Footer Links And Link Juice
I'm starting to learn about link juice and notice in GWMT > Traffic > Internal Links, that the list is in this order by the links counted on each page. Some are in the footer and some are in the header, with some being more important than others commercially i.e. /register
/privacy
/terms
/search
/sitemap
/disclaimer
/blog
/register
So I am wondering if I should add a 'no-follow' attribute to the footer links i.e. privacy, terms, disclaimer and leave the others as they are? Does this help retain link juice on each page where the links appear? Or am I missing the point all together?
This is my website: http://goo.gl/CN0e5
there are ways around it though such as obfuscated javascript linking and other methods of making a link unrecognized as a link
Fair point about disrupting the flow, I will leave the footer links as they are.
Some of the links are at the top of the page with Register being a call to action.
Thx.
Hmmmm.... a search form has been on my mind as I would track what people enter and then include them in my keyword research. Top tip!!
Thanks for the link, this video answered a few of my niggles about footer links!
Just to add to the consensus (although credit goes to multiple people on the thread) - PR-sculpting with nofollow on internal links no longer works, and it can be counter-productive. If these links are needed for users, don't worry about them, and don't disrupt PR flow through your site. Ultimately, you're only talking about a few pages, and @sprynewmedia is right - Google probably discounts footer links even internally (although we may no good way to measure this).
Be careful with links like "register", though, because sometimes they spin off URL variations, and you don't want those all indexed. In that case, you'd probably want to NOINDEX the target page - it just doesn't have any search value. I'm not seeing that link in your footer, though, so I'm not clear on what it does. I see this a lot with "login" links.
A no-follow, in terms of juice, would actually hurt your goals as the link still gets allocated the juice portion but it doesn't flow through. **Each no-follow link will siphon off a little juice. **
See http://support.google.com/webmasters/bin/answer.py?hl=en&answer=96569
The effects of navigational links are diminished somewhat as Google treats them differently compared to content links. To help solidify this, surround the footer with
<nav></nav>
tags.
Review: http://www.seomoz.org/blog/10-illustrations-on-search-engines-valuation-of-links #5
Generally, remove any site wide links that aren't always needed and place them on page where users would like the details. For instance, use a search form instead of a link to the search page.
No this won't work. it's called pagerank sculpting and used to work but Google fixed that a couple of years ago by making the nofollow counts as a link and instead all you are doing is throwing away your page juice.
Hi there,
John Doherty did a really good whiteboard friday on this last year:
http://www.seomoz.org/blog/smarter-internal-linking-whiteboard-friday
You could add a noindex if you think the privacy and disclaimer pages, etc, are not bringing any SEO value. Nofollow would block search engines from even spidering them. But a noindex would just stop it from showing up as an entrance/landing page in the SERPs.
I wouldn't say that it helps "retain link juice", but it might help you to show the search engines what your most important pages are.
An alternative would be to perhaps only link to some of those pages from your home page and not from every single page. Are there any pages that you think would be appropriate NOT to link to all those pages? If so, perhaps you can write a conditional statement in your code to only show those links on some pages and not others.
Scott O.
Backlinks vs External Links vs Referral Links vs Outbound links
Hello all, I was just wondering if you could explain the difference between all the links above? I'm confused as they all seem to be the same or similar and I would just like to clearly know what distinguishes them from eachother. Thanks for your help, Jayne
Link Building | | NCOREGSEO0 -
Internal Linking - Post links vs Side Bar Links behaving differently
Hi, I have a question regarding the internal linking behavior. My website is www.hindimeaning.com which is approx 3 years old. I have approx 450 posts. Now i have a widget on right sidebar "Popular posts". A widget below my posts "Related Posts". And a simple html CSS menu above the posts (I removed menu around 6 month before so currently it will not show.) I crawled my site with moz crawler (same are the result from google crawler as well) and it shows menus links as internal links. While sidebar widget "Popular posts" and "Related Posts" are not showing as internal links. If we talk theoretically what i learn till now is "every link on a page behaves as internal link". Then why the widget links are not showing as internal links. Thanks, Mahesh Kumar
Link Building | | chaudhary04890 -
What is a good ratio of total links to linking root domains?
Is 100 total links for every linking domain too high? I suppose I could also look at ratios of sites that are doing well in the rankings.
Link Building | | ProjectLabs0 -
A link with "return false"- OSE sees as a No Followed Link
Hello, I couldn't find a clear answer to the impact on SEO for a link written in this way: [" class="expert_info" onclick="window.open(this.href);return false;">](w</span>ww.yourwebsite.com<span style=) [Does the "return false" act as a "no follow"? I came across this in our link data in Open Site Explorer which lists these links all as "no follows." However, an engineer I spoke to said that it shouldn't impact search engine behavior. Any ideas? Thank you in advance! -Sarah K.](w</span>ww.yourwebsite.com<span style=)
Link Building | | OneMedical0 -
Link Detox and Link Removal
I have a question about which links to remove after running a link detox from Link Research Tools. First a little back story. I had had an SEO company link building for one of the websites I own. But I have recently stopped working with them. In the last month my rankings have near dropped off the charts. I have just recently gotten access to Google webmaster tools and noticed an unnatural link warning from back in March. So yesterday I ran link detox and it reported 19 toxic links, 120 suspicious links, and 24 healthy links. It's rather obvious that I should remove all of the toxic links. They all from sites that have been deindexed by google. But my question is a about the suspicious links. What should my criteria be for removing them? Am I better off removing them all and leaving my site with only 24 healthy links or should I personally comb through them and remove only the worst of the worst so that I leave my site with a few more links? I'd really like to get the site ready to resubmit to google as soon as I can. Thoughts? yyCOf.png
Link Building | | CobraJones950 -
Links on the same keyword
When is linking from one particular keyword to much. At what point could link building from one keyword be considered spam and potentially delist a site ? Is it possible for a site to be delisted for having to many links from the same keyword ? Heard linking from the website name is more important following recent changes. I try and link from a selection of 3 to 4 keywords. Thanks for your help
Link Building | | onlinemediadirect0 -
Does linking to a subdomain give link juice to the main domain?
I have a few domains that I'm going to use for link building, will the link juice from the sub domains transfer to the main domain?
Link Building | | Vsky0 -
Porn link ...
I just ran https://www.majesticseo.com report for back links and showed me that I have one link at porn site ... not sure if it will be appropriate to post it here. The link was discovered on 03.05.11 and when I visited today link is not there... I dont know who put that link there. Can I get penalty for that from google? Can it be a mistake?
Link Building | | DiamondJewelryEmpire1
