Trailing Slash Problems
Link juice being split between trailing slash and non versions. ie. ldnwicklesscandles.com/scentsy-uk and ldnwicklesscandles.com/scentsy-uk/
Initially asked in here and was told to do a rewrite in the htaccess file.
I don't have access to this with squarespace, nor can I add canonical tags on a page by page basis.
301 redirect from scentsy-uk to scentsy-uk/ didn't work either...said that the redirect wasn't completing in an error message on the browser.
Squarespace hasn't been very helpful at all.
My question is....is there another way to fix this? or should I just call it a day with squarespace and move to wordpress?
I know this is an old thread but just wondering if anyone ever found a solution in Squarespace, or did everyone just move over to Wordpress?
You'll be hard pressed to find a hosted platform that is technically optimized for search engines. Adobe Catalyst, Squarespace, Wix, etc. will all have little (or major) issues. I don't know of too many really popular sites hosted on these platforms, but that's not to say those hosted sites won't rank well for chosen keywords. Anyway, here's what Google has to say about it: http://www.youtube.com/watch?v=CTrdP7lJ2HU
Hi Christine:
Did you ever find a solution for this? I have a client who's Squarespace site shows rel-con issues with my recent crawl. And to your point, you can't implement that on a per page basis. Squarespace hasn't responded (yet) to a service request. Any suggestions would be helpful. Thank you!
Is there a way to get around this without moving to Wordpress? I only will do that if there's absolutely no other way to help my site.
Looks like a move to Wordpress is a safe bet then as your system seems very SEO-Unfriendly.
When you do move to Wordpress be sure to check out Yoast SEO Plugin http://yoast.com/wordpress/seo/
Aran I can't add canonical tags on a page by page basis. x
have you tried using the canonical tag?
Essentially, its only a issue when you have links to both the slash and non-slash versions. I would standardize on either having slashes or not, and make sure all links on the site follow the standard. However, after hearing that they lack basic SEO, I would convert to WP.
I have two robots.txt pages for www and non-www version. Will that be a problem?
There are two robots.txt pages. One for www version and another for non-www version though I have moved to the non-www version.
Technical SEO | | ramb0 -
Problems with WooCommerce Product Attribute Filter URL's
I am running a WordPress/WooCommerce site for a client, and Moz is picking up some issues with URL's generated from WooCommerce product attribute filters. For example: ..co.uk/womens-prescription-glasses/?filter_gender=mens&filter_style=full-rim&filter_shape=oval How do I get Google to ignore these filters?
Technical SEO | | SushiUK
I am running Yoast Premium, but not sure if this can solve the issue? Product categories are canonicalised to the root category URL. Any suggestions very gratefully appreciated. Thanks Bob0 -
Canonical homepage link uses trailing slash while default homepage uses no trailing slash, will this be an issue?
Hello, 1st off, let me explain my client in this case uses BigCommerce, and I don't have access to the backend like most other situations. So I have to rely on BG to handle certain issues. I'm curious if there is much of a difference using domain.com/ as the canonical url while BG currently is redirecting our domain to domain.com. I've been using domain.com/ consistently for the last 6 months, and since we switches stores on Friday, this issue has popped up and has me a bit worried that we'll loose somehow via link juice or overall indexing since this could confuse crawlers. Now some say that the domain url is fine using / or not, as per - https://cloudz.click/community/q/trailing-slash-and-rel-canonical But I also wanted to see what you all felt about this. What says you?
Technical SEO | | Deacyde0 -
Last Part Breadcrumb Trail Active or Non-Active
Breadcrumbs have been debated quite a bit in the past. Some claim that the last part of the breadcrumb trail should be non-active to inform users they have reached the end. In other words, Do not link the current page to itself. On the other hand, that portion of the breadcrumb would won't be displayed in the SERPS and if it was may lead to a higher CTR. Foe example: www.website.com/fans/panasonic-modelnumber panasonic-modelnumber would not be active as part of the breadcrumb. What is your take?
Technical SEO | | CallMeNicholi0 -
Double Slash // in URL
My client is using double forward slahes in URL like this "//" is this affecting SEO?
Technical SEO | | yanaiguana1110 -
Trailing Slashes on Home Pages
I do not think I have a problem here, but a second opinion would be welcomed... I have a site which has a the rel=canonical tag with the trailing slash displayed. ie www.example.com/ The sitemap has it without the trailing slash. www.example.com Google has it's cached copy with the trailing slash but the browser displays it without. I want to say it's perfectly fine (for the home page) as I tend to think they are treated (with/without trailing slashes) as the same canonical URL.
Technical SEO | | eventurerob0 -
403 forbidden, are these a problem?
Hi I have just run a crawl test on screaming frog and it is showing quite a few 403 forbidden status codes. We are showing none of these in webmaster tools, is this an issue?
Technical SEO | | jtay1230 -
Trailing Slashes In Url use Canonical Url or 301 Redirect?
I was thinking of using 301 redirects for trailing slahes to no trailing slashes for my urls. EG: www.url.com/page1/ 301 redirect to www.url.com/page1 Already got a redirect for non-www to www already. Just wondering in my case would it be best to continue using htacces for the trailing slash redirect or just go with Canonical URLs?
Technical SEO | | upick-1623910
