Difference between search volume in KWT and Impressions in GWT
Hi there,
Sorry I've been a bit quiet of late, we're going through a huge rebranding exercise as well as staying on top of client work.
Anyway. I've got an issue with keyword research phase of a client remarketing.
Trying to decide which keywords to target (aren't we all?) The client has 3 months of back data in Google Webmaster Tools, which helps us to see Impressions, CTR and actual click-throughs etc.
Now, they rank #1 on Google.com for a certain keyword (logged out, of course).
According to Google Keyword tool (Logged in) there are 2.7million searches per month for this keyword. With the average CTR being 18% for a #1 keyword that should be bringing in 400k visits.
However, take the same keyword in Google Webmaster Tools and the impressions are actually around 1,600 per month with a CTR of 9%.
Different CTR's for different sectors I can accept. What I don't get is the vast difference between the impressions in GWT compared to the alleged search volume coming from the Keyword tool.
Really need to understand this so we can better select keywords and judge approximate traffic expected if ranking #1 for a keyword.
Any help would be really useful. Thank you!
This was indeed the problem - such a simple issue, but helps us in future to be wary of that stumbling block
Ah, that may well be it. I didn't do the first stage keyword research, a colleague did, so we may have to refine it. I will have a look through the data again and will get back to you.
Thanks for the reminder.
My best Guess is that when you do the Research in the keyword tool you do not have on "exact" matching. It is often quite silly how large the numbers get if you don't do that.
The ctr of 9% on #1 keyword wouldn't be unusual if there is a Heavy contested key.word With ads above the search result
Page disappears from Google search results
Hi, I recently encountered a very strange problem.
Technical SEO | | JoelssonMedia
One of the pages I published in my website ranked very well for a couple of days on top 5, then after a couple of days, the page completely vanished, no matter how direct I search for it, does not appear on the results, I check GSC, everything seems to be normal, but when checking Google analytics, I find it strange that there is no data on the page since it disappeared and it also does not show up on the 'active pages' section no matter how many different computers i keep it open. I have checked to page 9, and used a couple of keyword tools and it appears nowhere! It didn't have any back links, but it was unique and high quality. I have checked on the page does still exist and it is still readable. Has this ´happened to anyone before? Any thoughts would be gratefully received.0 -
Googlebot and other spiders are searching for odd links in our website trying to understand why, and what to do about it.
I recently began work on an existing Wordpress website that was revamped about 3 months ago. https://thedoctorwithin.com. I'm a bit new to Wordpress, so I thought I should reach out to some of the experts in the community.Checking ‘Not found’ Crawl Errors in Google Search Console, I notice many irrelevant links that are not present in the website, nor the database, as near as I can tell. When checking the source of these irrelevant links, I notice they’re all generated from various pages in the site, as well as non-existing pages, allegedly in the site, even though these pages have never existed. For instance: https://thedoctorwithin.com/category/seminars/newsletters/page/7/newsletters/page/3/feedback-and-testimonials/ allegedly linked from: https://thedoctorwithin.com/category/seminars/newsletters/page/7/newsletters/page/3/ (doesn’t exist) In other cases, these goofy URLs are even linked from the sitemap. BTW - all the URLs in the sitemap are valid URLs. Currently, the site has a flat structure. Nearly all the content is merely URL/content/ without further breakdown (or subdirectories). Previous site versions had a more varied page organization, but what I'm seeing doesn't seem to reflect the current page organization, nor the previous page organization. Had a similar issue, due to use of Divi's search feature. Ended up with some pretty deep non-existent links branching off of /search/, such as: https://thedoctorwithin.com/search/newsletters/page/2/feedback-and-testimonials/feedback-and-testimonials/online-continuing-education/consultations/ allegedly linked from: https://thedoctorwithin.com/search/newsletters/page/2/feedback-and-testimonials/feedback-and-testimonials/online-continuing-education/ (doesn't exist). I blocked the /search/ branches via robots.txt. No real loss, since neither /search/ nor any of its subdirectories are valid. There are numerous pre-existing categories and tags on the site. The categories and tags aren't used as pages. I suspect Google, (and other engines,) might be creating arbitrary paths from these. Looking through the site’s 404 errors, I’m seeing the same behavior from Bing, Moz and other spiders, as well. I suppose I could use Search Console to remove URL/category/ and URL/tag/. I suppose I could do the same, in regards to other legitimate spiders / search engines. Perhaps it would be better to use Mod Rewrite to lead spiders to pages that actually do exist. Looking forward to suggestions about best way to deal with these errant searches. Also curious to learn about why these are occurring. Thank you.
Technical SEO | | linkjuiced0 -
Indexed, but not shown in search result
Hi all We face this problem for www.residentiebosrand.be, which is well programmed, added to Google Search Console and indexed. Web pages are shown in Google for site:www.residentiebosrand.be. Website has been online for 7 weeks, but still no search results. Could you guys look at the update below? Thanks!
Technical SEO | | conversal0 -
How to remove Parameters from Google Search Console?
Hi All, Following are parameter configuration in search console - Parameters - fl
Technical SEO | | adamjack
Does this parameter change page content seen by the user? - Yes, Changes, reorders, or narrows page content.
How does this parameter affect page content? - Narrow
Which URLs with this parameter should Googlebot crawl? - Let Googlebot decide (Default) Query - Actually it is filter parameter. I have already set canonical on filter page. Now I am doing tracking of filter pages via data layer and tag manager so in google analytic I am not able to see filter url's because of this parameter. So I want to delete this parameter. Can anyone please help me? Thanks!0 -
Does an Apostrophe affect searches?
Does Google differentiate between keyphrase structures such as Mens Sunglasses & Men**'**s Sunglasses? I.e. does the inclusion/exclusion of an apostrophe make any difference when optimising your main keyword/phrase for a page? Keyword explorer appears to give different results..... I.e. no data for Men's Sunglasses, but data appears for Mens sunglasses. So if I optimise my page to include the apostrophe, will it screw the potential success for that page? Thanks 🙂 Bob
Technical SEO | | SushiUK1 -
Parked domain is first in search results
We have several brand related domains which are parked and pointing to our main website. Some of these websites are redirecting using a 302 (don't ask, that's a whole other story), but these are being changed. But it shouldn't matter what type of redirect they are no? Since there has never been any traffic and they are not indexed? But it seems that one of them was indexed: exotravel.vn. A search for our brand name or the previous brand name (exotravel and exotissimo) brings up this parked domain first! How can that be? The domain has never been used and has no backlinks. exotravel.vn is redirecting and I submitted a change of address weeks ago to Google, but its still coming up first in all brand name searches for exotissimo or exotravel.
Technical SEO | | Exotissimo0 -
How to handle (internal) search result pages?
Hi Mozers, I'm not quite sure what the best way is to handle internal search pages. In this case it's for an ecommerce website with about 8.000+ products and search pages currently look like: example.com/search.php?search=QUERY+HERE. I'm leaning towards making them follow, noindex. Since pages like this can be easily abused for duplicate content and because I'd rather have the category pages ranked. How would you handle this?
Technical SEO | | Qon0 -
Loss of search engine positions after 301 redirect - what went wrong?!?
Hi Guys After adhering to the On Page optimisation suggestions given by SEOmoz, we redirected some of old urls to new ones. We set 301 redirects from the old pages to new on a page by page basis but our search engine ranking subsequently fell off the radar and lost PR. We confirmed redirection with fiddler and it shows 301 permanent redirect on every page as expected. To manage redirection using a common code logic we executed following: In Http module, using “rewrite path” we route “all old page requests” to a page called “redirect.aspx? oldpagename =[oldpagename]”. This happens at server side. In redirect.aspx we are redirecting from old page to new page using 301 permanent redirect. In the browser, when old page is requested, it will 301 redirect to new page. In hope we and others can learn from our mistakes - what did we do wrong ?!? Thanks in advance. Dave - www.paysubsonline.com
Technical SEO | | Evo0
