Best Website Builder - Help Me Choose
I need to built a multi language site (to built a Pilates, Yoga site) and I will use a site builder. After posting questions on wix.com I came to the fact I should continue my research because there are not SEO friendly.
Do you have a suggestions?
Limited to html knowledge, using a website builder is my only option.
Here are some of the features I need:
- Multilanguage Web Site
- Mobile version
- SEO Friendly
- Nice Template Selections( this is important)
- HTML customization
- Twitter, Facebook, Blog...
I'm not looking at free website builder, when you want good features, there is a price to paid.
Thank you for your help and suggestions,
BigBlaze
Sorry for the late response, but you should also check out Breezi, as it meets all of your requirements and then some (and yes, I'm from Breezi, so I'm biased of course). WordPress is a good platform as well, but the drawback is that you'll likely spend a lot of time in theme customizations, installing plugins, etc.
We have a limited number of pre-designed themes currently, but we'll be ramping up over the next few weeks and adding a lot more.
Good luck, let me know if you have any questions!
Would it be spammy of me to say www.basekit.com?! It has everything you need. It's either us or SquareSpace - we're regarded as the best. All the others are pretty lacking or use flash. Even Wix's recent HTML5 push is still very much flash-based.
Well, you can perform a search for 'Free premium wordpress themes' and you'll get a very big selection of fantastic designs or you can go to elegantthemes.com and pay for one.
And yes Wordpress is very SEO friendly I believe Matt Cutts even said so.
Hope this helps
You are right, themes looks better then everything a saw in all website builder.
Do you other suggestions site for templates? I don't want a Blog look, I want to built a nice looking website for my Wife who is starting a Pilates Studio soon.
Also, is Worldpress SEO frendly?
Thank you for your help,
BigBlaze
I have never used it, but to be honest - the builder itself is probably irrelevant due to your specific requirements. As most sitebuilders are exactly the same - they just have different features - so if you find one with all the features you need go with it!
The only variable is if this builder is also the Host - in this situation just make sure you verify its uptime, support and service.
Hope this helps
You can easily build a website with wordpress and there's loads of themes you can choose from which you can then edit. Have a look at these an see if you like any. They're all free by the way - http://www.fabthemes.com/
I'M trying Webnode, any advice about them?
Personally - with your requirements, you are either going to have to do an in depth search of products that will fit your needs - the closest I would say is Weebly or the like - I really think though with your needs, you will be much better off with a CMS - it is a learning curve, but more control.
Other than that - I would suggest learning coding languages
Sitebuilders are built to be easy, and your needs are sort of outside the realm of a normal sitebuilder user.
WordPress is to built Blog, right?
I need a complet website
I need to built a site where you can select the language.
The site will french and english. -
I strongly recommend you build the site using Wordpress, site builders are usually very limited.
It really depends on your preference....
you can most definitely customize the URL with Weebly.... But the language? How do you mean? In page translation? Or the controls of the program in another language?
It look like they don't have multi language site.
also, not possible to customize page url.Any other options?
How about using software, like Intuit?
Wil it be better to use software or a online site builder ?
Thank you,
BigBlaze
if you need hosting and the builder - weebly.com is a pretty good choice - there are drawbacks of course to any sitebuilder, and limited HTML knowledge.
But in my expereince if you are not looking for a CMS, just a "drag and drop" builder - weebly is 100000 times better than wix - as you found out wix is HORRIBLE for SEO.
If you are looking for a little more customization - just find a host that offers a sitebuilder - like Fatcow - they offer weebly pro for an additional price AND you have all the FTP abilities to make advanced HTML changes and additions after using weebly to publish the core components.
Learning HTML and becoming very proficient in it, and its counterparts (php asp ect..) is crucial to SEO though...
Hope this helps
Shane
What is the best way to handle annual events on a website?
Every year our company has a user conference with between 300 - 400 attendees. I've just begun giving the event more of a presence on our website. I'm wondering, what is the best way to handle highlights from previous years? Would it be to create an archive (e.g. www.companyname.com/eventname/2015) while constantly updating the main landing page to promote the current event? We also use an event website (cvent) to handle our registrations. So once we have an agenda for the current years event I do a temporary redirect from the main landing page to the registration website. I don't really like this practice and I feel like it might be better to keep all of the info on the main domain. Wondering if anybody has any opinions or feedback on that process as well. Just looking for best practices or what others have done and have had success with.
Web Design | | Brando161 -
Internal Linking: What is the best practice for pages not included in Nav bar?
I never quite understood why internal linking was such a big deal for SEO, but now I'm having second thoughts and perhaps understanding it more. I always thought since most websites have a navigation feature--usually the menu bar located at the top and often another one in the footer--that internal navigation was usually already built in to most websites and therefore, a silly topic to make a fuss over; however, I may be the silly one after all. I am now creating pages that are not included in the navigation so.... What is the best practice for this? If I am creating say, pages for certain locations and those location pages begin to number in the hundreds, it makes my navigation bar a little too cumbersome to have all those pages in a drop down menu. So I made a Locations page and just link to all those pages from that page (and from nowhere else). But now I'm wondering if this could be a bad internal linking practice and perhaps hurt my online visibility as an SEO ranking factor. Is this a crawl problem? And if so, is there a better option that provides a good visitor experience while appeasing the search engines.
Web Design | | Dino640 -
Website organic traffic unchanged, impressions took a 98% drop in the last week.
Hi all, I have a very curious predicament and I'd be grateful if someone could shed some light on the situation. As mentioned in the title, organic traffic to our website has remained unchanged, but organic impressions have taken a 98% drop in the last week. This happened suddenly over one day; on October 22, impressions were 700, on October 23, they were 500, and on October 24 they drastically dropped to 50. The next two days they were at 22 and then up to 35. Organic traffic, however, showed the normal "weekend drop" as of October 24, and is still showing normal level (even increased a bit) continuing into this week. These are organic impressions according to Google Analytics and Google Webmaster tools. We did perform a complete site redesign a month ago. Could this be an effect from the redesign? We also noticed drop in Domain Authority, but our competitors suffered a similar (if not greater) drop as well, so we wondered if it could be due in part to the algorithm update. If anyone could shed some light on the situation I would be so appreciative! Thanks!
Web Design | | Joanne_Pendon0 -
Subdomains For Real Estate Website
I am currently working on a proposal for a clients Wordpress website development which includes ongoing SEO after the website is developed. I have looked into a number of options and the one that seems the most cost effective involves using subdomains for the individual listings pages. What I want: clientsdomain.com/listings/idxnumber/ What I can get for a decent price: listings.clientsdomain.com/idxnumber/ So the majority of the website will actually exist on a subdomain because the IDX API will automatically populate pages for all of the MLS listings in the area (hundreds or thousands). Meanwhile the domain itself will have all the neighborhood pages and other optimized content, blogs and whatnot. My concern is that dividing the website like this will have negative effects on SEO. There wont be duplicate content across subdomain and main domain, but they will share a lot of links back and forth. I haven't found any recent sources on the topic. Almost everything I have found says that dividing a website in this manor is bad for SEO, but these articles are often many years old. Does anyone know of a Wordpress plugin/IDX company that can provide a solution that doesn't use a subdomain and actually just lists each MLS page within a directory? I am open to using another platform, I am just most familiar with Wordpress. Will using a subdomain in the ways mentioned above have a profound negative effect on SEO? Thank you for your time in responding, I greatly appreciate it.
Web Design | | TotalMarketExposure0 -
Implementing a new Nav Bar: Best practice, SEO benefit, your suggestions?
Hi Mozland, We are going to have a new Nav Bar for our site built from the horror that we currently have to up with. We want to make it a simple affair, similar to The Guardian two-tier Nav Bar - main menu which will drop down to the 2nd tier according to what you clicked on in tier one. Regular stuff, I think. Any suggestions, from your experience, about how best to implement this, what to include, what not to do, what can be included and done to make it as best it can be to get people to peruse our site as easily as possible? Thanks
Web Design | | Martin_S0 -
Mobile Site Pages: Word Count Help
Hi there I am doing a mobile website for a client and they asked me what the dieal word count would be per page. They are SEO conciosu but we are not doing SEO on this site. I would just like to know a general rule of thumb. Regards Stef
Web Design | | stefanok0 -
Where is the best place to put reciprocal links on our website?
Where should reciprocal links be placed on our website? Should we create a "Resources" page? Should the page be "hidden" from the public? I know there is a right answer out there! Thank you for your help! Jay
Web Design | | theideapeople0 -
Best Wordpress Hosting
I've had a horrible experience with the security on wordpress hosting with GoDaddy. Someone recommended Blue Host as my next option. Does anyone have any experience with BlueHost and what other hosting companies would you recommend for wordpress hosting?
Web Design | | ChristineCadena0
