Do I need to use canonicals if I will be using 301's?
I just took a job about three months and one of the first things I wanted to do was restructure the site. The current structure is solution based but I am moving it toward a product focus.
The problem I'm having is the CMS I'm using isn't the greatest (and yes I've brought this up to my CMS provider). It creates multiple URL's for the same page. For example, these two urls are the same page: (note: these aren't the actual urls, I just made them up for demonstration purposes)
http://www.website.com/home/meet-us/team-leaders/boss-man/
http://www.website.com/home/meet-us/team-leaders/boss-man/bossman.cmsx(I know this is terrible, and once our contract is up we'll be looking at a different provider)
So clearly I need to set up canonical tags for the last two pages that look like this:
http://www.omnipress.com/boss-man" />
With the new site restructure, do I need to put a canonical tag on the second page to tell the search engine that it's the same as the first, since I'll be changing the category it's in?
For Example:
will become
http://www.website.com/home/MEET-OUR-TEAM/team-leaders/boss-man
My overall question is, do I need to spend the time to run through our entire site and do canonical tags AND 301 redirects to the new page, or can I just simply redirect both of them to the new page?
I hope this makes sense. Your help is greatly appreciated!!
no what you need to do is out of the conocal URL reference whatever is going to be shown to the user as the preferable content so if the pages http://www.omnipress.com/boss-woman" />
and next pages
">http://www.omnipress.com/boss-man" /> you will of course need 301 redirect as usual and anyone that tells you rel="canonical is not important does not understand much about SEO and that's not a sly on anyone.
rel="canonical Tells Google where the original pages are it no matter what helps you immensely who searc it on SEOmoz see what Rand has to say or we could just look at this link that claims it's the most important advancement in SEO since site maps so please do use a canonical-url-tag http://www.seomoz.org/blog/canonical-url-tag-the-most-important-advancement-in-seo-practices-since-sitemaps
here is exactly how to implement them and I wish you all the best. http://www.metatags.org/rel_canonical
Sincerely,
Thomas
Canonical tag is only required if the search engines are able to access both the pages. There is no need to apply canonical tag as long as the duplicate pages are being redirected to the new/original page.
As you've specifically mentioned to Google that these page do not exist anymore and I've created a new page for all these pages, and now you want your visitors/search engines to visit the new page which doesn't have any duplicate entry.
Canonical tag only works if you're running a
- multilingual website or
- you're using some query strings for tacking purpose
- you've multiple copies of the one page and those page can not be deleted.
If you're sure that after 301 redirect there will not be any duplicate entry for the page, you don't need to apply canonical tag.
Hope it helps
If your using a 301 redirect, there is no need to use the Rel=canonical tag. However, I would like to point out that the rel=canonical tag is basically made for this type of situation where your CMS is creating multiples of the same page. So adding a rel=canonical tag looks to be exactly what you’re looking for.
You only need to use a 301.
Ps. Your links are going to 404 pages
It depends,
Doing a 301 will transfer the search engine/user from Page A to Page B which is fine. However, if Page B and Page C have a similar URL structure like the first example you gave I would recommend using a canonical tag.
I would recommend using a canonical tag in any case, to let the search engine spider know which page you want it to crawl. If the content/URL is very similar on two pages or more I would highly recommend it to avoid duplication.
How does educational organization schema interact with Google's knowledge graph?
Hi there! I was just wondering if the granular options of the Organization schema, like Educational Organization (http://schema.org/EducationalOrganization) and CollegeOrUniversity (http://schema.org/CollegeOrUniversity) schema work the same when it comes to pulling data into the knowledge graph. I've typically always used the Organization schema for customers but was wondering if there are any drawbacks for going deep into the hierarchy of schema. Cheers 😄
Intermediate & Advanced SEO | | Corbec8880 -
If my website uses CDN does thousands of 301 redirect can harm the website performance?
Hi, If my website uses CDN does thousands of 301 redirect can harm the website performance? Thanks Roy
Intermediate & Advanced SEO | | kadut1 -
Ranking 1st for a keyword - but when 's' is added to the end we are ranking on the second page
Hi everyone - hope you are well. I can't get my head around why we are ranking 1st for a specific keyword, but then when 's' is added to the end of the keyword - we are ranking on the second page. What could be the cause of this? I thought that Google would class both of the keywords the same, in this case, let's say the keyword was 'button'. We would be ranking 1st for 'button', but 'buttons' we are ranking on the second page. Any ideas? - I appreciate every comment.
Intermediate & Advanced SEO | | Brett-S0 -
Should you allow an auto dealer's inventory to be indexed?
Due to the way most auto dealership website populate inventory pages, should you allow inventory to be indexed at all? The main benefit us more content. The problem is it creates duplicate, or near duplicate content. It also creates a ton of crawl errors since the turnover is so short and fast. I would love some help on this. Thanks!
Intermediate & Advanced SEO | | Gauge1230 -
Block in robots.txt instead of using canonical?
When I use a canonical tag for pages that are variations of the same page, it basically means that I don't want Google to index this page. But at the same time, spiders will go ahead and crawl the page. Isn't this a waste of my crawl budget? Wouldn't it be better to just disallow the page in robots.txt and let Google focus on crawling the pages that I do want indexed? In other words, why should I ever use rel=canonical as opposed to simply disallowing in robots.txt?
Intermediate & Advanced SEO | | YairSpolter0 -
Is there any negative SEO effect of having comma's in URL's?
Hello, I have a client who has a large ecommerce website. Some category names have been created with comma's in - which has meant that their software has automatically generated URL's with comma's in for every page that comes beneath the category in the site hierarchy. eg. 1 : http://shop.deliaonline.com/store/music,-dvd-and-games/dvds-and-blu_rays/ eg. 2 : http://shop.deliaonline.com/store/music,-dvd-and-games/dvds-and-blu_rays/action-and-adventure/ etc... I know that URL's with comma's in look a bit ugly! But is there 'any' SEO reason why URL's with comma's in are any less effective? Kind Regs, RB
Intermediate & Advanced SEO | | RichBestSEO0 -
Canonical & noindex? Use together
For duplicate pages created by the "print" function, seomoz says its better to use noindex (http://www.seomoz.org/blog/complete-guide-to-rel-canonical-how-to-and-why-not) and JohnMu says its better to use canonical http://www.google.com/support/forum/p/Webmasters/thread?tid=6c18b666a552585d&hl=en What do you think?
Intermediate & Advanced SEO | | nicole.healthline1 -
To subnav or NOT to subnav... that's my question.... :)
We are working on a new website that is golf related and wondering about whether or not we should set up a subnavigation dropdown menu from the main menu. For example: GOLF PACKAGES
Intermediate & Advanced SEO | | JamesO
>> 2 Round Packages
>> 3 Round Packages
>> 4 Round Packages
>> 5 Round Packages GOLF COURSES
>> North End Courses
>> Central Courses
>> South End Courses This would actually be very beneficial to our users from a usability standpoint, BUT what about from an SEO standpoint? Is diverting all the link juice to these inner pages from the main site navigation harmful? Should we just create a page for GOLF PACKAGES and break it down on that page?0
