My Site Is Using A Lot of Hosting Bandwidth. Suggestions?
My website http://www.socialseomanagement.com/ is using tons of bandwidth. I received a message from the hosting company saying I exceeded my monthly bandwidth and it has only been a few days. Can anyone take a look and make suggestions?
Something doesn't sound right there. You can't have 3112 unique visits from 12093 unique visitors, unless your log file program is using those terms in a different way. If your log file program lets you, you should be able to see which files haven been using the most bandwidth.
As of the October 4th these were my statistics for the month of October:
These statistics are based on the October 2012, so far:
- 427K hits
- 3112 unique visits from 12K sources
- 2.65GB data
- 12093 unique visitors
Hmm.. Based on the other responses above my load time was not very long. Did you try visiting more than once?
Is there a way to test the speed of the server also? I am checking my server logs as you suggested to see if someone is linking to our images...
The reason the site "looks" to tools like it takes a long time to load is because the Google+ API call and the Facebook Connect call are taking an obscenely long time to negotiate their SSL connections - over 11 seconds.
Fortunately the essential user-visible parts of the page (up to document complete) load quickly so the user experience is fine. Might be worth trying to figure out why the SSL negotiation on those 2 files is getting killed so badly though.
Here's a link to the page load Waterfall View that clearly shows the long purple lines indicating SSL delay for those 2 scripts.
Your homepage is a little over 900kb which isn't massive by any means. Your homepage loads in a little over 3.5 seconds from a Virginia location using the equivalent of a slow cable connection so it looks very-well speed optimized to me.
If you've seen that big a jump in bandwidth use with no accompanying jump in traffic, my strong guess is that some other site is leaching your content (otherwise known as hotlinking).
Typically, this means somebody else has embedded images from your site into their own, meaning every time their page displays the image, it loads form your server/bandwidth instead of their own. (Can also happen with other file types)
Some sites do this because they don't know any better, and sometimes it's malicious. I've seen this often happen from forums where a whole page of post images loads every time the thread is viewed. To see if this is happening, you'll need to check in your server logs. Google Analytics won't show it as the images aren't tagged with the tracking code.
If hotlinking is the problem, the only way to stop it is to tell your server to only display images that were requested from your own website pages. You do this through the htaccess file. If your site uses cPanel for it's hosting control panel, there's actually a button on the Panel in the Security section to disable hotlinking. I assume most other control panels have something similar. Be aware that this will disable ALL images from showing on other sites, including any badges etc you may have created for other sites to display intentionally.
Do you have plugins?
Load time can be a server issue, a software/coding issue, and/or a filesize issue.
4GB of bandwidth in 4 days is a lot - that's how much my site that gets 30K+ uniques per month has used. Based on Alexa rank, it looks like your site doesn't get that much traffic? Have you had an uptick in traffic?
You can check page and file sizes at http://tools.pingdom.com/fpt/ That tool shows your homepage and associated files has a total size of 1MB. To use 4GB of bandwidth at that rate, you'd need ~4,000 pageviews.
You could run your top pages through that tool and see if any of the embedded images or other files are too large.
You could also check your log files to see if someone has embedded an image from your site, you're getting crawled by robots, etc.
Hope that helps!
Plus the site already caches...
I am using Drupal.
Nearly 4gb in 4 days... The slider images are rather large. Are there any good compression tools? Yahoo smushit didnt make much of a difference.
Any advice on how to make it load faster? Or is that a server issue?
The site appears to use Drupal. A cache plugin may make the pages load faster, but it won't change the amount of bandwidth used.
Well, you're probably either getting more traffic and/or maybe you need to optimize your file sizes.
How much bandwidth have you used?
Usually images or videos are what gobbles up bandwidth. Are you hosting any large images, videos, or files?
Hi James,
Your site loading takes quite some time. Although graphics load quickly, there is still something loading in the background.
I suggest checking out which plugins you are using and disable one by one to see what could be conflicting with the load times.
I'm not sure which CMS you are using but I suggest getting a cache plugin to make loading times more quick if its images slowing load times(probably not since graphics loaded quick).
Load time was pretty long. How are your file sizes?
I am Using <noscript>in All Webpage and google not Crawl my site automatically any solution</noscript>
Web Design | | ahtisham2018
| | <noscript></span></td> </tr> <tr> <td class="line-number"> </td> <td class="line-content"><meta http-equiv="refresh" content="0;url=errorPages/content-blocked.jsp?reason=js"></td> </tr> <tr> <td class="line-number"> </td> <td class="line-content"><span class="html-tag"></noscript> | and Please tell me effect on seo or not1 -
Site Migration due to Corporate Acquisition
Hey everyone, Wanted to check-in on something that I've been thinking way too much about lately. I'll do my best to provide background, but due to some poor planning, it is rather confusing to wrap your head around. There are currently three companies involved, Holding Corp (H Corp) and two operating companies, both in the same vertical but one B2B and the other is B2C. B2C corp has been pushed down the line and we're focusing primarily on H Corp and B2B brand. Due to an acquisition of H Corp and all of it's holdings, things are getting shuffled and Ive been brought in to ensure things are done correctly. What's bizarre is H Corp and it's web property are the dominant authority in SERPs for the B2B brand. As in B2B brand loses on brand searches to H Corp, let alone any product/service related terms. As such, they want to effectively migrate all related content from H Corp site to B2B brand site and handover authority as effectively as possible. Summary: Domain Migration from H Corp site to B2B Brand site. Ive done a few migrations in my past and been brought in to recover a few post-launch so I have decent experience and a trusted process. One of my primary objectives initially is change as little as possible with content, url structure (outside the root) etc so 301s are easy but also so it doesn't look like we're trying to play any games. Here's the thing, the URL structure for H Corp is downright bad from both a UX perspective and a general organizational perspective. So Im feeling conflicted and wanted to get a few other opinions. Here are my two paths as I see and Id love opinions on both: stick with a similar URL structure to H Corp through the migration (my normal process) but deviate from pretty much every best practice for structuring URLs with keywords, common sense and logic. Pro: follow my process (which has always worked in the past) Con: don't implement SEO/On-page best practices at this stage and wait for the site redesign to implement best practices (more work) Implement new URL structure now and deviate from my trusted process. Do you see a third option? Am I overthinking it? Other important details: B2B brand is under-going a site redesign, mostly aesthetic but their a big corporation and will likely take 6-9 months to get up. Any input greatly appreciated. Cheers, Brent
Web Design | | pastcatch1 -
Having a second homepage for a site would affect my SEO?
Hello guys, One of our clients is planning to have a new landing page for any users hitting the site for the first time. (returning users will still see the current homepage based on cookies ... in other words, the site would technically have 2 home pages). According to this client, they are planning to do something like this: https://www.websitename.com/ (for returning visitors) https://www.websitename.com/newuser (for first time visitors) Our instinct is that is not great to have 2 home pages (that would affect the SEO campaign we are managing for this company) and we are not sure how to handle this. That's why we would appreciate your opinion regarding this topic: From an SEO perspective, do you think this is a good idea? If not, what would you guys do differentiate first-time visitors vs returning visitors without affecting SEO? Maybe just a pop-up? Thanks in advance for your help !
Web Design | | Robertnweil10 -
Should the parent directory of the main site-navigation be clickable or not?!?
Highly discussed in our team is the question: Should all parent navigation items be clickable, or only the ones that have no child menu appearing on mouse over? At Starwood Germany, we would like to adjust the main navigation for all our websites in order to improve consistency and user friendliness. At the moment, most of our websites feature both clickable non-clickable parent items, depending on whether the items have a corresponding child menu (appearing on mouse over) or not. See example here: http://www.imperialvienna.com/en Some of our team members believe it might be irritating and/or confusing for the user if some items are clickable while others are not. What do you think? Any thoughts and insights would be truly appreciated!
Web Design | | DFM_GSA0 -
Should I use the google mod_pagespeed in my apache server?
Anyone already use it? There is some speed benefit? http://code.google.com/speed/page-speed/docs/module.html
Web Design | | Naghirniac0 -
Do you suggest a SEO Plug-in for Dreamweaver?
I would like to know it there is any plug-in for Dreamweaver that helps our SEO work
Mobile Site Pages: Word Count Help
Hi there I am doing a mobile website for a client and they asked me what the dieal word count would be per page. They are SEO conciosu but we are not doing SEO on this site. I would just like to know a general rule of thumb. Regards Stef
Web Design | | stefanok0 -
Best Wordpress Hosting
I've had a horrible experience with the security on wordpress hosting with GoDaddy. Someone recommended Blue Host as my next option. Does anyone have any experience with BlueHost and what other hosting companies would you recommend for wordpress hosting?
Web Design | | ChristineCadena0
