301 for "index.php" in Web.config?
Hi there, I'm trying to create a 301 redirect for the file "index.php" but I keep getting a "fail to redirect" message in Firefox whenever I insert it into the Web.config file.
<location path="index.php"></location>
Is there anyway around this? Thanks for any help
According to Open Site Explorer, there are about 500 links to my index file but it only has a 302 status so will not be passing link juice.
Hi Alan,
Thanks for that, it worked perfectly!
Yannick seems to have it right, but here is another way
<system.webserver><rewrite><rules><rule name="DefaultRule" stopprocessing="true"><match url="^index.php"><action type="Redirect" url="/" =""></action></match></rule></rules></rewrite></system.webserver>
Did you add/activate all the right plugins/dll files?
Thanks Yannick,
I'm using the configuration tag and there isn't a CMS being used. The page is accessible via index.php, but I'm currently redirecting it using a PHP script (this is fine but it doesn't provide a 301 redirect).
I'd hopefully like to replace this using the web.config file but it only results in an internal server error or an infinite loop.
Thanks again.
<configuration><location path="index.php"></location></configuration>
Did you add the configuration part?
Is your home page available on the / part of your domain? Or is it only accessible via index.php? What CMS are you using?
Link rel="prev" AND canonical
Hi guys, When you have several tabs on your website with products, you can most likely navigate to page 2, 3, 4 etc...
Technical SEO | | AdenaSEO
You can add the link rel="prev" and link rel="next" tags to make sure that 1 page get's indexed / ranked by Google. am I correct? However this still means that all the pages can get indexed, right? For example a webshop makes use of the link rel="prev" and ="next" tags. In the Google results page though, all the seperate tabs pages are still visible/indexed..
http://www.domain.nl/watches/?tab=1
http://www.domain.nl/watches/?tab=24
http://www.domain.nl/watches/?tab=19
etc..... Can we prevent this, and make sure only the main page get's indexed and ranked, by adding a canonical link on every 'tab page' to the main page --> www.domain.nl/watches/ I hope I explained it well and I'm looking forward to hearing from you. Regards, Tom1 -
"Search Box Optimization"
A client of ours recently received en email from a random SEO "company" claiming they could increase website traffic using a technique known as "search box optimization". Essentially, they are claiming they can insert a company name into the autocomplete results on Google. Clearly, this isn't a legitimate service - however, is it a well known technique? Despite our recommendation to not move forward with it, the client is still very intrigued. Here is a video of a similar service:
Technical SEO | | McFaddenGavender
https://www.youtube.com/watch?v=zW2Fz6dy1_A0 -
How can I Style Long "List Posts" in Wordpress?
Hi All, I have been working on a list-post which spans over 100 items. Each item on the list has a quick blurb to explain it, an image and a few resource links. I am trying to find an attractive way to present this long list post in Wordpress. I have seen several sites with long list posts however; they place their items one on top of the other which yields a VERY long page and the end user has to do a lot of scrolling. Others turn their lists into slideshows, but I have no data on how slides perform against 10-mile-long-lists which load in 1 page. I would like to do something similar to what List25.com does as they present about 5-10 items per page and they seem to have pagination. The pagination part I understand however; is there a shortcode plugin to format lists in an attractive way just like list25?
Technical SEO | | IvanC0 -
Rel="external"
Hi all, I got a link and its off a site and marked up with rel="external". Is this a followed or nofollowed link? Does it pass link juice? Thanks
Technical SEO | | Sharer0 -
How valuable is content "hidden" behind a JavaScript dropdown really?
I've come across a method implemented by some SEO agencies to fill up pages with somehow relevant text and hide it behind a javascript dropdown. Does Google fall for such cheap tricks? You can see this method used on these pages for example (just scroll down to the bottom) - it's all in German, but you get the idea I guess: http://www.insider-boersenbrief.de/ http://www.deko-und-kerzenshop.de/ How is you experience with this way of adding content to a site? Do you think it is valuable or will it get penalised?
Technical SEO | | jfkorn0 -
Does it really matter to maintain 301 redirect after de-indexing of old URLs?
Today, I was reading latest blog post on SEOmoz blog about. Uncrawled 301s - A Quick Fix for When Relaunches Go Too Well This is very interesting study about 301 & How it useful to maintain traffic. I'm working on eCommerce website and I have done similar stuff on my website. I have big confusion to manage 301 redirect. My website generates new URLs due to following actions. Re-write dynamic URLs. Re-launch entire website on different eCommerce platform. [osCommerce to Magento Commerce] Re-name category. Trasfer one product from one category to another category. I'm managing my 301 redirect with old practice. Excel sheet data from Google webmaster tools and set specific new URLs for redirect. Hoooo... Now, I have 8.5K redirect in htaccess... And, I'm thinking it's too much. Can we remove old 301 redirect from htaccess or not? This is big question for me. Because, all pages are not hyperlink on external website. Google have just de-indexed old URLs and indexed new URLs. So, Is it require to maintain 301 redirect after Google process?
Technical SEO | | CommercePundit0 -
Should we use "and" or "&"?
Our client has an ampersand in their brand name. The logo has "&", their url is spelled out. I'm trying to get them to standardize the use of the name for directories/listings. Should we use "and" or "&"?
Technical SEO | | vernonmack0 -
Multiple Domains, Same IP address, redirecting to preferred domain (301) -site is still indexed under wrong domains
Due to acquisitions over time and the merging of many microsites into one major site, we currently have 20+ TLD's pointing to the same IP address as our "preferred domain:" for our consolidated website http://goo.gl/gH33w. They are all set up as 301 redirects on apache - including both the www and non www versions. When we launched this consolidated website, (April 2010) we accidentally left the settings of our site open to accept any of our domains on the same IP. This was later fixed but unfortunately Google indexed our site under multiple of these URL's (ignoring the redirects) using the same content from our main website but swapping out the domain. We added some additional redirects on apache to redirect these individual pages pages indexed under the wrong domain to the same page under our main domain http://goo.gl/gH33w. This seemed to help resolve the issue and moved hundreds of pages off the index. However, in December of 2010 we made significant changes in our external dns for our ip addresses and now since December, we see pages indexed under these redirecting domains on the rise again. If you do a search query of : site:laboratoryid.com you will see a few hundred examples of pages indexed under the wrong domain. When you click on the link, it does redirect to the same page but under the preferred domain. So the redirect is working and has been confirmed as 301. But for some reason Google continues to crawl our site and index under this incorrect domains. Why is this? Is there a setting we are missing? These domain level and page level redirects should be decreasing the pages being indexed under the wrong domain but it appears it is doing the reverse. All of these old domains currently point to our production IP address where are preferred domain is also pointing. Could this be the issue? None of the pages indexed today are from the old version of these sites. They only seem to be the new content from the new site but not under the preferred domain. Any insight would be much appreciated because we have tried many things without success to get this resolved.
Technical SEO | | sboelter0
