Removing robots.txt on WordPress site problem
Hi..am a little confused since I ticked the box in WordPress to allow search engines to now crawl my site (previously asked for them not to) but Google webmaster tools is telling me I still have robots.txt blocking them so am unable to submit the sitemap.
Checked source code and the robots instruction has gone so a little lost. Any ideas please?
I edited the robots.txt file for my website http://debtfreefrombankruptcy.com yesterday to allow search engines to crawl my site. However, Google isn't recognizing the new file and is still saying that my sitemap is blocked from search. Here is a link to the file itself:
http://www.debtfreefrombankruptcy.com/robots.txt
The Blocked URLs tester said that the file allows Google to crawl the site, but in actuality it still isn't recognizing the new file. Any advice would be appreciated. Thanks!
I can help you out as this issue DROVE ME NUTS.
1. I didnt have a Robots.txt (yet)
2. I had Yoast installed
3. Im pretty sure it created a Robots.txt even though it doesnt exist in my root (.com/here)
4. My Google webmaster tools shows this
User-agent: Disallow: /wp-admin/ Disallow: /wp-includes/ Disallow: /cgi-bin Disallow: /wp-admin Disallow: /wp-includes Disallow: /wp-content/plugins Disallow: /plugins Disallow: /wp-content/cache Disallow: /wp-content/themes Disallow: /trackback Disallow: /feed Disallow: /comments Disallow: /category//* Disallow: /trackback Disallow: /feed Disallow: /comments Disallow: /? Disallow: /?Allow: /wp-content/uploadsAllow: /assets Create a Robots.txt
1. login to wordpress 2. Click SEO in your side toolbar (Yoast WordPress Plugin settings) 3. Go to edit files under SEO (in the side toolbar)
And now you have the option to edit your Robots.txt file.
Hi Sophia
I just checked and see your homepage indexed in google.co.uk with a cache date of April 26th. You should be all set!
-Dan
Quick update - by amending the robots text file and switching sitemap plugin over to Yoast I finally got the sitemap to index without robots.txt warnings although the Home page of site was not indexed, 'oh dear'. 5 out of the 7 pages in the sitemap were indexed by Google so It's a start but some more investigating to be done on my side.
Dan,
Cant thank you enough! The sitemap request is still pending in Google - maybe I sent too many requests But it's time to sit back and wait for the good news hopefully. Thanks again.
Hi Sofia
I just ran the same validator on your sitemap and it went through fine - see screenshot
I intended to mean that you should just be sure Google Webmaster Tools accepts the sitemap as valid - if so, there's no need to run through a 3rd party validator. Apologies if I didn't state it clearly!
Let me know, but from what I can see it looks good!
-Dan
EDIT - Looking more closely, it looks like your ran the homepage through the validator - you would actually enter the sitemap address its self in the validator - http://containerforsale.co.uk/sitemap.xml
Hi Dan,
I followed the above advice and switched to the Yoast generated sitemap but after testing on http://www.xml-sitemaps.com/validate-xml-sitemap.html I got the following result - no idea what it means but it looks nasty...
Schema validating with XSV 3.1-1 of 2007/12/11 16:20:05Schema validator crashed
The maintainers of XSV will be notified, you don't need to
send mail about this unless you have extra information to provide.
If there are Schema errors reported below, try correcting
them and re-running the validation.Target: http://containerforsale.co.uk
(Real name: http://containerforsale.co.uk
Server: Apache/2.2.22 (Unix) mod_ssl/2.2.22 OpenSSL/0.9.8e-fips-rhel5 mod_bwlimited/1.4)The target was not assessedLow-level XML well-formedness and/or validity processing output
Warning: Undefined entity raquo
in unnamed entity at line 16 char 83 of http://containerforsale.co.uk
Warning: Undefined entity nbsp
in unnamed entity at line 160 char 10 of http://containerforsale.co.uk
Error: Expected ; after entity name, but got =
in unnamed entity at line 274 char 631 of http://containerforsale.co.u -
Sofia
You are using Yoast SEO plugin for WordPress, so use the XML sitemap within Yoast. You don't need a separate plugin for the XML sitemap. And yes, within Yoast turn the sitemap on.
Hope that helps!
-Dan
Indeed, thanks everyone - it's really appreciated!
I have updated the robots.txt as indicated and re submitted site map but looks like Google still has problems with my site since the error warning for robots is there after the processing is done.
Quick question - I am using a plugin called Google XML Sitemaps which has the following tick box option.
'Add sitemap URL to the virtual robots.txt file'.
The virtual robots.txt generated by WordPress is used. A real robots.txt file must NOT exist in the blog directory!'Should this box be ticked or un-ticked please? Fyi I currently don't have the box ticked.
Thanks guys for all the responses and helping!
Three Things to try
1.Fix Robots.txt
Sofia - I just checked your robots.txt now and it reads;
User-agent: * Disallow: Sitemap: http://containerforsale.co.uk/sitemap.xml.gz
- with the sitemap on the same line as disallow - I'd check on that and make sure its on a separate line.
- ALSO, you don't need the .gz on the sitemap file just sitemap.xml
2. Re-submit Sitemap
- RESUBMIT your sitemap to webmaster tools and make sure its valid.
3. Submit URL to Webmaster Tools (only last resort)
this is only last case scenario, shouldn't have to do this on the homepage if everything is correct.
- go to fetch as googlebot ->run the fetch ->then submit URL
- do this for the homepage
- see article on google blog for reference
Let us know if you're all set, thanks!
-Dan
Ok thanks Brent, I changed to
User-agent: *
Disallow:
Guess I will just have to wait for Google to refresh now...
yes, the urls being blocked are includes from your Wordpress program.
Thanks for the heads up.
The warning just says 7 Url''s blocked by robots.txt. - have seen this issue posted on the WordPress boards by others but no real insight into solutions.
Perhaps I should try your idea of
Change the robots.txt file to this:
User-agent *
Disallow:
Well there is a robots.txt file. You can view it here: http://containerforsale.co.uk/robots.txt
What warnings are you getting in your sitemap submission area? It appears to look alright: http://containerforsale.co.uk/sitemap.xml But I tried to validate it and got a 504 Gateway Time-out error. http://www.xml-sitemaps.com/index.php?op=validate-xml-sitemap&go=1&sitemapurl=http%3A%2F%2Fcontainerforsale.co.uk%2Fsitemap.xml&submit=Validate
Its weird, the front page warning on Google webmaster for robots has disappeared now, but still got the warnings in the sitemap submission area. My host suggests I just wait a bit longer for Google to update because he said same as you - that there doesn't seem to be any robot.txt file.
Doesn't appear to be blocked, so maybe it has something to do with your /wp-includes/ directory.
User-agent *
Disallow:
Hey Guys,
Thanks for your replies...the domain is http://containerforsale.co.uk ,My host told me to look in the Public HTML file folder for the robots.txt file and just delete it but can't see it in there?
My host said he found a tester site and it doesn't report any issues:
http://www.searchenginepromotionhelp.com/m/robots-text-tester/robots-checker.php
This is the display I get from http://containerforsale.co.uk/robots.txt
User-agent *
Disallow: /wp-includes/ -
Hi Sofia,
Two things you need to consider when troubleshooting this:
The actual robots.txt file (located in the root directory of your site) and the meta-robots tags in the section of your HTML. When you say you checked the source code and the robots instructions were missing, I think you were talking about the meta-robots tags in the actual HTML of your site.
Webmaster Tools is probably referring to the actual robots.txt file in your domain's root path, which would differ entirely and not be visible by checking the HTML on your site. Like Nakul and Brent said, if you'll let us know your site's URL and paste the content of your robots.txt file here, I'm sure one of us can help you resolve the problem fairly quickly.
Anthony
copy whatever you have in your robots.txt file here and we will tell you the issue.
SEOmoz has a great article about Robots.txt files here: http://www.seomoz.org/learn-seo/robotstxt
The robots.txt would probably not be a part of the Wordpress Configuration. Allow indexing is controlled via Meta Data by the Wordpress Architecture.
I would look for something like this in yourdomain.com/robots.txt
disallow /
or something like that. If that does not help, PM me your site URL and I would be glad to look it up for you.
Robots.txt Syntax for Dynamic URLs
I want to Disallow certain dynamic pages in robots.txt and am unsure of the proper syntax. The pages I want to disallow all include the string ?Page= Which is the proper syntax?
Technical SEO | | btreloar
Disallow: ?Page=
Disallow: ?Page=*
Disallow: ?Page=
Or something else?0 -
Removing a large number of unnecessary pages from a site
Hi all, I got a big problem with my website. I have a lot of page, duplicate page made from various combinations of selects, and for all this duplicate content we've be hit by a panda update 2 years ago. I don't want to bring new content an all of these pages, about 3.000.000, because most of them are unnecessary. Google indexed all of them (3.000.000), and I want to redirect the pages that I don't need anymore to the most important ones. My question, is there any problem in how google will see this change, because after this it will remain only 5000-6000 relevant pages?
Technical SEO | | Silviu0 -
Robots.txt on subdomains
Hi guys! I keep reading conflicting information on this and it's left me a little unsure. Am I right in thinking that a website with a subdomain of shop.sitetitle.com will share the same robots.txt file as the root domain?
Technical SEO | | Whittie0 -
Should I block Map pages with robots.txt?
Hello, I have a website that was started in 1999. On the website I have map pages for each of the offices listed on my site, for which there are about 120. Each of the 120 maps is in a whole separate html page. There is no content in the page other than the map. I know all of the offices love having the map pages so I don't want to remove the pages. So, my question is would these pages with no real content be hurting the rankings of the other pages on our site? Therefore, should I block the pages with my robots.txt? Would I also have to remove these pages (in webmaster tools?) from Google for blocking by robots.txt to really work? I appreciate your feedback, thanks!
Technical SEO | | imaginex0 -
Removing Media from Wordpress
I've run the seomoz on page report and found an interesting issue. I'm using wordpress and it seems that every picture I add to my articles seem to be added as separate pages to the site. I'm having to go to each and every picture and creating a meta tag and description to it. I still get duplicate content issues with the same. On my Disqus system, I get the same pictures added just as a page or article would look like. What can I do to avoid this?
Technical SEO | | emasaa0 -
Will an XML sitemap override a robots.txt
I have a client that has a robots.txt file that is blocking an entire subdomain, entirely by accident. Their original solution, not realizing the robots.txt error, was to submit an xml sitemap to get their pages indexed. I did not think this tactic would work, as the robots.txt would take precedent over the xmls sitemap. But it worked... I have no explanation as to how or why. Does anyone have an answer to this? or any experience with a website that has had a clear Disallow: / for months , that somehow has pages in the index?
Technical SEO | | KCBackofen0 -
Can I Disallow Faceted Nav URLs - Robots.txt
I have been disallowing /*? So I know that works without affecting crawling. I am wondering if I can disallow the faceted nav urls. So disallow: /category.html/? /category2.html/? /category3.html/*? To prevent the price faceted url from being cached: /category.html?price=1%2C1000
Technical SEO | | tylerfraser
and
/category.html?price=1%2C1000&product_material=88 Thanks!0 -
Delete old site but redirect domain to a new domain and site
I just have a quick query and I have a feeling about what the answer is so just wanted to see what you guys thought... Basically I am working on a client site. This client has a few other websites that are divisions of their company. However these divisions/websites are no longer used. They are wanting to delete the websites but redirect the domains to their name main website. They believe this will pass on SEO benefits as these old division sites are old and have a good PR and history. I'm unsure for DEFINITE, which way is correct?
Technical SEO | | Weerdboil0
