Dofollow and Nofollow links
What is the difference between dofollow and nofollow links? I know that some sites/blogs only let you post nofollow links. In such a case how do I know if a comment I posted on a certain site will be a nofollow or dofollow? How about big traffic sites such as Huff Post. Do they only allow nofollow links?
Dofollow letting the bot crawl the target page
Thank you for the help Tom!
dofollow links pass "SEO Juice".
nofollow links do not pass "SEO Juice".
If your curious as to whether or not a particular blog allows for dofollow links, you can view the source code of the webpage using any common web browser. Find the link in question, and look to see if it includes "rel=nofollow". If that tag doesn't exist, then the link is dofollow.
Presuming that you're going to be linking to your website in the comment, I'd probably keep it limited to your own niche, but there's definitely room for a few comments from other industries.
If your comments are engaging, provide value to that blog's community and are not on blogs that are spammed to death, then you won't be doing any harm. The key is to comment something of worth and to integrate yourself into the community.
I always think of blog commenting as a way of establishing a community presence and to raise unaided brand awareness. Any subsequent link of page strength is an after-thought for me.
Thanks for the reply Tom, you were really helpful.
I had another question regarding the process of commenting on blogs/articles. Should I only comment on blogs/articles that are relative to my own niche or can I also comment and link from blogs/articles that are outside my niche?
Hi. Everything Tom said and I also wanted to add another extension to this - If you use Firefox this is for checking nofollow and dofollow links. When you add the extension, if you right click and select the nodofollow it hghlights nofollows in red and dofollows in blue. I use it all the time.
A dofollow link will pass the SEO strength, or "PageRank" of the page to the site that it links to. A nofollow link, in theory, will not do this. That's the main difference between the two.
By that logic, you may assume that a nofollow link will not help you rank for a keyword, but I don't think this is completely the case. Having a link to your site in any capacity may improve the "authoritativeness" of your site. SEOMoz uses Page Authority and Domain Authority to measure this and, while not an official Google metric, it stands to say that if you have 2 identical sites, one has 5 nofollow links from newspapers and the other has none, Google may well think that the site with the links has more authority or trust and may treat it more favourably. We all know how much Google loves to promote real brands.
As for seeing if a link is dofollow or nofollow, you can either inspect the element in the source code, or a convenient and hassle-free way to test is with the SEOMoz toolbar. That toolbar contains an option to highlight the links on the page - green links are dofollow and pink links are nofollow. If you check previous posts on any website, you should be able to see a pattern of whether they allow for dofollow or nofollow links - but in the end, this is at the discretion of the webmaster.
Hope this helps!
Static Links in Sidebar Hurting SEO?
Our website currently has a sidebar/widget area that appears on almost all pages throughout of entire site (350 page domain). In that sidebar, we have some static links and some non-static links. Right now there are: 6 Related Post Links - Non-Static
Technical SEO | | DemiGR
1 - Call To Action - Static to a landing page
10 Calculators - Static - These calculators I think are very useful to our users (financial website). So in total 17 total sidebar links, 11 static links, and 6 which change based on the content of the page. Do you think these static links from an SEO perspective can be hurting us? Is there some sort of best practice for sidebar links in regards to quantity as well as static vs non-static? Thanks!0 -
How does link juice flow through hreflang?
We want to use the hreflang tag on our site (direct users searching for the Spanish version of spanishdict.com to spanishdict.com/traductor). Before doing so, we were wondering how link juice flows through hreflang? Any insight or resources on this would be very helpful. Thanks!
Technical SEO | | CuriosityMedia0 -
Self Referencing Links - Good or Bad?
As an agency we get quite a few of our clients come to us saying "Ooo, this company just contacted me saying they've run an SEO report on my site and we need to improve on these following things" We had one come through the other day that had reported on something we had not seen in any others before. They called them self-referencing links and marked it as a point of action should be taken. They had stated that 100% of the pages on our clients website had self-referencing links. The definition of self-referencing is when there is a link on a page that is linking to the page you are currently on. So for example you're on the home page and there is a link in the nav bar at the top that says "Home" with a link to the home page, the page you are already currently on. Is it bad practice? And if so can we do anything about it as it would seem strange from a UI point of view not to have a consistent navigation. I have not heard anything about this before but I wanted to get confirmation before going back to our client and explaining. Thanks Mozzers!
Technical SEO | | O2C0 -
Correct linking to the /index of a site and subfolders: what's the best practice? link to: domain.com/ or domain.com/index.html ?
Dear all, starting with my .htaccess file: RewriteEngine On
Technical SEO | | inlinear
RewriteCond %{HTTP_HOST} ^www.inlinear.com$ [NC]
RewriteRule ^(.*)$ http://inlinear.com/$1 [R=301,L] RewriteCond %{THE_REQUEST} ^./index.html
RewriteRule ^(.)index.html$ http://inlinear.com/ [R=301,L] 1. I redirect all URL-requests with www. to the non www-version...
2. all requests with "index.html" will be redirected to "domain.com/" My questions are: A) When linking from a page to my frontpage (home) the best practice is?: "http://domain.com/" the best and NOT: "http://domain.com/index.php" B) When linking to the index of a subfolder "http://domain.com/products/index.php" I should link also to: "http://domain.com/products/" and not put also the index.php..., right? C) When I define the canonical ULR, should I also define it just: "http://domain.com/products/" or in this case I should link to the definite file: "http://domain.com/products**/index.php**" Is A) B) the best practice? and C) ? Thanks for all replies! 🙂
Holger0 -
How to fix broken links?
Hi, I use WordPress CMS with Yoast SEO plugin. I have just found out that my 403 errors increased dramatically. It seems that all my tags below of each post are being broken for some reason. When i click on the tags i get the following massage: **403 Forbidden Request forbidden by administrative rules. ** I assume it has something to do with the configuration within Yoast SEO plugin. Dose anyone know how should i fix that? Thanks, Raviv evsGujA
Technical SEO | | Indiatravelz0 -
How to find and fix 404 and broken links?
Hi, My campaign is showing me many 404 problems and other tools are also showing me broken links, but the links they show me dose work and I cant seem to find the broken links or the cause of the 404. Can you help?
Technical SEO | | Joseph-Green-SEO0 -
Does Yelp pass link juice?
This is probably a profoundly obvious question, but I can't seem to find an explicit answer on the internet, so I'll ask it here: Yelp's links out to local business websites are not nofollow'd, but they go through a javascript-based redirect. My understanding is that javascript redirected links do not pass link juice, so a link from a yelp profile will not directly impact my page authority; however, it looks like yelp does use nofollow judiciously for internal links, so I don't understand why they would allow follow for these "useless" outbound links. Do yelp's javascript-redirected links pass link juice?
Technical SEO | | tvkiley0 -
Link Volume - calculate what you need?
Hi everyone, an interesting question here. How do you determien what link volume you should try and get into your website? What analysis do you do to determine the number of links you feel is right to go into a back-link profiel every month? obviously there is no magic number but its an interesting question to know what others do. Obviously you don't want to build too many or too little. If you have been penalised for bad links in the past and are now back on track - how do you calculate the volume? Do you take links dropping out into consideration?
Technical SEO | | pauledwards0
