Redirecting all URLs appended with index.htm or index.html
It has come to my attention with one of my clients (WordPress website) that for some time they have within their Landing Page report (of GA - Google Analytics) URLs that should all be pointing to the one page, example:
domain.com/about-us, also has a listing in GA as domain.com/about-us/index.htm
Is this some kind of indication of a subdirectory issue? Has anyone had experience with this in such wordpress plugins as Yoast SEO, or other SEO plugin?
My thoughts here are to simply redirect any of these non-existent files with a redirect in .htaccess - but what I'm using isn't working. I will insert the redirect here - - and any help would be greatly appreciated.
RewriteEngine onRewriteCond %{THE_REQUEST} ^./index.html?
RewriteRule ^(.)index.html?$ http://www.dupontservicecenter.com/$1 [R=301,L]and this rewrite doesn't work:
RewriteEngine on
RewriteRule ^(.+).htm$ http://dupontservicecenter.com/$1.php [R,NC]_Cindy
ThompsonPaul,
Thank you! I've looked at that feature so many times, and read and reread the info Google provided, and clearly reading this information literally, as someone at my level would, it really doesn't specify whether adding the default page "adds" index.htm(l) to the url and therefore combines all "same-pages" or if it removes it to combine "same-pages"
-- and I assumed the later since that is what happens with permalinks in WP... go figure. Now I realize it adds. Also it didn't occur to me that this feature wouldn't act as a filter would and you would see the results right away.
OK so I have removed "index.htm" from the default page field, it is all clear now. Additionally I am also showing appended to my url's an "index.html" -- and this is in addition the actual url. So I am seeing, for example:
/about-us/ /about-us/index.htm and in some cases urls like /about-us/index.html.
I can only guess that at one time both of these default urls were in the default page setting... "index.html" and "index.htm" And anyway these pages with index.htm(l) do not exist, ...which would explain that right, likely this issue concerns settings in GA
So one more perplexing issue - in the search console landing page report I am showing 0 hits for any url appended with either index.htm or index.html.
But in the regular reporting of landing pages, and also custom reporting, these pages are showing hits (pages appended w index.htm(l)). What could cause this discrepancy?
As you suggestion it would take a bit of filtering to clean up these url's in Google Analytics? And so if it is in Google Analytics then any redirect in the htaccess file is for naught?
So a several weeks, likely for this small business site, to begin showing clean urls and to see if this is actually this issue?
Thank you so very much!
_Cindy
Thomas, thank you for your help. I did occur to me that perhaps the order of items in the htaccess file may be the issue.
I am going to look into this issue - thanks to your suggestion, and then see if my redirects are working as they should.
When I do, I'll get back to you on this topic.
Now, I'm trying to wrap my mind around the issue of why "index.htm and index html" when my site is WP based and therefore a PHP framework. ThompsonPaul has responded with what was my next look (and actually a 4th to 8th look) concerning the default page setting in GA.
Thanks again.
_Cindy -
Cindy, this is almost certainly an issue with the way your Google Analytics is configured, not your WP site. (the fact the "index.htm" comes after a "/" is the clue.
If you check the View Settings link under the View in the Admin section of your dashboard, you'll find a field called Default Page. For most correctly configured modern sites (WP sites included), this field must be empty for GA to be configured correctly. I'm betting your config has index.htm entered in that field. [See screenshot below.]
Once you remove that entry, your data will avoid the problem going forward, but it will take some work with custom filters if you want to try to clean up the historical data.
Let me know if that solves the issue?
Are you able to copy out your whole htaccess?
I've got to admit, i'm not the best with it but I'll try and help you figure this out
Hi Thomas,
Very much appreciate your reponse.
So far none of the redirects are working, including your suggestion. So I tested the htaccess file with this redirect, changing one of the redirects already listed in the htaccess file for some time now, which use to work...
RewriteCond %{HTTP_HOST} ^dupontservicecenter.com/buying-and-selling$
RewriteRule ^$ http://dupontservicecenter.com/rewards/auto-service-credit [L,R=301]...not working, is redirecting to the old url, the one I changed.
I have purged cache (using litespeed cache for wp since I'm on a litespeed server these days). Could it be a purge issue? What would cause the htaccess file not to work properly?
The only redirect that is working is through a plugin for wp - quick redirects which uses the wp_redirect() function.
Totally lost in a haystack.
Any further suggestions would be helpful, otherwise, a complete, timely, breakdown of all website components will have to be proposed to the client.
_Cindy
https://cloudz.click/community/q/redirecting-index-html-to-the-root
StreamlineMetrics:
If you want to redirect all index.html(s) to their roots, then try this code -
RewriteEngine On
RewriteRule ^index.html$ / [R=301,L]
RewriteRule ^(.*)/index.html$ /$1/ [R=301,L]And yes, Google will treat them as 301 redirects so your juice will be transferred and consolidated.
Obviously, change index.html to index.htm
Website excluded from indexing, google-selected canonical: N/A
The google search console revealed to me that none of my pages was indexed, all pages are listed in the 'excluded' section "duplicate, google chose different canonical than user".
Reporting & Analytics | | Fibigrus
But in the URL-inspection tab it shows me google-selected canonical: N/A Indexing and crawling is both allowed. Don't know how to get my pages to be indexed correctly. (by the way, they do NOT exist in other languages, so that can't be a reason why google might think they are a duplicate. There's definitively no other version of those pages available)0 -
Vanity URL vs domain URL
Hi guys, Our CEO is having an interview with a known broadcaster on radio. During the interview he will mention a specific URL www.example.com/marketingcampaign that we want track on Google Analytics, therefore behaving like a vanity URL redirecting to the actual URL www.example.com/resources/primary-keyword-2018. Would this work the same way a vanity URL in terms of tracking or not such as following guideline here ? I am asking because vanity URLs are supposed to be completely different domain name that gets purchased and in our case it is the same domain name just with a different URI. thanks guys!
Reporting & Analytics | | Taysir0 -
"index.htm" for all url's in google analytics
I don't have this issue with other wordpress websites, only this one website, and I don't know what's causing the issue: Google Analytics is adding an "index.htm" to every single page on the website. So it is tracking the pages, I see no errors - is it tracking the right page? When I click on the page link in a report, I naturally go to a "404 page not found" since the website address isn't "www.example.com/rewards/index.htm" - but instead the actual address would be:
Reporting & Analytics | | cceebar
"www.example.com/rewards/". I have navigated to View Settings in GA to insure "default page" is empty. Although adding anything else to this field does not effect the page url in analytics reports either. Could it be htaccess file - or a plugin effecting the htaccess file?_Cindy0 -
How to get multiple pages to appear under main url in search - photo attached
How do you get a site to have an organized site map under the main url when it is searched as in the example photo? SIte-map.png
Reporting & Analytics | | marketingmediamanagement0 -
Switch to www from non www preference negatively hit # pages indexed
I have a client whose site did not use the www preference but rather the non www form of the url. We were having trouble seeing some high quality inlinks and I wondered if the redirect to the non www site from the links was making it hard for us to track. After some reading, it seemed we should be using the www version for better SEO anyway so I made a change on Monday but had a major hit to the number of pages being indexed by Thursday. Freaking me out mildly. What are people's thoughts? I think I should roll back the www change asap - or am I jumping the gun?
Reporting & Analytics | | BrigitteMN0 -
Google Analytics Organic Search Keywords Suddenly Displaying FulL Urls
In my Google Analytics, the top keywords for Organic Search are suddenyl displaying full URLs. For example, now the third and fourth keywords are http://www.domain.com/highly-specific-URL. These have all started recently around the same day, July 12th. I've checked back, and we've made no internal changes to the site around that time that could affect this. Any thoughts on this? Thanks! P.S. It might be related to rich snippets, but I cannot tell at this point.
Reporting & Analytics | | 10SL0 -
How to remove unwanted dynamic parameters from a URL in Google Analytics
Hi, Would really appreciate some help with this. I have been experimenting with RegEx to achieve this but as I’ve never used it before am currently failing miserably. We have conversion pages i need to set goals for that are formatted as below: https://www.domain.co.uk//Application_Form/(S(ewhbqp5cki0mppuzukunkqno))/enterCardDetails.aspx I need to remove the (s(xxx)) section from the URL as rather than one pages i currently have thousands of unique URL's. What’s catching me out is that as it’s not a URL parameter I can’t discount and as half way through can’t just do head matches etc to /entercarddetails Help would be much appreciated. Thanks.
Reporting & Analytics | | Sarbs0 -
Why are Seemingly Randomly Generated URLs Appearing as Errors in Google Webmaster Tools?
I've been confused by some URLs that are showing up as errors in our GWT account. They seem to just be randomly generated alphanumeric strings that Google is reporting as 404 errors. The pages do 404 because nothing ever existed there or was linked to. Here are some examples that are just off of our root domain: /JEzjLs2wBR0D6wILPy0RCkM/WFRnUK9JrDyRoVCnR8= /MevaBpcKoXnbHJpoTI5P42QPmQpjEPBlYffwY8Mc5I= /YAKM15iU846X/ymikGEPsdq 26PUoIYSwfb8 FBh34= I haven't been able to track down these character strings in any internet index or anywhere in our source code so I have no idea why Google is reporting them. We've been pretty vigilant lately about duplicate content and thin content issues and my concern is that there are an unspecified number of urls like this that Google thinks exist but don't really. Has anyone else seen GWT reporting errors like this for their site? Does anyone have any clue why Google would report them as errors?
Reporting & Analytics | | kimwetter0
