How to fix broken links?
I use WordPress CMS with Yoast SEO plugin. I have just found out that my 403 errors increased dramatically. It seems that all my tags below of each post are being broken for some reason. When i click on the tags i get the following massage: **403 Forbidden Request forbidden by administrative rules. **
I assume it has something to do with the configuration within Yoast SEO plugin.
Dose anyone know how should i fix that?
Thanks,
Raviv
Awesome! Definitely happy you let us know
Hi Dan,
Just wanted to let you know that the problem is fixed at last:)
WP support suggested to check this out with the hosting and bingo! Apparently is happened because of a massive on many WP sites ( Brute Force Attack ) which blocked some of my files and that was the reason for the 403's.
I thought that you might want to know.
Again, thanks so much for your help!!!
Raviv
For sure!
Hi Raviv - great, that will be your quickest source to the answer I think at this stage. Do update us if you can!
-Dan
Hey Dan,
Thanks so much for your help! really!
I still didn't fix it but as you said the tags themselves are broken. when i viewed them in the tags archive i get the same thing guess what? 403!
anyways, I will contact the help forum as you suggested hopefully they'll be able to tell me how to get it done.
Thanks again!
Raviv
Ah good! We've ruled out Yoast. Either one of two things are going on;
1. Tags are simply broken.
2. Maybe the link to the tags are just broken.
Can you adjust the URL at all to get to tags? Maybe the links are adding something extra in the URL making it incorrect? Or you can't get to tags at all. From within the Admin section, try going to Posts->Tag and hovering over a tag click "view" to try and view that tag archive. If it's still broken then it's tags themselves.
Either way this is leaning more towards a development issue, and maybe you want to contact the help department for your theme, or try the WordPress help forum.
-Dan
Hey Dan,
So I've tested it and it seems that I still get those broken links even when the Yoast plug in was disabled. In both tests i got the same results- 403.
Any suggestions of how to fix it?
Cheers,
Raviv
Hi Raviv
Yes, go to plugins and hit "disable" - you shouldn't lose your information, but I would take screenshots or write down of your settings just in case. Definitely don't delete the plugin - just disable it temporarily.
Let me know!
-Dan
Hi Dan!
Thanks for helping here!
2nd test result - even when I'm not being logged in to WP then I still get the 403 error
with regard to the 1st test ( shunting off the plugin) : 1 ) shall i do it by the 'deactivate' function in the plugins section? or is it something in I need to do withing the setting of Yoast plug in itself.
- either way is shutting off the plug in means that I will have to reconfigure the plugin from the beginning after switching it back on?
Sorry ... I'm still very new to this
Thanks Again
Raviv
Raviv
Just to make sure we're not assuming incorrectly, temporarily shut off the Yoast SEO plugin. This should be fine to do for just a few minutes. Do you still get the 403 errors? If so, then it is not the Yoast plugin but some other issue.
Also, do you get this error while logged out of WordPress? Trying doing it on your site in incognito mode in Chrome without logging in.
Let us know what happens with both of those tests!
-Dan
Hi Ed,
Thanks for that! But I need now to find out how to fix those broken links
Cheers,
Raviv
Hi Raviv,
I used this Worpress plugin to fix my broken links, hope it helps http://w-shadow.com/blog/2007/08/05/broken-link-checker-for-wordpress/
Regards
Ed
302 redirects in Magento, trying to fix
Hi all, I'm assigned a site in Magento. After the first craw, we found almost 15k 302 redirects. A sample URL ends with this /stores/store/switch/?SID=qdq9mf1u6afgodo1vtvk0ucdpb&___from_store=default&___store=german&uenc=aHR0cHM6Ly9qdWljeWZsdXRlcy5jb20vP19fX3N0b3JlPWdlcm1hbg%2C%2C And they are currently 302 redirecting to the homepage as well as other main pages and also product pages it seems. Some of these point to account pages where customers log in. Probably best for me to de-index those so no issues there. But I'm worried about the 302 redirects to public pages. The extension we have installed is SEO Suite Ultimate by MageWorx. Does anyone here have experience here specifically and how did you fix it? Thanks, JC
Technical SEO | | LASClients0 -
How to fix Google index after fixing site infected with malware.
Hi All Upgraded a Joomla site for a customer a couple of months ago that was infected with malware (it wasn't flagged as infected by google). Site is fine now but still noticing search queries for "cheap adobe" etc with links to http://domain.com/index.php?vc=201&Cheap_Adobe_Acrobat_xi in web master tools (about 50 in total). These url's redirect back to home page and seem to be remaining in the index (I think Joomla is doing this automatically) Firstly, what sort of effect would these be having on on their rankings? Would they be seen by google as duplicate content for the homepage (moz doesn't report them as such as there are no internal links). Secondly what's my best plan of attack to fix them. Should I setup 404's for them and then submit them to google? Will resubmitting the site to the index fix things? Would appreciate any advice or suggestions on the ramifications of this and how I should fix it. Regards, Ian
Technical SEO | | iragless0 -
Links from the same server has value or not
Hi Guys, Sometime ago one of the SEO experts said to me if I get links from the same IP address, Google doesn't count them as with much value. For an example, I am a web devleoper and I host all my clients websites on one server and link them back to me. Im wondering whether those links have any value when it comes to seo or should I consider getting different hosting providers? Regards Uds
Technical SEO | | Uds0 -
How do I fix the h1 tag?
No More Than One H1 Tag Easy fix <dl> <dt>Number of H1s</dt> <dd>2</dd> <dt>Explanation</dt> <dd>Best practices for both SEO and accessibility require only a single H1 tag. The H1 is meant to be the page's headline, and thus, multiple H1s are confusing. Consider employing H2, H3 or CSS styles to achieve the same results with text visualization.</dd> <dt>Recommendation</dt> <dd>Remove multiple instances of the H1 tag, so that only one exists on the page.</dd> <dd>I get this error yet it does not tell me how to fix it. I'm not even sure what the H1 tag is?
Technical SEO | | 678648631264
</dd> </dl>0 -
Advice on Linking to an Adult Related Website
I have a question regarding whether or not Google would penalize my main website for linking to a website that has adult content. The site I am linking to is not a porn site, rather it is a site that sells web site templates for adult related stores selling sexy toys, videos, etc. For example my site that is linking to the adult related website is here: http://www.websitetemplatedesign.com/ and the link to the site is in the footer at the bottom left which is an icon. And it links to http://www.adultsextemplates.com/ Im just looking for advice as to whether or not this could be a penalty or not. I did suffer major SERP loss in the last month and Im trying to find what I am doing that may have caused this. Any advice would be appreciated.
Technical SEO | | jmccommas0 -
Does the Referral Traffic from a Link Influence the SEO Value of that Link?
If a link exists, and nobody clicks on it, could it still be valuable for SEO? Say I have 1000 links on 500 sites with Domain Authority ranging from 35 to 80. Let's pretend that 900 of those links generate referral traffic. Let's assume that the remaining 100 links are spread between 10 domains of the 500, but nobody ever clicks on them. Are they still valuable? Should an SEO seek to earn more links like those, even though they don't earn referral traffic? Does Google take referral data into account in evaluating links? 5343313-zelda-rogers-albums-zelda-pictures-duh-what-else-would-they-be-picture3672t-link-looks-so-lonely.jpg Sad%20little%20link.jpg
Technical SEO | | glennfriesen1 -
Add to Cart Link
We have shopping cart links (<a href's,="" not="" input="" buttons)="" that="" link="" to="" a="" url="" along="" the="" lines="" of="" cart="" add="" 123&return="/product/123. </p"></a> <a href's,="" not="" input="" buttons)="" that="" link="" to="" a="" url="" along="" the="" lines="" of="" cart="" add="" 123&return="/product/123. </p">The SEOMoz site crawls are flagging these as a massive number of 302 redirects and I also wonder what sort of effect this is having on linkjuice flowing around the site. </a> <a href's,="" not="" input="" buttons)="" that="" link="" to="" a="" url="" along="" the="" lines="" of="" cart="" add="" 123&return="/product/123. </p">I can see several possible solutions: Make the links nofollow Make the links input buttons Block /cart/add with robots.txt Make the links 301 instead of 302 Make the links javascript (probably worst care) All of these would result in an identical outcome for the UX, but are very different solutions. What would you suggest?</a>
Technical SEO | | Aspedia0 -
How to find links to 404 pages?
I know that I used to be able to do this, but I can't seem to remember. One of the sites I am working on has had a lot of pages moving around lately. I am sure some links got lost in the fray that I would like to recover, what is the easiest way to see links going to a domain that are pointing to 404 pages?
Technical SEO | | MarloSchneider0
