Xml sitemap advice for website with over 100,000 articles
I have read numerous articles that support submitting multiple XML sitemaps for websites that have thousands of articles... in our case we have over 100,000. So, I was thinking I should submit one sitemap for each news category.
My question is how many page levels should each sitemap instruct the spiders to go? Would it not be enough to just submit the top level URL for each category and then let the spiders follow the rest of the links organically?
So, if I have 12 categories the total number of URL´s will be 12???
If this is true, how do you suggest handling or home page, where the latest articles are displayed regardless of their category... so I.E. the spiders will find l links to a given article both on the home page and in the category it belongs to. We are using canonical tags.
Thanks,
Jarrett
It's really a process of experimenting over time to find out the method that results in the most URLs indexed that in turn brings the most relevant traffic. Personally I wouldn't have one for each category, yet without tests there's no conclusive reasoning either way.
Thanks for the tip... I will do that.
I´m still unsure if I really need to submit a sitemap with thousands of URL´s I was thinking I should create an sitemap index file the points to individual top level category sitemaps and leave it at that. If I do this though, I suppose I don´t need individual sitemaps per category as I will just insert the category URL´s in the root sitemap. What do you think?
To add to Corey's response, I'll repeat what I just provided another question here on Pro Q&A. Sitemap.xml files can handle a maximum of 50,000 URLs, however I've seen them choke with as few as 10,000. Its important to run them through a tool like tools.pingdom.com to ensure they load within just a couple seconds.
Then submit them through Google/Bing webmaster systems and then see if they succeed in crawling all of them.
We break up our sitemap files into several different site maps, and then use a sitemap index file to make sure Google finds them all.
At the bottom of this post they talk about using an index file to combine multiple sitemaps, and they also specifically say it is fine to have one time sensitive site map (ie: front page items) and several other less time sensitive ones (categories in your case).
http://googlewebmastercentral.blogspot.com/2006/10/multiple-sitemaps-in-same-directory.html
Pending Sitemaps
Hi, all Wondering if someone could give me a pointer or two, please. I cannot seem to get Google or Bing to crawl my sitemap. If I submit the sitemap in WMT and test it I get a report saying 44,322urls found. However, if I then submit that same sitemap it either says Pending (in old WMT) or Couldn't fetch in the new version. This couldn't fetch is very puzzling as it had no issue fetching the map to test it. My other domains on the same server are fine, the problem is limited to this one site. I have tried several pages on the site using the Fetch as Google tool and they load without issue, however, try as I may, it will not fetch my sitemap. The sitemapindex.xml file won't even submit. I can confirm my sitemaps, although large, work fine, please see the following as an example (minus the spaces, of course, didn't want to submit and make it look like I was just trying to get a link) https:// digitalcatwalk .co.uk/sitemap.xml https:// digitalcatwalk .co.uk/sitemapindex.xml I would welcome any feedback anyone could offer on this, please. It's driving me mad trying to work out what is up. Many thanks, Jeff
Intermediate & Advanced SEO | | wonkydogadmin0 -
Do you suggest I use the Yoast or the Google XML sitemap for my blog?
I just shut off the All-In-One seo pack plugin for wordpress, and turned on the Yoast plugin. It's great! So much helpful, seo boosting info! So, in watching a video on how to configure the plugin, it mentions that I should update the sitemap, using the Yoast sitemap I'm afraid to do this, because I'm pretty technologically behind... I see I have a Google XML Sitemaps (by Arne Brachhold) plugin turned on (and have had it for many years). Should I leave this one on? Or would you recommend going through the steps to use the Yoast plugin sitemap? If so, what are the benefits of the Yoast plugin, over the Google XML? Thanks!
Intermediate & Advanced SEO | | DavidC.0 -
Sitemap on a Subdomain
Hi, For various reasons I placed my sitemaps on a subdomain where I keep images and other large files (static.example.com). I then submitted this to Google as a separate site in Webmaster tools. Is this a problem? All of the URLs are for the actual site (www.example.com), the only issue on my end is not being able to look at it all at the same time. But I'm wondering if this would cause any problems on Google's end.
Intermediate & Advanced SEO | | enotes0 -
302 redirects in the sitemap?
My website uses a prefix at the end to instruct the back-end about visitor details. The setup is similar to this site - http://sanfrancisco.giants.mlb.com/index.jsp?c_id=sf with a 302 redirect from the normal link to the one with additional info and a canonical tag on the actual URL without the extra info ((the normal one here being http://sanfrancisco.giants.mlb.com,) However, when I used www.xml-sitemaps.com to create a sitemap they did so using the URLs with the extra info on the links... what should I do to create a sitemap using the normal URLs (which are the ones I want to be promoting)
Intermediate & Advanced SEO | | theLotter0 -
DNS or 301 Website Redirect
We are running a marketplace site, so we have thousands of vendors selling their products on our site. Each vendor has a Profile page and we are soon to launch a premium store-front that is white label. Many of these vendors will want to point a custom url to their premium store-front (which is a sub domain of the marketplace) and we are trying to get an understanding of how we should instruct them to point their url in a way that will give the main marketplace site the seo juice. We also want to understand what will show up in the address bar. Will it be their url or our sub domain? Will any of the marketplace seo juice boost their url local listing status?
Intermediate & Advanced SEO | | bloomnation0 -
100 + links on a scrolling page
Can you add more than 100 links on your webpage If you have a webpage that adds more content from a database as a visitor scrolls down the page. If you look at the page source the 100 + links do not show up, only the first 20 links. As you scroll down it adds more content and links to the bottom of the page so its a continuos flowing page if you keep scrolling down. Just wanted to know how the 100 links maximum fits into this scenario ?
Intermediate & Advanced SEO | | jlane90 -
Where to link to HTML Sitemap?
After searching this morning and finding unclear answers I decided to ask my SEOmoz friends a few questions. Should you have an HTML sitemap? If so, where should you link to the HTML sitemap from? Should you use a noindex, follow tag? Thank you
Intermediate & Advanced SEO | | cprodigy290 -
Create a new XML Sitemap for a blog subdomain?
What would be the best way to go about this? A site just put a blog on http://blog.domain.com/ Should there be a separate XML Sitemap for that particular subdomain or should the original XML Sitemap for the main domain be sufficient? Looking forward to your responses. Thanks
Intermediate & Advanced SEO | | iAnalyst.com0
