How does a search engine bot navigate past a .PDF link?
We have a large number of product pages that contain links to a .pdf of the technical specs for that product. These are all set up to open in a new window when the end user clicks.
If these pages are being crawled, and a bot follows the link for the .pdf, is there any way for that bot to continue to crawl the site, or does it get stuck on that dangling page because it doesn't contain any links back to the site (it's a .pdf) and the "back" button doesn't work because the page opened in a new window?
If this situation effectively stops the bot in its tracks and it can't crawl any further, what's the best way to fix this?
1. Add a rel="nofollow" attribute
2. Don't open the link in a new window so the back button remains finctional
3. Both 1 and 2
or
4. Create specs on the page instead of relying on a .pdf
Here's an example page: http://www.ccisolutions.com/StoreFront/product/mackie-cfx12-mkii-compact-mixer - The technical spec .pdf is located under the "Downloads" tab [the content is all on one page in the source code - the tabs are just a design element]
Thoughts and suggestions would be greatly appreciated.
Dana
Thanks very much Christopher. This is an excellent explanation. What do you think of Charlie and EGOL's suggestions regarding making sure that there are links embedded in these PDFs pointing either back to the product page or even to the home page?
In your opinion, is this something worth doing? If so, why?
Hi Dana,
" ... you are right, one of the fundamental questions I still have is how does a bot behave when it finds an orphaned page like one of these? Does it just revert back to the sitemap and move one? Does it automatically go back to the last non-dead end page and move on from there? What does it do?"
Bots are not really like a single spider that has to crawl around the web that can get trapped when entering an orphaned page with no back-button. When a bot enters a site, it creates a list of all the internal pages that are linked from the home page. Then it visits each page on that list and keeps adding more linked pages to that list. Each time it adds more pages to the list, it only adds new unique pages and does not add duplicates. It also keeps track of which pages it has already visited. When all the pages have been visited once, and no new pages are discovered that are not already on the list, all of the pages have been crawled.
Best,
Christopher -
Hi Don,
Thanks so much for responding and while the answers I have received so far did give me some direction, you are right, one of the fundamental questions I still have is how does a bot behave when it finds an orphaned page like one of these? Does it just revert back to the sitemap and move one? Does it automatically go back to the last non-dead end page and move on from there? What does it do?
Thanks for chiming in. I'd love it if someone more familiar with how a bot actually crawls links like this on a page would jump in with an answer.
Dana
Thanks Charlie. I think this is a good suggestion. I work 9-6 too, and just so happen to be the in-house SEO strategist, so this stuff is what I'm there to do. I don't mind the mundane aspects of SEO because the payoff is usually pretty rewarding! Now I know what I'm doing on Monday (on top of a dozen other things!)
Thanks again!
I would spend the time needed to do an assessment of these pages.
** how many of them have external links
** how many of them pull traffic from search or other sites
** how many of them are currently useful (are people looking at them)
I would delete (and redirect the URL) of any page that answers "no" to the three items above. These are "dead weight" on your site.
Also, if these are .pdfs of print ads then they might simply be images in a pdf. (test this by searching for an exact phrase from one of them in quotes and include site:yourdomain.com in the query. Keep in mind that google can read the text in some images embedded in pdfs.
I had a lot of pdfs with images on one of my site and got hit with a panda problem. I think that Google thought that the .pdfs were thin content. So I used rel=canonical to assign them to the most relevant page using .htaccess. The panda problem was solved after a couple of months.
Also, keep in mind that .pdfs can be used for conversions. You can embed "add to cart" buttons and links into them and they will function just as on a web page.
If any of these pdfs are pulling in tons I traffic I would figure out how I can put the pdf to better use or create webpage (and redirect the pdf) to best monetize/convert or whatever you business goals dictate.
Can a bot navigate via a back button?
I don't think so. They can follow links but they can't "click".
Hi Dana
I think your question has been dodged a tad. I ways lead to understand that a .pdf or any page that opens in a new tab and does not link back to the original site, (dangling page) is not a problem. The reason being is that crawlers don't really care how a page is opened. Because the crawler will fork at every link and crawls each new page/link from each fork, when it finds a orphan or dangling page it just stops. This of course is not an issue since if the crawler has forked at each link.
So the question is how a SE treats .pdf's rather how does it treat orphan page. Maybe somebody who works with crawlers can confirm or educate us both on they work.
Don
Many thanks to both you and EGOL for excellent answers!
Thanks EGOL. Yes, many of these .pdfs could be and are referenced by other sites. Given that there's no link from the .pdf back to our site, we really are missing out on a huge opportunity. I thought this might be the case as I pondered the whole concept of "dangling links" that was discussed in a SEOMoz blog post this week.
I agree about the last point regarding opening in a new window being more of a usability issue than a problem for SEO. I agree with you completely that opening in the same window is way better for the end user.
Thanks very much to both you and Charlie for your excellent answers!
lol, thank heaven's they aren't spammy. However, they aren't particularly helfpul either. You see, about 3,000 of them are old .pdf versions of print advertising campaigns, going back as far as 2005. They contain obsolete pricing, products, etc. Unfortunately, instead of archiving them off the server, they've been continuously archived in a sub-directory of our main website.
Nearly all of it is indexed. It seems to me the best thing to do for these is to include a statement that the content is an old advertisement and include a llnk to our current "special offers" page.
What do you think of that as a strategy for at least giving engines and humans a means to navigate to someplace current on the site?
I see 6000 pdfs as an amazing opportunity. Get links on those pages and it will funnel a lot of power through your site.
If that was my site, we would be on that job immediately. Could be a huge gain for some easy work.
Go back and rework our .pdfs so they at least contain a link back to the homepage?
Yes! Absolutely! And, link them to other relevant pages. If these are reference documents they could be pulling in a lot of links and traffic from other sites.
In addition toAs well as configure the hyperlinks so they open in the same window instead of a new one?
In my opinion, this is not an SEO issue. This is a usability issue. I would have them open in the same window so the back button is available.
Thank you Charlie. In our case, our .pdfs contain no links in them at all. There is nothing for a bot (or a human) that will navigate them out of the .pdf....not even the back button.
Considering that, and EGOL's response below, would the best course of action be to include, at the very least, an active link back to our homepage from all of our .pdf files?
We have as many as 6,000 .pdfs.
Thanks,
Dana
Thanks EGOL,
Yes, I understand well that .pdf documents can be indexed. That's not my concern. My concern is that a bot that navigates to one of our many .pdf tech specs documents, which, incidentally, contains no outbound links to anything, would then become trapped and not be able to continue crawling the site. This is particularly true because we have them set up to open in a new window. In the example above, sure, there's a text reference back to the site "www.kingdom.com" - but it isn't a link in the .pdf. There are no links, in any of our .pdfs.
So, what is the best way to deal with this? Go back and rework our .pdfs so they at least contain a link back to the homepage? In addition toAs well as configure the hyperlinks so they open in the same window instead of a new one?
.pdf documents are crawled by bots and they accumulate pagerank just like .html pages.
You can include links in them to other documents on the web and bots will crawl those links and pagerank will flow through them.
.pdf documents can be given a "title tag" equivalent by opening their properties and giving the document a title. This title will display in the SERPs. .pfd documents can be hard to beat in the SERPs if they are optimized and have links from a competitive number of other web documents.
Lots of document formats behave this way. Excel, PowerPoint, Word for example.
In my opinion, .pdf documents can trigger a Panda problem for your site if you have a lot of them with trivial or duplicate content (as in print versions of web documents). They can be given rel=canonical through .htaccess to solve the Panda problem but Google often takes a long long time (sometimes months) to recognize the canonical and use that instruction.
Broken canonical link errors
Hello, Several tools I'm using are returning errors due to "broken canonical links". However, I'm not too sure why is that. Eg.
Technical SEO | | GhillC
Page URL: domain.com/page.html?xxxx
Canonical link URL: domain.com/page.html
Returns an error. Any idea why? Am I doing it wrong? Thanks,
G1 -
Referencing links in Articles and Blogs
Hi I am wondering if the <sup>tag in html is picked up by google as a reference point?</sup> I.e when you put a superscript in word it puts a small number next to your sentence. Then you have a list of reference at the end of the blog/article does google recognise this?
Technical SEO | | Cocoonfxmedia0 -
Links from Instructables.com?
This is a silly newbie question. But will posting on www.instructables.com with some valuable content and url link back to my site help with "linking"? Or do they put a no-follow on all links on their site? Thanks for answering! Ron
Technical SEO | | yatesandcojewelers0 -
How to allow googlebot past paywall
Does anyone know of any ways or ideas to allow Google/Bing etc. to index your content, but have it behind a paywall for users?
Technical SEO | | MirandaP0 -
Forum Profile Links
Are they really important? Many preach they are, and there are tonnes of services out there who give you thousands of forum profile links in no time. I strictly believe in genuine links built the hard way, and definitely don't want to get into anything which is black hat. Please suggest if building several Forum Profile Links is an appropriate way of building links?
Technical SEO | | KS__2 -
Image search and CDNs
Hi, Our site has a very high domain strength. Although our site ranks well for general search phrases, we rank poorly for image search (even though our site has very high quality images). Our images are hosted on a separate CDN with a different domain. Although there are a number of benefits to doing this, since they are on a different domain, are we not able to capitalize on our my site's domain strength? Is there any way to associate our CDN to our main site via Google webmaster tools? Has anyone researched the search ranking impacts due to storing your images on a CDN, given that your domain strength is very high? Curious on people's thoughts?
Technical SEO | | NicB10 -
How to stop Search Bot from crawling through a submit button
On our website http://www.thefutureminders.com/, we have three form fields that have three pull downs for Month, Day, and year. This is creating duplicate pages while indexing. How do we tell the search Bot to index the page but not crawl through the submit button? Thanks Naren
Technical SEO | | NarenBansal0 -
Is link cloaking bad?
I have a couple of affiliate gaming sites and have been cloaking the links, the reason I do this is to stop have so many external links on my sites. In the robot.txt I tell the bots not to index my cloaked links. Is this bad, or doesnt it really matter? Thanks for your help.
Technical SEO | | jwdesign0
