How to fix issues regarding URL parameters?
Today, I was reading help article for URL parameters by Google.
http://www.google.com/support/webmasters/bin/answer.py?answer=1235687
I come to know that, Google is giving value to URLs which ave parameters that change or determine the content of a page. There are too many pages in my website with similar value for Name, Price and Number of product. But, I have restricted all pages by Robots.txt with following syntax.
URLs:
http://www.vistastores.com/table-lamps?dir=asc&order=name
http://www.vistastores.com/table-lamps?dir=asc&order=price
http://www.vistastores.com/table-lamps?limit=100Syntax in Robots.txt
Disallow: /?dir=
Disallow: /?p=
Disallow: /*?limit=Now, I am confuse. Which is best solution to get maximum benefits in SEO?
No i dont think so, even if the thought they were duplicate, then they will pick one as the original. so one of them will rank.
If you are still concerned use tha canonicall tag, rather them remove them from index
Your concern is that, Google will crawl following all pages. If I will not do any thing with those pages. Right?
http://www.vistastores.com/table-lamps?limit=100&p=2
http://www.vistastores.com/table-lamps?limit=60&p=2
http://www.vistastores.com/table-lamps?limit=40&p=2
Now, my website is on 3rd page of Google for Discount Table Lamps keyword.
I have fear that, If Google will crawl multiple pages with duplicate Title tag so it may mesh up current ranking for Discount Table Lamps keyword.
What you think about it?
If the content is different, then dont do anything, but if it is duplicate us ethe canonical tag.
The meta tages are not a problem, you are not going to get flaged for that, it would be better if you could make them unique but this is a very small problem
Will it really work? Because, both page have different content.
http://www.vistastores.com/table-lamps have 100 products and
http://www.vistastores.com/table-lamps?limit=100&p=2 have different + unique 100 products.
One another problem is regarding Meta info. Both page have same Meta info. If Google will index both pages so it may create warning message for duplicate Meta info across too many pages.
Thats the advice i gave you, put a canonical tag in the page
rel="canonical" href="http://www.vistastores.com/table-lamps"/>
if google finds http://www.vistastores.com/table-lamps?dir=asc&order=name
it will know it5 is mean to be http://www.vistastores.com/table-lamps
Honestly, I did not getting it. Because, I have read one help article about URL parameters by Google.
It shows me some different thing. Google suggested to use Google webmaster tools. But, I have restricted all dynamic pages by robots.txt.
So, I want to know best practice which may help me to gain my crawling and no of indexed pages.
I would simplty put a rel canonical in the page point ing to the true URL. so SE's will see them as one page.
It is better to use cononical for the reasons in the google doc you posted, goolge may not pick the nest url to be the canonical, you should make that choice for them
410 or 301 after URL update?
Hi there, A site i'm working on atm has a thousand "not found" errors on google console (of course, I'm sure there are thousands more it's not showing us!). The issue is a lot of them seem to come from a URL change. Damage has been done, the URLs have been changed and I can't stop that... but as you can imagine, i'm keen to fix as many as humanly possible. I don't want to go mad with 301s - but for external links in, this seems like the best solution? On the other hand, Google is reading internal links that simply aren't there anymore. Is it better to hunt down the new page and 301-it anyway? OR should I 410 and grit my teeth while google crawls and recrawls it, warning me that this page really doesn't exist? Essentially I guess I'm asking, how many 301s are too many and will affect our DA? And what's the best solution for dealing with mass 404 errors - many of which aren't attached or linked to from any other pages anymore? Thanks for any insights 🙂
Intermediate & Advanced SEO | | Fubra0 -
All URLs in the site is 302 redirected to itself
Hi everyone, I have a problem with a website wherein all URLs (homepage, inner pages) are 302 redirected. This is based on Screaming Frog crawl. But the weird thing is that they are 302 redirected to themselves which doesn't make any sense. Example:
Intermediate & Advanced SEO | | alex_goldman
https://www.example.com.au/ is 302 redirected to https://www.example.com.au/ https://www.example.com.au/shop is 302 redirected to https://www.example.com.au/shop https://www.example.com.au/shop/dresses is 302 redirected to https://www.example.com.au/shop/dresses Have you encountered this issue? What did you do to fix it? Would be very glad to hear your responses. Cheers!0 -
If I block a URL via the robots.txt - how long will it take for Google to stop indexing that URL?
Intermediate & Advanced SEO | | Gabriele_Layoutweb0 -
URL Rewriting Best Practices
Hey Moz! I’m getting ready to implement URL rewrites on my website to improve site structure/URL readability. More specifically I want to: Improve our website structure by removing redundant directories. Replace underscores with dashes and remove file extensions for our URLs. Please see my example below: Old structure: http://www.widgets.com/widgets/commercial-widgets/small_blue_widget.htm New structure: https://www.widgets.com/commercial-widgets/small-blue-widget I've read several URL rewriting guides online, all of which seem to provide similar but overall different methods to do this. I'm looking for what's considered best practices to implement these rewrites. From what I understand, the most common method is to implement rewrites in our .htaccess file using mod_rewrite (which will find the old URLs and rewrite them according to the rewrites I implement). One question I can't seem to find a definitive answer to is when I implement the rewrite to remove file extensions/replace underscores with dashes in our URLs, do the webpage file names need to be edited to the new format? From what I understand the webpage file names must remain the same for the rewrites in the .htaccess to work. However, our internal links (including canonical links) must be changed to the new URL format. Can anyone shed light on this? Also, I'm aware that implementing URL rewriting improperly could negatively affect our SERP rankings. If I redirect our old website directory structure to our new structure using this rewrite, are my bases covered in regards to having the proper 301 redirects in place to not affect our rankings negatively? Please offer any advice/reliable guides to handle this properly. Thanks in advance!
Intermediate & Advanced SEO | | TheDude0 -
Duplicate URLs ending with #!
Hi guys, Does anyone know why a site can contain duplicate URLs ending with hastag & exclamation mark e.g. https://site.com.au/#! We are finding a lot of these URLs (as duplicates) and i was wondering what they are from developer standpoint? And do you think it's worth the time and effort adding a rel canonical tag or 301 to these URLs eventhough they're not getting indexed by Google? Cheers, Chris
Intermediate & Advanced SEO | | jayoliverwright0 -
Product or Shop in URL
What do you think is better for seo and for sale, I am using woo-ecommerce for health products website. websitename.com/product/keyword OR websitename.com/shop/keyword
Intermediate & Advanced SEO | | MasonBaker0 -
URL mapping for site migration
Hi all! I'm currently working on a migration for a large e-commerce site. The old one has around 2.5k urls, the new one 7.5k. I now need to sort out the redirects from one to the other. This is proving pretty tricky, as the URL structure has changed site wide. There doesn't seem to be any consistent rules either so using regex doesn't really work. By and large, the copy appears to be the same though. Does anybody know of a tool I can crawl the sites with that will export the crawled url and related copy into a spreadsheet? That way I can crawl both sites and compare the copy to match them up. Thanks!
Intermediate & Advanced SEO | | Blink-SEO0 -
Does Google index url with hashtags?
We are setting up some Jquery tabs in a page that will produce the same url with hashtags. For example: index.php#aboutus, index.php#ourguarantee, etc. We don't want that content to be crawled as we'd like to prevent duplicate content. Does Google normally crawl such urls or does it just ignore them? Thanks in advance.
Intermediate & Advanced SEO | | seoppc20120
