical SEO | | vernonmack0 -
Which pages to "noindex"
I have read through the many articles regarding the use of Meta Noindex, but what I haven't been able to find is a clear explanation of when, why or what to use this on. I'm thinking that it would be appropriate to use it on: legal pages such as privacy policy and terms of use
Technical SEO | | mmaes
search results page
blog archive and category pages Thanks for any insight of this.0
