Moz Pro, our web crawler, and sites that use SNI (804 HTTPS SSL) error
Hello:
Have a clarifying question: using this site: https://globalsign.ssllabs.com/analyze one of our sites got the following status:
HTTP Strict Transport Security (HSTS) with long duration deployed on this server.
and not this one:
This site works only in browsers with SNI support.
However, we recently received this error through Moz:
Error Code 804: HTTPS (SSL) Error Encountered
Your page requires an SSL security certificate to load (using HTTPS), but the Moz Crawler encountered an error when trying to load the certificate.Please advise if the HTTP Strict Transport Security (HSTS) also causes the Error Code 804: HTTPS (SSL) Error Encountered in Moz?
Thank You
Anytime!
Brilliant David,
I appreciate the lengths you have gone to get more info on my issue. I will get the host to address this. Thanks very much!
Etienne
Hi Etienne
I checked the campaign you have with the 902 response and the issue is with your host blocking AWS IPs. I could not find any SSL or SNI errors for the domain.
You will want to reach out to your hosting provider to make sure they are not blocking any AWS IP ranges. Our IPs are dynamic so we will not be able to provide a range for you.
There are also other issues with the SSL configuration which will need to be looked at which could result in different errors once the IPs are unblocked.
http://www.screencast.com/t/b8qEdNah
You can run a test here for any SSL domain: https://globalsign.ssllabs.com/analyze.html
Hope this helps!
Hello Etienne - sorry to hear this.
Have you checked in with [email protected] yet? They might be able to fix your problem.
Hi Jon
Same problem this side, not sure if it's SNI. First we had 904 server error and then 902. Our site has not been crawled by RogerBot since 9 Oct when we switched from HTTP to HTTPS.
I am hoping for the best as I cannot use the full functionality of MOZ at the moment as we have one crawl error which completely keeps me in the dark as a SEO.
Many thanks
Etienne -
Do you have a rough ETA on the new crawler? Being without useful crawl data for several months has been painful
Can you recommend any suitable alternatives for web crawling our site while your new crawler is in development.
We already use screaming frog but it would be handy to have something that flagged up any problems like MOZ did with our other sites.
Cheers
OK great, thank you.
Yes the sign up link is in the very first post by Jon
The link is http://goo.gl/forms/LCvL9Ix8JDHfbAvr1
Hi @David,
You mention a beta, is there someplace that we signup? I am a Moz Pro account holder and haven't seen anything offered or an e-mail.
Please provide steps for signup, as currently we have clients that we can't crawl and still paying for Moz.
Hello!
I can confirm your site does use SNI which can be checked at https://globalsign.ssllabs.com/analyze.html?d=www.honesthouse.co.uk&latest
If anyone else is unsure about your own site, you can use the above link, replace the URL and click on any server results which will confirm SNI status shown here: http://www.screencast.com/t/GLzjD7gjzjR
As for any workaround, other than disabling SNI completely, the quickest option to get crawled would be to sign up for the beta.
Jon will keep everyone posted with any new status and I can assure you this is our top priority feature we are working on.
Hi Jon,
I think we might have the same problem.
Our site is https://www.honesthouse.co.uk/ and we're getting the 804 SSL error too
Is there anything we can do?
Cheers
Hello Aaron! Unfortunately I am unable to provide a date - mainly because if I did, I would be guessing, and I don't think that is helpful. We used to commit dates to releases, and we stopped, simply because our software is too complex to estimate accurately.
I will say it is close, I sent an email update earlier this week to all who sign up for the beta, I have included this below, it has a little more color:
Thank you for signing up for the Moz Pro Site Crawl beta. I wanted to give you all an update since it has taken us a little longer to get the beta ready for testing. We were hoping to have it out here by MozCon (this week) but we are slightly behind. In the interest of transparency:
- our current crawler does not support SNI (as you well know) and is simply too old and fragile to make meaningful updates to, so we decided in Q1 of this year to re-write our crawler
- the new re-written crawler will support SNI, be much faster and more reliable, and support many more configuration options inc. crawl speed, includes/excludes, UA (though some of these will not be available for the first beta)
- we will also be giving the UX and UI of the crawl a revamp in combination with this crawler
- whilst the SNI support works right now, we are ironing out some issues with the other parts of the crawler before we feel comfortable releasing it in beta
- we had hoped we would be able to show off the beta at MozCon this week but some recent changes have slowed us a little
- we will be offering a second free-trial for those who are not current customers and wish to try it again when it is ready
I appreciate your patience, we are very close and hope to have something soon.
Do we have a beta timeframe yet? It's been 3 months since the announcement that SNI crawl ability is coming and still no release. I have a very large client that I can't crawl their site. As a development company I can understand that good code takes time, but 3 solid months and really a over a year is what we're really looking at that Moz has known this was an issue.
Please provide us (as customers) with a solid date that SNI will be supported. I don't think that's too much to ask.
And a vote from me too Jon, I would need to this before converting from trial.
Good luck with it.
Just another vote to see this happen. I use SNI on some sites and a must have to be able to use Moz.
As a side not, I am not seeing any Google crawl errors in using SNI, at least not in Google Search Console.
Hi Phil - sorry you are seeing those errors. I do not have a firm date, it will likely be in the next few weeks though.
Hi Jon, Do you have an update as to when the new crawler will be available. We have just started getting 804 HTTPS SSL error's for one of our sites.
Thank you. I look forward to sharing something.
Great, we would like to participate as some results are better than nothing. We filled out the form so i suppose we wait.
Thanks for your response.
Firstly, I empathize with your decision to cancel, and I hope we can win you back in the future.
In terms of why a customer might participate. Many of our customers who have SNI problems are still Moz customers, and still use our Rankings, Links and Keyword Research tools. In this case, they would also be able to get some crawl data (albeit in a beta form) as a temporary fix whilst we finish the crawler. We had already planned to launch a beta with select customers, we think this might also help us help some customers who are having struggles with our product. But I realize this route is not for everyone.
Please let me know if there is any other feedback you guys have about Moz. [email protected]
Thank you for the update. We have several sites that cannot be crawled and after a lot of investigation have concluded we would need to cancel Moz. I'm glad this is being released and submitted the form to be contacted regarding the Beta Testing.
I am curious though, what is in it for us? As of now we are paying for a service that does not work. I seriously doubt we will be interested in continuing to pay for a service just to be a test dummy (which one of the requirements is a paid account, unless I am misunderstanding).
Either way, we are excited about the solution and interested in learning more.
Thanks.
Moz Q&A is closing, December 12th 2024
After more than 13 years, and tens of thousands of questions, we’re finally closing Moz Q&A. Whilst we’re not completely removing the content - many posts will still be possible to view - we’re locking both new posts and new replies. Why? The truth is that the conversation has moved elsewhere. Sites like Twitter, Reddit, and more recently BlueSky and LinkedIn, have largely replaced specialist forums. At the same time, the challenge of moderating a platform like this has become more difficult, and of course, we’re SEOs, and the sheer quantity of new pages generated, often by malicious actors, has its challenges in terms of what it does to the profile of our site. Forums are still an opportunity for many sites, in SEO and more broadly, but the calculus no longer works for Moz. Where can I ask my question instead? If you’re a customer or currently evaluating a free trial, you can reach out directly with questions about the product to our customer support team here. If you want to learn more about SEO, you can check our learning resources here, and we also offer the Moz Academy. If you just want to hang out, you can also still find us on X, BlueSky, or LinkedIn. Thank you We’re grateful to everyone who has contributed to Moz Q&A over the years. It’s been a blast, and we hope this isn’t the last time we’ll see you here on the Moz site.
Moz News | | Tom.Capper32 -
MozBar Login Change Update + Firefox Temporarily Disabled
Hello! I wanted to give you all a heads up about some changes we will be making to the MozBar very soon. We will be making an update to the MozBar that will require you to log in with either a free Community account or with your Moz subscription to access link metrics. Don’t worry! We will never charge you for link metrics in the MozBar. Why are we making this change?
Moz News | | Roxana_Nelson
The MozBar has historically made use of a free endpoint in our Mozscape API. Unfortunately, over time, we have been experiencing increasing levels of abuse on this endpoint. For a long time, we were able to manage this mis-use but recently we have reached a tipping point whereby this malicious traffic is starting to degrade other legitimate API traffic and cause performance issues within our products. By asking you to log in to the MozBar with either a free Community account or a Moz subscription, we can ensure only authenticated users are able to use the MozBar. Also, if you don’t need link metrics, you can still use the MozBar. Logged out users will still be able to access on-page information. A note to Firefox users
With this change, we will temporarily disable the Firefox version of the MozBar. You may have noticed that the Firefox and Chrome versions of the MozBar are not the same. This is due to Mozilla’s review process, and us being unable to get new versions approved despite multiple attempts. Good news on the horizon! Firefox will start accepting Chrome-based extensions with the release of Firefox v48, which means soon there will be one version of the MozBar. When v48 is released, we will re-enable the MozBar in Firefox. In the meantime you can use the free Google Chrome version. Thank you for your understanding while we make these changes in the MozBar! Please feel free to let us know what you think, or ask questions, in the comments below. Thanks!
Roxana11
