Correct Canonical Reference
Aloha,
This is probably a noob question, but here we go:
I got a CMS e-commerce, which does not allow static "rel=canonical" declaration in the header and can only work with third-party modules (xml packages) that append "rel=canonical" to all pages dynamic pages within the URL. As a result, I have pages I'm declaring incomplete rel="canonical" as such:
Instead of:
rel="canonical" src="www.domainname.com/category.aspx"
I get:
rel="canonical" src="/category.aspx"
Coincidentally (or not), after the implementation of the canonical tag, pages that were continuously increasing in rankings started dropping, and, within a week, disappeared from the index completely.
Could the drop be a result of my canonical links pointing to incomplete URLs? If so, by fixing this issue, do I stand a chance of recovering my pages' SERPs?
It's possible that the canonical timing was just a coincidence and something deeper is going on, but I look at it this way - if it's easy to fix, fix it, and then you'll know for sure. It can be really tough to separate technical indexation problems from penalties.
Absolutely!
What gets me wondering is that only two pages have been removed from the index and do not appear in 1-1000 search results, others just dropped in rankings. Maybe, the two "most optimized" pages with most content and links got most "attention" from Google and got removed first.
Sorry, I could've sworn they recommended not using relative paths somewhere, but now I can't find that reference. I'd just make doubly sure they're resolving correctly. Given that these pages disappeared completely from the index, it's hard to believe the canonical tag addition was just an accident. You always have to start with what you know, and you know this changed.
Thanks for the link!
It says that canonical CAN be a relative path, and that Google will relate the path the the base URL _(section:"Can I use a relative path to specify the canonical, such as ?"). _
I will be posting my results here. Let's see if pages get re-indexed and recovered in SERPs. Hope this helps someone who is have a similar issue.
I haven't specifically tested the impact of relative URLs, but to the best of my knowledge, all canonical tags should be absolute URLs (including "http://"). I would've figured Google would just ignore the incomplete tags, at worst, but it's certainly possible they're attributing them incorrectly.
Since you know you made the change and that they pages have de-indexed, I'd definitely fix the issue, even if it's on a few test pages (not sure how difficult the implementation is).
One note - this is probably just a typo in your question, but it's href="", not src="" in the canonical tag. Google's reference page on the tag is actually pretty good:
http://googlewebmastercentral.blogspot.com/2009/02/specify-your-canonical.html
As I mentioned, right after the implementation, some of the landing pages I optimized disappeared from the index completely, some began dropping.
Can you check to make sure those pages are still indexed by Google? If the pages that were indexed are no longer indexed, then your canonical links have interfered with the ranking.
What type of website is best for seo.
I need a new website for my health insurance business. What type is best for SEO? Many thanks
Web Design | | laurentjb1 -
Is managed wordpress hosting bad for seo?
hi, i would like to create my own website, but I am confused either to choose cpanel hosting or managed wordpress
Web Design | | alan-shultis0 -
Does changing content and design of the website gonna affect my all the backlinks i have made till now
i have been working on my link profile for a month now, after learning about 5 step moz methodology i have decided that i would like to change all of the content of my site and taylor it to what my customers need, am i gonna loose all the domain authority if make changes? if it gonna affect, hows that gonna come out
Web Design | | calvinkj0 -
Why is my financial services site being flagged as gambling
Watchguard and Websense/Forecepoint are flagging my financial services site gambling...how can I prevent that from happening. https://fwag.com/
Web Design | | AdsposureDev0 -
Payment Options in Footer
Hi Moz Community. I'm currently working on cleaning up a website footer on an e-commerce site. I was curious to find out if including payment options is important? Either text or image icons. Including Visa, AMEX etc. Are there benefits of displaying them? Image attached. Thanks vcdoL
Web Design | | Kdruckenbrod0 -
What’s the best tool to visualize internal link structure and relationships between pages on a single site?
I‘d like to review the internal linking structure on my site. Is there a tool that can visualize the relationships between all of the pages within my site?
Web Design | | QBSEO0 -
Migration from HTML to Wordpress - SEO Implications?
I am in the process of having a wordpress site developed to replace my current HTML site. (I currently have my website in html and a blog in wordpress in a sub directory). I am doing this in phases to try and preserve as much of my good rankings as possible. My first phase is to replicate my site with the exact same pages, meta data, and site structure. I'm hoping that google will see this as not much change and not change my rankings for the worse. I also made it a goal that my site speed tests be at least equal to what they are now. We will have to 301 all of the URLs however since it will be going from /example.html to /example. I believe my blog will also need to move into the root directory as well, so I need to 301 all of those pages. I plan to wait a couple months for Phase 2. Phase 2 involves replacing old content (photo galleries), and introducing new content (virtual tours, videos, new pages, etc.) One of my reasons for moving to wordpress is to keep up with current trends a little easier since I have very little time. (I am owner, website maintainer, SEO - all on my own). My question here is three parts. 1. Do you think this strategy will work to preserve my current rankings? 2. Do you have any lessons learned or advice to share with me to make this as smooth as possible? 3. Do I really need to wait to add new content? I might get antsy and want to do it sooner! 🙂 Thank you in advance!
Web Design | | CalicoKitty20001 -
Question on Breadcrumb and Canonical
Hi SEOmozers, I have another question. =] Thanks in advance. First question: How important is the breadcrumb for SEO? I know that breadcrumb makes better UX because it shows how the visitor landed on this page and the breadcrumb may show up in the search engine. But other than that, how important is it? Second Question: If I have a page that can be found via 2 locations, how should I handle this in regards to breadcrumb? For example, I have page A. You can access page A via Category A and Category B. Therefore, what I did was list Page A under Category A and when someone visit Category B and click on Page A, it will redirect to the page A that was found via Category A. The problem is on page A, the breadcrumb is Home > Category A > Page A. So if someone visit Category B and click on Page A, it redirects and the breadcrumb shows Home > Category A > Page A. What should I do with the breadcrumb for Category B > Page A? Should I create another page A and just use canonical on it? Should I create another page A but do not index it? or leave it as is? 1 Page A, can be access via 2 categories. Please advise. Thank you!
Web Design | | TommyTan0
