Loss of search engine positions after 301 redirect - what went wrong?!?
Hi Guys
After adhering to the On Page optimisation suggestions given by SEOmoz, we redirected some of old urls to new ones. We set 301 redirects from the old pages to new on a page by page basis but our search engine ranking subsequently fell off the radar and lost PR.
We confirmed redirection with fiddler and it shows 301 permanent redirect on every page as expected.
To manage redirection using a common code logic we executed following:
- In Http module, using “rewrite path” we route “all old page requests” to a page called “redirect.aspx? oldpagename =[oldpagename]”. This happens at server side.
- In redirect.aspx we are redirecting from old page to new page using 301 permanent redirect.
- In the browser, when old page is requested, it will 301 redirect to new page.
In hope we and others can learn from our mistakes - what did we do wrong ?!?
Thanks in advance.
Dave - www.paysubsonline.com
Chris - thanks for the heads up. It's been a month since we made the changes and we haven't started to crawl back up the rankings yet. I'll see how it goes and report back.
Cheers
Dave
Dan - thanks for the info. Looks like we have some tidying up and a few tasks to do!
I was talking about Google but looking at the reports, we have suffered with Bing and Yahoo too.
I would have set up 301s in .htaccess.
However, I think you may just be citing a correlation not causation. You have some WAY bigger issues:
1. The homepage can be arrived at by:
- paysubsonline.com
- paysubsonline.com/index.aspx <--returns a 404
- www.paysubsonline.com/index.php <-- loads a "coming soon" page, completely different than homepage, though which you can get to - https://paysubsonline.com/howitworks.php and others etc...
- www.paysubsonline.com/index.html <---returns a 404
Redirect all possible variations on the homepage to one singular version and fix that old site that's showing up.
2. Your sitemap has all URLs that look outdated (.htm extension and have "www" while the internal links in your site do not have "www") <--update your XML sitemap and resubmit to webmaster tools
3. You have not robots.txt file.
4. You have no canonical tag - which would be the last possible line of defense against all the duplicate content.
I'd start with those things, hope that helps.
-Dan
Yes, that is a very good point.
Dave,
Assuming your 301 redirects are technically correct then it will take time for your new page URLs to be indexed by the major search engines.
Be aware that your rankings may not come back 100% as they were before the change.
A 301 redirect does not pass all the PR and linkjuice as many SEO's assume. You can read about it in this interview with Matt Cutts and in this illustrated summary from Rand on SEOMoz
From my personal experience what you are seeing is normal just keep doing the good work you are currently doing a quite Google search with info:yournewdomain will show if your new domain has been added to the index.
May I know which search engine rankings fell off the radar?
If it is the rankings of the old URLs, then it might be because 301 redirection would pass your link juice from the old to the new pages. It might also be good to see your new page's rankings.
It might take a little time for the passing of link juice from old to new and thus is the reason for the change in rankings.
Redirection chain and Javascript Redirect
Hi, A redirection chain is usually defined as a page redirecting to another page which itself is another redirection. URL1 ---(301/302)---> URL2 ---(301/302)---> URL3 But what about Javascript redirect? They seem to be a different beast: URL1 ---(301/302)---> URL2 ---(200 then Javascript redirect)---> URL3 From what I know if the javascript redirect is instant Google counts it as a 301 permanent redirection, but I'm still not sure about if this counts as a redirection chain. Most of the tools (such as moz) only see the first redirection. So is that scenario a redirection chain or no?
Technical SEO | | LouisPortier0 -
What to do with old content after 301 redirect
I'm going through all our blog and FAQ pages to see which ones are performing well and which ones are competing with one another. Basically doing an SEO content clean up. Is there any SEO benefit to keeping the page published vs trashing it after you apply a 301 redirect to a better performing page?
Technical SEO | | LindsayE0 -
Proper 301 redirect code for http to https
I see lots of suggestions on the web for forwarding http to https. I've got several existing sites that want to take advantage of the SSL boost for SEO (however slight) and I don't want to lose SEO placements in the process. I can force all pages to be viewed through the SSL - that's no problem. But for SEO reasons, do I need to do a 301 redirect line of code for every page in the site to the new "https" version? Or is there a way to catch all with one line of code that Google, etc. will recognize & honor?
Technical SEO | | wcksmith10 -
Meta descriptions and h1 tags during a 301 redirect
My employer is shifting to a new domain and i am in the midst of doing URL mapping. I realize that many of the meta descriptions and H1 tags are different on the new pages - is this a problem ? Thank you.
Technical SEO | | ptapley0 -
301 redirect relative or absolute path?
Hello everyone, Recently we've changed the URL structure on our website, and of course we had to 301 redirect the old urls to the coresponding new ones. The way the technical guys did this is: "http://www.domain.com/old-url.html" 301 redirect to "/new-url.html"
Technical SEO | | Silviu
meaning as a relative redirect path, not an absolute one like this:
"http://www.domain.com/old-url.html" 301 redirect to "http://www.domain.com/new-url.html" This happened for few thousands urls, and the fact is the organic traffic dropped for those pages after this change. (no other changes were made on these pages and the new urls are as seo friendly as possible, A grade on On-Page Grader). The question is: does the relative redirect negatively affects seo, or it counts the same as an absolute path redirect? Thanks,
S.0 -
HELP: Wrong domain showing up in Google Search
So i have this domain (1)devicelock.com and i also had this other domain (2)ntutility.com, the 2nd domain was an old domain and it is not in use anymore. But when i search for devicelock on Google, the homepage devicelock.com does not exist. Only ntutility.com comes up. I asked one of the developer how the redirect is happening from the old domain to the new one and he told me its through a DNS forward. And there is no way to have an .htacess file to set up a 301 instead. Please help!
Technical SEO | | Devicelock0 -
Can you do a 301 redirect without a hosting account?
Trying to retire domain1 and 301 it to domain2 - just don't want to get stuck having to pay the old hosting provider simply to serve a .htaccess file with the redirect rule.
Technical SEO | | TitanDigital0 -
301 redirects & merging two sites into one
We have a client that has two sites that rank well for different searches in their market. The main pages ranking are things like advice articles and news pieces. For various reasons, they just want one site. I believe they need to duplicate the content from the outgoing site and place it on the main site, with a 301 redirect from each old page to each new one. What happens when they eventually want to redirect the entire domain? Would these smaller, internal redirects become obsolete, therefore removing any link value they once had? I am not sure how this works or if there is a best practice way to do this. Thanks Gareth
Technical SEO | | Gmorgan0
