Upper case or/and lower case in rel="alternate" hreflang
Hi Mozzers,
I have a question about the rel="alternate" hreflang tag, with an example.
When I use two subfolders for two different countries/languages, for instance www.domain.com/nl-nl/ and www.domain.com/nl-en/ (for the English version) and I want to use the rel="alternate" hreflang tag, do I need to follow the ISO standards concerning Uppercase country code and Lowercase language code (en-NL)? Or is it okay to use the Lowercase country and language code (en-nl), since we also use this in the URL of the Subfolder.
What does Google prefer?
Thanks in advance.
Hey there, Lowercase is fine.
Not sure why you would have /nl-nl/ and /nl-en/ though, it's either English or Dutch, right?
I've set this up many times before and it works just fine, although it's sometimes a little overkill unless you have the English version of a page ranking higher than the Dutch version in Google.nl for example.
I usually find adding these as separate websites in WMT's and setting the target country correctly for each site you shouldn't have any problems.
So add http://www.domain.com/nl/ as its own site in WMT and set target country to Netherlands, then add http://www.domain.com/en/ as another site and set its target country to UK.
Hope this helps,
Goodluck,
Woody
Using same URL for both "en" and "en-us" hreflang tags
Hi,I have a question. Is it okay if I use the same URL for both "en" and "en-us" hreflang tags? For example, for my en-us page: Is this okay with Google? What are your thoughts on this?
International SEO | | Avid_Demand0 -
How do hreflang attributes affect ranking?
We have a site in English. We are considering translating the site into Dutch. If we use a hreflang attribute does that mean we have to create a duplicate page in Dutch for each English page, or does Google auto-translate? How would duplicate pages, even if they are in a different language, affect ranking?
International SEO | | Substance-create0 -
Redirect to 'default' or English (/en) version of site?
Hi Moz Community! I'm trying to work through a thorny internationalization issue with the 'default' and English versions of our site. We have an international set-up of: www.domain.com (in english) www.domain.com/en www.domain.com/en-gb www.domain.com/fr-fr www.domain.com/de-de and so on... All the canonicals and HREFLANGs are set up, except the English language version is giving me pause. If you visit www.domain.com, all of the internal links on that page (due to the current way our cms works) point to www.domain.com/en/ versions of the pages. Content is identical between the two versions. The canonical on, say, www.domain.com/en/products points to www.domain.com/products. Feels like we're pulling in two different directions with our internationalization signals. Links go one way, canonical goes another. Three options I can see: Remove the /en/ version of the site. 301 all the /en versions of pages to /. Update the hreflangs to point the EN language users to the / version. **Redirect the / version of the site to /en. **The reverse of the above. **Keep both the /en and the / versions, update the links on / version. **Make it so that visitors to the / version of the site follow links that don't take them to the /en site. It feels like the /en version of the site is redundant and potentially sending confusing signals to search engines (it's currently a bit of a toss-up as to which version of a page ranks). I'm leaning toward removing the /en version and redirecting to the / version. It would be a big step as currently - due to the internal linking - about 40% of our traffic goes through the /en path. Anything to be aware of? Any recommendations or advice would be much appreciated.
International SEO | | MaxSydenham0 -
Hreflang for bilingual website in the same region/location
Hi everyone, got a quick question concerning the hreflang tag. I have a website with 2 different language versions targeting to the same region(Reason: The area is bilingual however not everyone speaks the other language fluently) Question:
International SEO | | ennovators
Can I use hreflang in that case like: Many thanks in advance0 -
Can multiple hreflang tags point to one URL? International SEO question
Moz, Hi Moz, Can multiple hreflang tags point to a single URL? For example, if I have a Canadian site (www.example.com/ca) that targets French and English speakers can I have the following: or would I use: Any insight would be very helpful and greatly appreciated! Thank you in advance!
International SEO | | DA20131 -
When I upload my app in chrome web store, it shows this error - "no manifest found in package please make sure to put manifest at the root directory of the zip package". Please explain me the process of putting manifest file.
Chrome Web store give error "no manifest found in package please make sure to put manifest at the root directory of the zip package"
International SEO | | SameerBhatia0 -
International hreflang - will this handle duplicate content?
The title says it all - if i have duplicate content on my US and UK website, will adding the hreflang tag help google figure out that they are duplicate for a reason and avoid any penalties?
International SEO | | ALLee1 -
Optimizing terms with accents/tildes in Spanish
Hello all, quick question. We are optimizing for a keyword that includes an accent in Spanish. Is it better to use the accented or regular form (i.e. inglés vs. ingles)? Also, is there any distinction between accents (áéí...) and the ene (ñ) in terms of strategy/best practices? Does this accent issue have a huge impact on ranking?
International SEO | | CuriosityMedia0
