Duplicate content problem from an index.php file
Hi
One of my sites is flagging a duplicate content problem which is affecting the search rankings.
The duplicate problem is caused by http://www.mydomain.com/index.php which has a page rank of 26
How can I sort the duplicate content problem, as the main page should just be
http://www.mydomain.com which has a page rank of 42 and is the stronger page with stronger links etc
Many Thanks
Yes just use the canonical tag on the index.php file to reference the page as the domain, that'll be the easiest way.
Using an actual redirect could cause you to spiral into a loop
Thanks Malcolm
Can it be done using the canonical URL tag or another means rather than the .htaccess file?
I have access to the .htaccess but I am unsure of what I would need to add in there to solve my problem?
Its simple…
Redirect 301 http://www.mydomain.com/index.php to http://www.mydomain.com and all your link juice value and traffic will move to the index page you want and duplicate content issues will be resolved!
Hope this helps!
You need to add a redirect preferably in the .htaccess file so that index.php automatically redirects to the root. This should fix the problem as Google will currently see www.yourdomain.com/index.php and www.yourdomain.com/ and www.yourdomain.com asa 3 separate pages thus why your page authority is different. Google will also think they are duplicate content which is obviously bad!
This fix will work if mod_rewrite is enabled, but is usually enabled on most apache servers. http://www.askapache.com/htaccess/redirect-index-blog-root.html
Duplicate content, although page has "noindex"
Hello, I had an issue with some pages being listed as duplicate content in my weekly Moz report. I've since discussed it with my web dev team and we decided to stop the pages from being crawled. The web dev team added this coding to the pages <meta name='robots' content='max-image-preview:large, noindex dofollow' />, but the Moz report is still reporting the pages as duplicate content. Note from the developer "So as far as I can see we've added robots to prevent the issue but maybe there is some subtle change that's needed here. You could check in Google Search Console to see how its seeing this content or you could ask Moz why they are still reporting this and see if we've missed something?" Any help much appreciated!
Technical SEO | | rj_dale0 -
Duplicate content and 404 errors
I apologize in advance, but I am an SEO novice and my understanding of code is very limited. Moz has issued a lot (several hundred) of duplicate content and 404 error flags on the ecommerce site my company takes care of. For the duplicate content, some of the pages it says are duplicates don't even seem similar to me. additionally, a lot of them are static pages we embed images of size charts that we use as popups on item pages. it says these issues are high priority but how bad is this? Is this just an issue because if a page has similar content the engine spider won't know which one to index? also, what is the best way to handle these urls bringing back 404 errors? I should probably have a developer look at these issues but I wanted to ask the extremely knowledgeable Moz community before I do 🙂
Technical SEO | | AliMac260 -
Z-indexed content
I have some content on a page that I am not using any type of css hiding techniques, but I am using an image with a higher z-index in order to prevent the text from being seen until a user clicks a link to have the content scroll down. Are there any negative repercussions for doing this in regards to SEO?
Technical SEO | | cokergroup0 -
Is duplicate content ok if its on LinkedIn?
Hey everyone, I am doing a duplicate content check using copyscape, and realized we have used a ton of the same content on LinkedIn as our website. Should we change the LinkedIn company page to be original? Or does it matter? Thank you!
Technical SEO | | jhinchcliffe0 -
Duplicate Content
We have a ton of duplicate content/title errors on our reports, many of them showing errors of: http://www.mysite.com/(page title) and http://mysite.com/(page title) Our site has been set up so that mysite.com 301 redirects to www.mysite.com (we did this a couple years ago). Is it possible that I set up my campaign the wrong way in SEOMoz? I'm thinking it must be a user error when I set up the campaign since we already have the 301 Redirect. Any advice is appreciated!
Technical SEO | | Ditigal_Taylor0 -
Home Page .index.htm and .com Duplicate Page Content/Title
I have been whittling away at the duplicate content on my clients' sites, thanks to SEOmoz's pro report, and have been getting push back from the account manager at register.com (the site was built here and the owner doesn't want to move it). He says these are the exact same page and he can't access one to redirect to the other. Any suggestions? The SEOmoz report says there is duplicate content on both these urls: Durango Mountain Biking | Durango Mountain Resort - Cascade Village http://www.cascadevillagehotel.com/index.htm Durango Mountain Biking | Durango Mountain Resort - Cascade Village http://www.cascadevillagehotel.com/ Your help is greatly appreciated! Sheryl
Technical SEO | | TOMMarketingLtd.0 -
Does Google index XML files?
Does Google or other search engines include XML files in their index? More specifically, I am wondering how Google knows the difference between an xml filetype and an RSS feed.
Technical SEO | | nicole.healthline0 -
Duplicate Content issue
I have been asked to review an old website to an identify opportunities for increasing search engine traffic. Whilst reviewing the site I came across a strange loop. On each page there is a link to printer friendly version: http://www.websitename.co.uk/index.php?pageid=7&printfriendly=yes That page also has a link to a printer friendly version http://www.websitename.co.uk/index.php?pageid=7&printfriendly=yes&printfriendly=yes and so on and so on....... Some of these pages are being included in Google's index. I appreciate that this can't be a good thing, however, I am not 100% sure as to the extent to which it is a bad thing and the priority that should be given to getting it sorted. Just wandering what views people have on the issues this may cause?
Technical SEO | | CPLDistribution0
