Too many links on page -- how to fix
We are getting reports that there are too many links on most of the pages in one of the sites we manage.
Not just a few too many... 275 (versus <100 that is the target).
The entire site is built with a very heavy global navigation, which contains a lot of links -- so while the users don't see all of that, Google does.
Short of re-architecting the site, can you suggest ways to provide site navigation that don't violate this rule?
Dr. Pete has a good post about this warning at http://www.seomoz.org/blog/how-many-links-is-too-many that may help you out.
How much damage does this issue really do?
I see many sites in our industry (enterprise software) whose pages are equally heavy with links. They still seem to enjoy a high page rank. Look at Microsoft, IBM, Oracle, Red Hat...
Just wondering how this compares to other issues that would be easier to address.
I don't know what you mean that users don't see the links and Google does.
I mean that most of these links are on drop-down menus so they aren't visible unless someone hovers over the tab. My point was that the user experience isn't affected by the presence of all of these links on the page, even though it is a problem from an SEO perspective.
The page in question is: http://www.novell.com/products/groupwise/ -- but since we use the same global navigation across the entire site, every page on the site is getting the same SEOMoz warning about too many links.
I do think a navigation restructure is the way to do it and a way to better focus your link juice. No following certain links no longer works for internal site links - Google see's through that now.
Instead of your categories nav including a/or multiple sub cat nav links (im guessing thats how it currently works) on every page, inc the sub cat links on the main cat pages not as part of the main cat nav e.g. dont inc red widget, blue widget, green widget under the main 'widget' navigation, instead add links to red, blue, green widget on the main widget page. Hope that makes sense.
You should bucket the categories into 10-20 primary categories. If you have have lower level categories that are potential traffic drivers, you can feature a few select categories along the primary categories. Every link takes away Pagerank from the host page and too many links on every page will devalue the pages. It's hard to give clear directions without seeing the site,
I don't know what you mean that users don't see the links and Google does. Are you hiding links? That may penalize the site.
Landing page separate from product page
Hello there, I have a wordpress website with a woocommerce plugin. I have 4 landing pages that describe my products and at the end of the pages, I have a CTA to my product page. is it bad for SEO? my website: https://relationadviser.ir
On-Page Optimization | | Aaron.be1 -
Will Google Count Links Loaded from JavaScript Files After the Page Loads
Hi, I have a simple question. If I want to put an image with a link to another site like a banner ad on my page, but do not want it counted by Google. Can I simply load the link and banner using jQuery onload from a separate .js file? The ideal result would be for Google to index a script tag instead of a link.
On-Page Optimization | | CopBlaster.com1 -
How many keywords should I optimize a page for?
Hi, There is a lot of debate going on on whether to use a single keyword per page or multiple keywords per page. What I know for sure is that it is not advisable to repeat the same exact keyword in different pages. I need to optimize product pages, categories and pages for an online store and still do not know if it is better to: 1-work with one main keyword per page plus latent semantic keywords, 2-to optimize a page for multiple different keywords (2 to 4 keywords) which are strongly related to the main topic or to the product sold in a particular product page 3- use single keyword for each page (and no more than one keyword per page). Some seo gurus argue this is the best way to get higher ranking for that particular page in the serps. My personal opinion would be 1 or 2, but I would like to hear what you suggest and think about it. Any suggestion or opinion is welcome and appreciated. Thanks in advance
On-Page Optimization | | cinzia090 -
Should I optimize my home-page or a sub-page for my most important keyword
Quick question: When choosing the most important keyword set that I would like to rank for, would I be better off optimizing my homepage, or a sub page for this keyword. My thinking goes as follows: The homepage (IE www.mysite.com) naturally has more backlinks and thus a better Google Page Rank. However, there are certain things I could do to a subpage (IE www.mysite.com/green-widgets-los-angeles ) that I wouldn't want to do to the homepage, which might be more "optimal" overall. Option C, I suppose, would be to optimize both the homepage, and a single sub-page, which is seeming like a pretty good solution, but I have been told that having multiple pages optimized for the same keywords might "confuse" search engines. Would love any insight on this!
On-Page Optimization | | Jacob_A2 -
How do I fix duplicate page issue on Shopify with duplicate products because of collections.
I'm working with a new client with a site built on Shopify. Most of their products appear in four collections. This is creating a duplicate content challenge for us. Can anyone suggest specific code to add to resolve this problem. I'm also interested in other ideas solutions, such as "don't use collections" if that's the best approach. I appreciate your insights. Thank you!
On-Page Optimization | | quiltedkoala0 -
Missing meta descriptions on indexed pages, portfolio, tags, author and archive pages. I am using SEO all in one, any advice?
I am having a few problems that I can't seem to work out.....I am fairly new to this and can't seem to work out the following: Any help would be greatly appreciated 🙂 1. I am missing alot of meta description tags. I have installed "All in One SEO" but there seems to be no options to add meta descriptions in portfolio posts. I have also written meta descriptions for 'tags' and whilst I can see them in WP they don't seem to be activated. 2. The blog has pages indexed by WP- called Part 2 (/page/2), Part 3 (/page/3) etc. How do I solve this issue of meta descriptions and indexed pages? 3. There is also a page for myself, the author, that has multiple indexes for all the blog posts I have written, and I can't edit these archives to add meta descriptions. This also applies to the month archives for the blog. 4. Also, SEOmoz tells me that I have too many links on my blog page (also indexed) and their consequent tags. This also applies to the author pages (myself ). How do I fix this? Thanks for your help 🙂 Regards Nadia
On-Page Optimization | | PHDAustralia680 -
Tag clouds: good for internal linking and increase of keyword relevant pages?
As Matt Cutts explained, tag clouds are OK if you're not engaged in keyword stuffing (http://www.youtube.com/watch?v=bYPX_ZmhLqg) - i.e. if you're not putting in 500 tags. I'm currently creating tags for an online-bookseller; just like Amazon this e-commerce-site has potentially a couple of million books. Tag clouds will be added to each book detail page in order to enrich each of these pages with relevant keywords both for search engines and users (get a quick overview over the main topics of the book; navigate the site and find other books associated with each tag). Each of these book-specific tag clouds will hold up to 50 tags max, typically rather in the range of up to 10-20. From an SEO perspective, my question is twofold: 1. Does the site benefit from these tag clouds by improving the internal linking structure? 2. Does the site benefit from creating lots of additional tag-specific-pages (up to 200k different tags) or can these pages become a problem, as they don't contain a lot of rich content as such but rather lists of books associated with each tag? Thanks in advance!
On-Page Optimization | | semantopic0 -
Prevent link juice to flow on low-value pages
Hello there! Most of the websites have links to low-value pages in their main navigation (header or footer)... thus, available through every other pages. I especially think about "Conditions of Use" or "Privacy Notice" pages, which have no value for SEO. What I would like, is to prevent link juice to flow into those pages... but still keep the links for visitors. What is the best way to achieve this? Put a rel="nofollow" attribute on those links? Put a "robots" meta tag containing "noindex,nofollow" on those pages? Put a "Disallow" for those pages in a "robots.txt" file? Use efficient Javascript links? (that crawlers won't be able to follow)
On-Page Optimization | | jonigunneweg0
