Script tags and seo
I have a page on my site with a google map embed, and a path drawn on the map. The path is made from a long string of coordinates. For ease I have the co-ordinates placed in a script tag at the foot of the page, amongst my javascript
My question is, will this script tag hurt the seo for the page? I've read that inline js and 'data islands' can be bad, so I've been careful to keep it out of the main body of the page. Thanks, any help appreciated!
Inline scripts aren't bad per se, search engines just can't always understand them. Worst case scenario: you have extra code that Google has to crawl but doesn't understand, which takes up bandwidth and doesn't add value. But, it won't lower your rankings.
So, do whatever you need to do to deliver the best user experience you can on your site with this map and related route, and figure that Google will ignore it (Google is trying to understand it, though, so it may be helpful in the long run). Then, for search engines, include some text content describing the map and the route so that search engines can send the right searchers to your page.
Good luck!
Kristina
Okay great, that's very helpful.
What if I wanted to have multiple scripts, say, for points of interest along the route, and had multiple (20+) tags at the bottom of the page? Would this be an ugly way of doing it, or considered totally okay in the eyes of google?
Yes, that's an inline script (putting it at the top or bottom will still be inline), but as I said, if only one page is using that script, you are good to go. There's nothing bad in using inline scripts if they aren't going to be used on other pages as well.
Thanks Federico.
As my script is being called at the bottom of the page, I would assume it doesn't count as 'inline'?
Yes the scripts are only being used once on specific pages.
Inline scripts are bad if you are bringing them on every page, if that's the case, just use scrip embedding so users don't need to download the scripts EVERY time they see a page.
But, if the inline script is used only on a specific page and not reused, then there's no reason to load it as an external file. In my opinion, that will even need an extra server call to bring a code that only works on that page.
Hope that helps!
Is The HREF Link "Title" Tag Needed on Mobile Websites?
Hello To Those Who Are Wiser Than I, I am wondering if the href link "title" tag is needed, or serves any purpose, on mobile websites? Also, does it effect SEO in any way? I ask because generally the href link title tag provides more information to the user when they scroll their mouse over the link - but this action does not happen on mobile! Users have no mouse and thus no extra information would be displayed. I'm really wondering if it still matters for SEO purposes on mobile though. -The UnEnlightened
Web Design | | Stew2220 -
Will having two wordpress themes installed hurt seo?
We currently have 3 sites built on WordPress that have little to no blogging capabilities. Currently, all published posts show up on a /category page which does not resemble the traditional blog format and is not aesthetically pleasing. We would like to have a more traditional blog and are considering installing a second wordpress theme on the site which will strictly be used for /blog and all the posts. My question is will having the second WordPress installation on the sites hurt us in any way on the SEO front and if we go this way should we place the install in a subfolder or on a subdomain? Is there anything else we need to worry about with making this transition? Thank you in advance for the advice! Patrick
Web Design | | PlanetDISH0 -
Wordpress - redirecting tags
I just ran a webmaster tool from Yoast SEO premium and notice I have a lot of problems with tags (restricted-robots-txt) For example : http://www.soobumimphotography.com/tag/wedding-group-photo/ Do I have to redirect to http://www.soobumimphotography.com/wedding-group-photo/ Should I do this to each and every posts Thank you
Web Design | | soobumim0 -
Too Many Outbound Links on the Home Page - Bad for SEO?
Hello Again Moz community, This is my last Q of the day: I have a LOT of outbound links on the home page of www.web3.ca Some are to clients projects, most are to other pages on the website. Can reducing this to the core pages have a positive impact on SEO? Thanks, Anton
Web Design | | Web3Marketing870 -
From Google Sites to Wordpress - Anyone Ventured this SEO terrain?
We have a few sites in Google Sites - and they are ugly! We have a majority (40+) of websites in Wordpress. But we have a few websites just stuck on Google Sites, and since Google won't let you fully edit the HTML, add scripts, or implement any technology since 2000, we want to move. The sad problem - the Google sites are ranking well. We rank well in Manhattan, Atlanta, Dallas, and Philadelphia. The problem is - the sites do not give much room for growth - and the bounce rate is high because they are so ugly. Has Anyone moved from Google sites to Wordpress? Should we just stay with Google and bite the ugly bullet? My fear is that these sites will not allow for growth. It is hard to update them and even harder to make them look nice. To get a sample - beware: www.counselingphiladelphia.com Even another reason to leave: The slider is non-semantic and terrible SEO. Google won't allow a slider script with tags and a hrefs, so the only way to implement a slider is through a Google Docs Presentation that keeps sliding. I know - terrible SEO (#donthate) but we needed something. Any advice and thoughts would help! Thanks Mozzers!
Web Design | | _Thriveworks0 -
What is the difference of HTML5 and web 2.0? What is web 2.0 and is this better for seo?
A little bit confused with the new stuff. The web 2.0 webpages are so much better? What changes?
Web Design | | Naghirniac0 -
Live Text in Navigation Vs. Image - Does this affect SEO
I recently was asked the question if having live text in the navigation vs and image affect seo. For example, refer to this link http://markup.io/v/avsaenq856kw the navigation highlighted is seperate images. The html elements read : /images/procedures.png"> Live text html reads like this: Breast » What is better for seo value, or does it now matter having live text or an image?
Web Design | | Red_Spot_Interactive0 -
Should I Remove URL extentions for SEO?
We are having a developer design our website with Magento. I noticed the main pages such as About Us have no file extention in the URL. But the product pages have a .html file extention. I was once told to remove the file extentions. Are there benefits to removing the .html file extension and if so, is there a way we can do this using Magento?
Web Design | | hfranz0
