Are there any SEO benefits changing the default home page filename (index.htm) to a keyword rich filename
II'm a newbie. I have a website using the default home page filename: index.htm. I have total control over the web server. I was wondering whether I can get any SEO improvements for my main keyword if I change the default filename with a filename that contains the main keyword, like our-main-product.htm (doing the 301 redirect and changing the server search order, of course)?
Thasnk you so much for your help, Paul.
Hey Oscar - my second language is French and I couldn't possibly have asked the question in my other language as well as you have here, so don't worry about the language issue at all!
For your question about changing the index.htm to something with a keyword: no, that would have absolutely no effect. As long as the redirect was with a 301 code, the search engines and the visitors will never know that page even exists. That's the whole purpose of the 301-redirect. it makes that page invisible to the search engines.
I would also strongly advise not to switch to a keyword-rich subdomain. that's just asking for a lot of headaches and problems in the future.
What you are suggesting here is trying to create what is called and Exact Match Domain (EMD), meaning the title of your domain matches the keyword you are trying to rank for. The value of these has recently been lowered by Google anyway, and as I say, doing it using a subdomain will cause all kinds of hassles, not to mention confusion for your users.
If I were you, the area i would be focusing most of my efforts would be on building and earning links form other websites. At the moment, you essentially only have one other domain linking to you.
In addition, trying to rank with a very competitive general term like impresión digital will be very difficult for a new site. Better to use terms like impresión digital en Chihuahua and others related to where you offer your services. This is assuming that most of your customers are fairly local, not from all over the Internet.
Hope that answers your question? If not, be sure to let me know.
Hi Paul:
I already got rid of the index.htm name appearing in the url homepage, and also I have all the needed 301 redirects for the mydomain.com, mydomain.com.mx and mydomain.mx pointing to www.grafimart.com. Please, take alook at: www.grafimart.com
What I really want to know is whether I can get some SEO benefit if I change the index.htm main home page filename for my main keyword: impresion-digital.htm, even when it is not to be shown to the users. In other words: Does the google bots consider as a valid keyword the index page name, even when it is not shown?
http://www.grafimart.com/impresion-digital.htm
instead of:
http://www.grafimart.com/index.htm
I´m thinking on this based on the fact that my domain name is a branded name and I find difficult to get better SEO for my main page using a subdomain like
(impresion-digital.grafimart.com)
Hope you can understand my poorly written english.
Oscar
Google weights most of its SEO 'strength' to the actual domain name iteself - and even then, from left to right i.e the further right your main keyword is, the less juice it will get.
However, if you have relevant content on the page and name the page accordingly then you are making what is called an 'seo friendly' URL. Many people who use Wordpress for example, change their permalinks to change the url from something like mysite.com/p1 to mysite.com/keyword - which WILL make a difference, albeit not a huge one.
So if it's straightforward for you to do so, then by all means do it. Outside of SEO it will help your visitors better understand what the page is about, and will look a lot prettier in the SERPs too.Also, rather than 301'ing each page, you may be able to change the structure of your permalinks within your .htaccess file so that it will happen automatically e.g by naming the file with the title of your page or postname.
Hope this helps...
What you actually want to do is get rid of that index.htm address for your home page altogether, Oscar. You want your visitors to only be able to reach your homepage at one URL. This means you need to use 301 rewrites to make your /index.htm page redirect to your primary domain name. (E.g. the website name with no filename after it.)
You also want to make sure that you have chosen between www.youdomain.com and yourdomain.com (without the www) as the primary address, and rewritten the other one to point to the primary. This is called canonicalisation of the home page. The search engines see each of those addresses as completely different pages because they have different URLs - even though they display the same page. As a result, they'll be considered duplicate content and will effectively be competing against each other.
There are many questions here in Q&A that explain how to do these kind of redirects. Let us know if you can't find one that works for you.
Hope that helps?
Keyword appearing on almost every slug of product pages = over-optimizatio
Hello all, I have an online store, let's say for example I sell forks of all kinds and colors. So naturally, I have 'product category' pages with titles and slugs like: Big forks
On-Page Optimization | | Veptune
Small forks
Plastic forks
Red fork
etc.. And plenty of product pages with slugs and H1 like: Small red fork
Large plastic fork
18th-century fork
etc... Some category pages are well-ranked, others are not, the same goes for product pages. The problem is that for the main keyword, 'fork' (exact query in the search console), my site is completely absent. Google should logically have referenced my homepage (which has links to all categories) for this main keyword. I have also optimized the page for it, without overdoing it. I wonder if it's not because I have a lot of pages with 'fork' in the slug, and perhaps Google thinks it's too much (even though it's logical for this word to be present in all product pages because it's an essential word to describe the product). I wonder if I should not modify half of my product pages to remove the word 'fork' from the slug...(only from the slug, without touching the H1 because removing the word 'fork' would remove its meaning). Do you have any experiences with this kind of issue? I wouldn't ask the question if my homepage was behind the competition, but it's completely absent. Thanks0 -
Why home Page is not showing showing in search results?
The USA Glitz I search the exact title & keyword but still its not showing though there is no related websites in this term. What can i do ? What kind of strategy needs to follow ? Kindly help me out . Thanks 😢
On-Page Optimization | | henrichjrr4201 -
Do keywords within a dropdown menu add any SEO value?
I haven't seen this written about in some time. Has anyone had any experience dabbling in this?
On-Page Optimization | | gregvellante0 -
How many keywords should I optimize a page for?
Hi, There is a lot of debate going on on whether to use a single keyword per page or multiple keywords per page. What I know for sure is that it is not advisable to repeat the same exact keyword in different pages. I need to optimize product pages, categories and pages for an online store and still do not know if it is better to: 1-work with one main keyword per page plus latent semantic keywords, 2-to optimize a page for multiple different keywords (2 to 4 keywords) which are strongly related to the main topic or to the product sold in a particular product page 3- use single keyword for each page (and no more than one keyword per page). Some seo gurus argue this is the best way to get higher ranking for that particular page in the serps. My personal opinion would be 1 or 2, but I would like to hear what you suggest and think about it. Any suggestion or opinion is welcome and appreciated. Thanks in advance
On-Page Optimization | | cinzia090 -
Should I optimize my home-page or a sub-page for my most important keyword
Quick question: When choosing the most important keyword set that I would like to rank for, would I be better off optimizing my homepage, or a sub page for this keyword. My thinking goes as follows: The homepage (IE www.mysite.com) naturally has more backlinks and thus a better Google Page Rank. However, there are certain things I could do to a subpage (IE www.mysite.com/green-widgets-los-angeles ) that I wouldn't want to do to the homepage, which might be more "optimal" overall. Option C, I suppose, would be to optimize both the homepage, and a single sub-page, which is seeming like a pretty good solution, but I have been told that having multiple pages optimized for the same keywords might "confuse" search engines. Would love any insight on this!
On-Page Optimization | | Jacob_A2 -
Is it convinient to use No-Index, Follow to my Paginated Pages?
I have a website http://www.naukrigulf.com and it has a lot of Paginated pages on its SERP and most of paginated pages are getting indexed in Google SERP. Is it beneficial to use No-Index, Follow to keep the link equity to main (first page), although we have already used rel=next and rel=prev. If Answer is "yes" is their any harm by using no-index, follow with rel=next, rel=prev.
On-Page Optimization | | vivekrathore0 -
Home page or landing page?
Hello, I want to ask a question related to that - Should we put keywords in the home page title if we wish to position another landing page better for particular keywords? I have read in one website about SEO that it's good the main keywords of your website to be positioned in homepage title also. f.e. Let's say we have website about web-design and our company is named Company Ltd. The title of the home page is "Company Ltd. - Web design, SEO, etc" We have also another inner page named "Web design | Company Ltd.". So should we leave the first page name only "Company Ltd." and the landing page's name "Web design | Company Ltd." . I don't know if they both have the same keyword in their title they won't compete with each other.
On-Page Optimization | | HrishikeshKarov0 -
Wordpress: Should I NO INDEX Categories & Archives Pages?
I am new to SEOmoz & trying to work my way through the ca-trillion errors that have been found on my site, but for each one I want to ensure that I am helping rather than harming my site. The tool has (as a "notice") said that my category pages & Archives are NO-INDEX, is this how these pages should be dealt with? In addition, the crawler has also (as a "warning error) discovered that my categories, and Archives do not have a meta description..is this of great importance for non indexed pages of this type? Thanks so much to the SEOmoz forum members, you have so far been of invaluable help to me.
On-Page Optimization | | KMack2
