403 forbidden, are these a problem?
Hi
I have just run a crawl test on screaming frog and it is showing quite a few 403 forbidden status codes.
We are showing none of these in webmaster tools, is this an issue?
Your welcome! Anytime
Followed advice ran report again, now 100% 200: OK, really chuffed thanks!
Thanks guys I will get that sorted.
Still very much a beginner and part time (late nights on our own sites) but this pro membership is proving priceless.
Really appreciate the help!
SEo Executive is correct. uyou have some flooding protection on
i doubt very much if you are a target for DOS attacks so get ried of it
this is how crawlers see your code
Forbidden access
(Flooding)
Yes it's an issue and I will help you fix this:
I noticed you are using sh404sef
From the back end of your site you will need to go to sh404sef
Then sh404sef configuration security tab,
At the bottom, you will find an option below "Anti-flood configuration", you will need to set "Activate anti-flood" to "No".
Yes sure.
Yes it means the crawler has no permissions to crawl the page.
Can we get the domain so we can check, use a tiny url if you dont want it shown
Problems with Meta Title on Bing
On the Bing search engine, it isn't showing the actual meta title we have for a website. It's showing something different. However, the correct meta title is showing on the Google search engine. Has anyone had the same issue? Has anyone been able to fix this issue? Thanks for your help!
Technical SEO | | Harrison.Stickboy0 -
Problem with Yoast not seeing any of this website's text/content
Hi, My client has a new WordPress site http://www.londonavsolutions.co.uk/ and they have installed the Yoast Premium SEO plug-in. They are having issues with getting the lights to go green and the main problem is that on most pages Yoast does not see any words/content – although there are plenty of words on the pages. Other tools can see the words, however Yoast is struggling to find any and gives the following message:- Bad SEO score. The text contains 0 words. This is far below the recommended minimum of 300 words. Add more content that is relevant for the topic. Readability - You have far too little content. Please add some content to enable a good analysis. They have contacted the website developer who says that there is nothing wrong, but they are frustrated that they cannot use the Yoast tools themselves because of this issue, plus Yoast are offering no support with the issue. I hope that one of you guys has seen this problem before, or can spot a problem with the way the site has been built and can perhaps shed some light on the problem. I didn't build the site myself so won't be offended if you spot problems with it. Thanks in advance, Ben
Technical SEO | | bendyman0 -
Are thousands of 404s a problem?
An ecommerce site I work on has around 16,000 URLs that are 404s in Webmaster Tools. The vast majority are for products that are no longer stocked by the site, which is a natural occurrence in ecommerce. But my question is, could these possibly be harming rankings?
Technical SEO | | creativemay1 -
403 forbidden error how to solve them
hi, i have been using a great tool today called screaming frog which was shown to me by Thomas Zickell when i used the tool i found some worrying things for my site www.in2town.co.uk. what i have found is, i have a large number of 403 forbidden status on my home page and i do not know why here is an example http://www.in2town.co.uk/emmerdale/emmerdale-debbie-hits-rock-bottom it loads fine but on the tool it shows it as an error and shows it as having no meta tags or anything but there is meta tags in there can anyone please let me know how to solve this and why it has happened many thanks
Technical SEO | | ClaireH-1848860 -
We have set up 301 redirects for pages from an old domain, but they aren't working and we are having duplicate content problems - Can you help?
We have several old domains. One is http://www.ccisound.com - Our "real" site is http://www.ccisolutions.com The 301 redirect from the old domain to the new domain works. However, the 301-redirects for interior pages, like: http://www.ccisolund.com/StoreFront/category/cd-duplicators do not work. This URL should redirect to http://www.ccisolutions.com/StoreFront/category/cd-duplicators but as you can see it does not. Our IT director supplied me with this code from the HT Access file in hopes that someone can help point us in the right direction and suggest how we might fix the problem: RewriteCond%{HTTP_HOST} ccisound.com$ [NC] RewriteRule^(.*)$ http://www.ccisolutions.com/$1 [R=301,L] Any ideas on why the 301 redirect isn't happening? Thanks all!
Technical SEO | | danatanseo0 -
Is it a problem to have a homepage with a slug / URL ?
Hi, We are designing a web site for one of our clients, and using a home made CMS. I don't know how this CMS has been built, but anyways, in the end the homepage has a URL format which looks like this : www.mydomain.com/my-custom-url.html. No www.mydomain.com. Is it dangerous for SEO to have a slug/URL directly on the homepage ? Do you have experiences, cases where it has impacted a site negatively ? The main problem I expect is duplicate content (with Google seeing both www.mydomain.com and www.mydomain.com/my-custom-url.html as being different pages) but apparently the CMS is doing a 302 redirect from the root domain to the URL (I told my colleague it should at least be a 301). Sorry if this question seems like basic SEO knowledge, but I really can't find a definitive answer on the subject. Thank you very much 🙂
Technical SEO | | edantadis0 -
Duplicate content problem from an index.php file
Hi One of my sites is flagging a duplicate content problem which is affecting the search rankings. The duplicate problem is caused by http://www.mydomain.com/index.php which has a page rank of 26 How can I sort the duplicate content problem, as the main page should just be http://www.mydomain.com which has a page rank of 42 and is the stronger page with stronger links etc Many Thanks
Technical SEO | | ocelot0 -
403 forbidden error website
Hi Mozzers, I got a question about new website from a new costumer http://www.eindexamensite.nl/. There is a 403 forbidden error on it, and I can't find what the problem is. I have checked on: http://gsitecrawler.com/tools/Server-Status.aspx
Technical SEO | | MaartenvandenBos
result:
URL=http://www.eindexamensite.nl/ **Result code: 403 (Forbidden / Forbidden)** When I delete the .htaccess from the server there is a 200 OK :-). So it is in the .htaccess. .htaccess code: ErrorDocument 404 /error.html RewriteEngine On
RewriteRule ^home$ / [L]
RewriteRule ^typo3$ - [L]
RewriteRule ^typo3/.$ - [L]
RewriteRule ^uploads/.$ - [L]
RewriteRule ^fileadmin/.$ - [L]
RewriteRule ^typo3conf/.$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !-l
RewriteRule .* index.php Start rewrites for Static file caching RewriteRule ^(typo3|typo3temp|typo3conf|t3lib|tslib|fileadmin|uploads|screens|showpic.php)/ - [L]
RewriteRule ^home$ / [L] Don't pull *.xml, *.css etc. from the cache RewriteCond %{REQUEST_FILENAME} !^..xml$
RewriteCond %{REQUEST_FILENAME} !^..css$
RewriteCond %{REQUEST_FILENAME} !^.*.php$ Check for Ctrl Shift reload RewriteCond %{HTTP:Pragma} !no-cache
RewriteCond %{HTTP:Cache-Control} !no-cache NO backend user is logged in. RewriteCond %{HTTP_COOKIE} !be_typo_user [NC] NO frontend user is logged in. RewriteCond %{HTTP_COOKIE} !nc_staticfilecache [NC] We only redirect GET requests RewriteCond %{REQUEST_METHOD} GET We only redirect URI's without query strings RewriteCond %{QUERY_STRING} ^$ We only redirect if a cache file actually exists RewriteCond %{DOCUMENT_ROOT}/typo3temp/tx_ncstaticfilecache/%{HTTP_HOST}/%{REQUEST_URI}/index.html -f
RewriteRule .* typo3temp/tx_ncstaticfilecache/%{HTTP_HOST}/%{REQUEST_URI}/index.html [L] End static file caching DirectoryIndex index.html CMS is typo3. any ideas? Thanks!
Maarten0
