Isnt it better to have headlines in H1 and H2 tags instead of p tags?
I am working with a simple site http://http://lightsigns.com/Uniko_Manufacturing_Limited.html
They seek more SEO traffic. However, the two big headlines that read "Wholesale Supply to the Sign and Display Industries" which is on line 241 and 242 of the source code, its in a p tag, i.e.
<p <span class="webkit-html-tag">style</p <span>="padding-top: 0pt; " class="paragraph_style_1">Wholesale Supply to the
and
<p <span class="webkit-html-tag">style</p <span>="padding-bottom: 0pt; " class="paragraph_style_1">Sign and Display Industries
Likewise, the product titles are in p tags, also. For example, on the Slide-in Light Box product page, http://lightsigns.com/Slide_In_light_box.html , I have done keyword research and no one is using the words slide in light box.Plus, it is also a p tag, ie. line 43 reads
style="padding-bottom: 0pt; padding-top: 0pt; " class="paragraph_style">Slide-in Light Box
If I suggest that they make an H2 tag with SEO-optimized keywords such as Display Light Box - Slide-In LIght Box, would this indeed help SEO?
In summary, is it correct to say that H1 and H2 tags are stronger signals to the search bots of what the page is about?
I would agree that H1s are stronger than
tags for SEO, but they're still pretty minor on-page indications.
Of much greater impact would be to better-optimize the meta-title for the page, which is one of the strongest on-page SEO factors. Right now it's just the company name "Uniko Manufacturing Limited" Much better would be "Uniko Manufacturing Limited - Wholesale Sign and Display Industry Supply" or something similar.
Also, the page has no meta-description, which could severely handicap it when it does appear in search results. The meta-description does not help with ranking, but it's like a mini-ad for the page right in the search results to all ow you try to convince a searcher to click on your page instead of someone else's.
Better to focus on the highest impact optimizations first, rather than just the easiest.
Hope that makes sense?
"If I suggest that they make an H2 tag with SEO..."
H1's carry a little more weight than H2's, so I'd suggest using an H1 if you can. Ian implied that, but he didn't outright say it
Also, the page you have listed has capital letters in it, which isn't ideal, but it's still fine. However, the lower case version does 404. So, any links that are sent to the lower case version will not result in you getting link juice to the page. I'd suggest using a 301 redirect from the lower case version to the upper case one that you have listed.
lower case version:
"In summary, is it correct to say that H1 and H2 tags are stronger signals to the search bots of what the page is about?"
Absolutely. These tags are strong signals to search engines as to what the page is about, along with title tags and meta descriptions. You can prioritize content and break down the page with H1 through H6 headline tags. SEOmoz has a great on-page best practice guide for setting up the page, which makes sense for your users as well as search engines. Try not to spam keywords anywhere, just make sure it is "keyword friednly" but at the same time readable and would make sense to a human.
Unsolved Using NoIndex Tag instead of 410 Gone Code on Discontinued products?
Hello everyone, I am very new to SEO and I wanted to get some input & second opinions on a workaround I am planning to implement on our Shopify store. Any suggestions, thoughts, or insight you have are welcome & appreciated! For those who aren't aware, Shopify as a platform doesn't allow us to send a 410 Gone Code/Error under any circumstance. When you delete or archive a product/page, it becomes unavailable on the storefront. Unfortunately, the only thing Shopify natively allows me to do is set up a 301 redirect. So when we are forced to discontinue a product, customers currently get a 404 error when trying to go to that old URL. My planned workaround is to automatically detect when a product has been discontinued and add the NoIndex meta tag to the product page. The product page will stay up but be unavailable for purchase. I am also adjusting the LD+JSON to list the products availability as Discontinued instead of InStock/OutOfStock.
Technical SEO | | BakeryTech
Then I let the page sit for a few months so that crawlers have a chance to recrawl and remove the page from their indexes. I think that is how that works?
Once 3 or 6 months have passed, I plan on archiving the product followed by setting up a 301 redirect pointing to our internal search results page. The redirect will send the to search with a query aimed towards similar products. That should prevent people with open tabs, bookmarks and direct links to that page from receiving a 404 error. I do have Google Search Console setup and integrated with our site, but manually telling google to remove a page obviously only impacts their index. Will this work the way I think it will?
Will search engines remove the page from their indexes if I add the NoIndex meta tag after they have already been index?
Is there a better way I should implement this? P.S. For those wondering why I am not disallowing the page URL to the Robots.txt, Shopify won't allow me to call collection or product data from within the template that assembles the Robots.txt. So I can't automatically add product URLs to the list.0 -
Should we set up redirects for all deleted TAGS?
We recently found our site had 65,000 tags (yes 65K). In an effort to consolidate these we've started deleting them. MOZ is now reporting a heap of 404 errors for tag pages. These tag pages should not have links to them so not sure how come they're being crawled. Any suggestions from experience in this area would be useful.
Technical SEO | | wearehappymedia0 -
Do URLs with canonical tags get indexed by Google?
Hi, we re-branded and launched a new website in February 2016. In June we saw a steep drop in the number of URLs indexed, and there have continued to be smaller dips since. We started an account with Moz and found several thousand high priority crawl errors for duplicate pages and have since fixed those with canonical tags. However, we are still seeing the number of URLs indexed drop. Do URLs with canonical tags get indexed by Google? I can't seem to find a definitive answer on this. A good portion of our URLs have canonical tags because they are just events with different dates, but otherwise the content of the page is the same.
Technical SEO | | zasite0 -
Title tag not showing on google? Please Help!
I've read the FAQs and searched the help center. My URL is: http://www.webygeeks.comI have updated title tags of my client's website 10-15 days ago, still the title on google is coming as the company name 😞 Why so??Description is correct but title is incorrect, can you please recommend me something guys?Also, i am wondering why the google cache is showing date of september 5 and we have changed the titles around 10 - 15 days before that http://webcache.googleusercontent.com/search?q=cache:P45GOiHRaIUJ:www.webygeeks.com/+&cd=1&hl=en&ct=clnk Really appreciate your suggestion.
Technical SEO | | lvp11380 -
Using a non-visible H1
I have a developer that wants to use style="text-indent:-9999px" to make the H1 non-visible to the user. Being the conservative person I am, I've never tried this before and worry that Search Engines may think this is a form of cloaking. Am I worrying about nothing? And apologies if it's already been covered here. I couldn't find it. Thanks in advance!!!!
Technical SEO | | elytical0 -
Duplicate title-tags with pagination and canonical
Some time back we implemented the Google recommendation for pagination (the rel="next/prev"). GWMT now reports 17K pages with duplicate title-tags (we have about 1,1m products on our site and about 50m pages indexed in Google) As an example we have properties listed in various states and the category title would be "Properties for Sale in [state-name]". A paginated search page or browsing a category (see also http://searchengineland.com/implementing-pagination-attributes-correctly-for-google-114970) would then include the following: The title for each page is the same - so to avoid the duplicate title-tags issue, I would think one would have the following options: Ignore what Google says Change the canonical to http://www.site.com/property/state.html (which would then only show the first XX results) Append a page number to the title "Properties for Sale in [state-name] | Page XX" Have all paginated pages use noindex,follow - this would then result in no category page being indexed Would you have the canonical point to the individual paginated page or the base page?
Technical SEO | | MagicDude4Eva2 -
Why "title missing or empty" when title tag exists?
Greetings! On Dec 1, 2011 in a SEOMoz campaign, two crawl metrics shot up from zero (Nov 17, Nov 24). "Title missing or empty" was 9,676. "Duplicate page content" was 9,678. Whoa! Content at site has not changed. I checked a sample of web pages and each seems to have a proper TITLE tag. Page content differs as well -- albeit we list electronic part numbers of hard-to-find parts, which look similar. I found a similar post http://www.seomoz.org/q/why-crawl-error-title-missing-or-empty-when-there-is-already-title-and-meta-desciption-in-place . In answer, Sha ran Screaming Frog crawler. I ran Frog crawler on a few hundred pages. Titles were found and hash codes were unique. Hmmm. Site with errors is http://electronics1.usbid.com Small sample of pages with errors: electronics1.usbid.com/catalog_10.html
Technical SEO | | groovykarma
electronics1.usbid.com/catalog_100.html
electronics1.usbid.com/catalog_1000.html I've tried to reproduce errors yet I cannot. What am I missing please? Thanks kindly, Loren0 -
Robots.txt and canonical tag
In the SEOmoz post - http://www.seomoz.org/blog/robot-access-indexation-restriction-techniques-avoiding-conflicts, it's being said - If you have a robots.txt disallow in place for a page, the canonical tag will never be seen. Does it so happen that if a page is disallowed by robots.txt, spiders DO NOT read the html code ?
Technical SEO | | seoug_20050
